核心概念
Aqara Spec 物模型采用分层架构,从上到下依次为:Device(设备) → Endpoint(端点) → Device Type(设备类型) → Function(功能) → Trait(功能点) / Command(命令)。
设备内存在两类特殊 Endpoint:Root Endpoint(Endpoint 0)和 Public Endpoint(通常为 Endpoint 1)。Root Endpoint 承载设备根信息;Public Endpoint 承载设备级通用 Function,供整个设备共享,不在各业务 Endpoint 上重复实现。
以下以一台多 Endpoint 人体存在传感器设备为例,展示 Root Endpoint、Public Endpoint 与多个业务 Endpoint 的实际结构:
Device: "<Device ID>"
├── Endpoint 0 (Root Endpoint)
│ └── Root (Device Type)
│ └── Basic Information (Function)
│ ├── DebugInfo (Trait)
│ ├── BLEVersion (Trait)
│ ├── MCUVersion (Trait)
│ ├── FirmwareRevision (Trait)
│ ├── SerialNumber (Trait)
│ ├── VendorName (Trait)
│ ├── VendorID (Trait)
│ ├── ProductName (Trait)
│ ├── Reachable (Trait)
│ ├── FirmwareRevisionString (Trait)
│ └── ProductID (Trait)
├── Endpoint 1 (Public Endpoint)
│ └── Public (Device Type)
│ ├── Identify (Function)
│ │ ├── IdentifyTime (Trait)
│ │ ├── IdentifyType (Trait)
│ │ └── Identify (Command)
│ ├── Matter Commissioning (Function)
│ │ ├── MatterFabricsOperationState (Trait)
│ │ ├── ConnectedMatterFabrics (Trait)
│ │ ├── MatterCommissioningWindowStatus (Trait)
│ │ ├── MatterNodeID (Trait)
│ │ ├── OpenMatterCommissioningWindow (Command)
│ │ └── RemoveMatterFabric (Command)
│ ├── General Diagnostics (Function)
│ │ ├── UpTime (Trait)
│ │ ├── NetworkInterfaces (Trait)
│ │ ├── ActiveHardwareFaults (Trait)
│ │ ├── RebootCount (Trait)
│ │ └── RebootReason (Trait)
│ ├── Matter Node Information (Function)
│ │ └── MatterNodeFirstEndpointID (Trait)
│ └── Thread Network Diagnostics (Function)
│ ├── OverrunCount (Trait)
│ ├── PartitionID (Trait)
│ ├── TxTotalCount (Trait)
│ ├── TxUnicastCount (Trait)
│ ├── TxBroadcastCount (Trait)
│ ├── RxTotalCount (Trait)
│ ├── RxUnicastCount (Trait)
│ ├── RxBroadcastCount (Trait)
│ ├── NetworkFaultChange (Trait)
│ ├── Channel (Trait)
│ ├── PanID (Trait)
│ ├── ExtendedPanID (Trait)
│ ├── NetworkName (Trait)
│ ├── RouteTable (Trait)
│ ├── RoutingRole (Trait)
│ ├── NeighborTable (Trait)
│ └── MeshLocalPrefix (Trait)
├── Endpoint 2 (业务 Endpoint)
│ └── Occupancy Sensor (Device Type)
│ ├── Occupancy Sensing (Function)
│ │ ├── HoldTime (Trait)
│ │ ├── Occupancy (Trait)
│ │ └── OccupancySensorType (Trait)
│ ├── General Configuration (Function)
│ │ └── CurrentSensitivityLevel (Trait)
│ ├── Ambient Sensing Configuration (Function)
│ │ ├── InstallMode (Trait)
│ │ ├── SideInstall (Trait)
│ │ ├── InstallHeightSetting (Trait)
│ │ ├── InstallStatus (Trait)
│ │ ├── InstallAngle (Trait)
│ │ ├── MaxDetectionZones (Trait)
│ │ ├── Zones (Trait)
│ │ ├── EntryExitRegionBitmask (Trait)
│ │ ├── InterferenceRegionBitmask (Trait)
│ │ ├── EdgeRegionBitmask (Trait)
│ │ ├── EnableHumanCountDetection (Trait)
│ │ ├── EnableAIHighPrecisionRecognition (Trait)
│ │ ├── EnableAIEntryExitRegionRecognition (Trait)
│ │ ├── EnableAIInterferenceSourceRecognition (Trait)
│ │ ├── EnableAIAdaptiveSensitivity (Trait)
│ │ ├── CoordinateReverseSetting (Trait)
│ │ ├── DetectionDirectionSetting (Trait)
│ │ ├── AutoInterferenceSourceRecognition (Trait)
│ │ ├── AutoEdgeRecognition (Trait)
│ │ ├── AIEntryExitRegionRecognition (Trait)
│ │ ├── ProximityDistanceLevel (Trait)
│ │ ├── InterferenceSourceRecognitionReportingTimeout (Trait)
│ │ ├── AISpaceBackgroundLearningReportingTimeout (Trait)
│ │ ├── AISpaceBackgroundLearningComplete (Trait)
│ │ ├── SubscribeAutoInterferenceSourceRecognitionData (Command)
│ │ ├── SubscribeAutoEdgeRecognitionData (Command)
│ │ ├── SubscribeAIEntryExitRegionRecognitionData (Command)
│ │ ├── EnableAISpaceBackgroundLearning (Command)
│ │ ├── CreateZone (Command)
│ │ ├── UpdateZone (Command)
│ │ ├── RemoveZone (Command)
│ │ └── SetZones (Command)
│ ├── Radar Sensing Union (Function)
│ │ ├── ChildEndpointList (Trait)
│ │ ├── CurrentHumanCount (Trait)
│ │ └── MotionState (Trait)
│ └── Occupant Location (Function)
│ ├── MaxDetectionTargets (Trait)
│ ├── LocationInfo (Trait)
│ ├── SubscribeLocationData (Command)
│ └── SubscribeRemoveDetectionTarget (Command)
├── Endpoint 3 (业务 Endpoint)
│ └── Illuminance Sensor (Device Type)
│ └── Illuminance (Function)
│ └── CurrentIlluminance (Trait)
├── Endpoint 4 (业务 Endpoint, 子区域)
│ │ ├── ZoneID (Trait)
│ └── LocationInfo (Trait)
└── Endpoint 5 (业务 Endpoint, 子区域)
Device(设备)​
Device 是一个物理智能设备,如网关、灯泡、门锁、传感器等。一个 Device 由一个或多个 Endpoint 组成。
Endpoint(端点)​
Endpoint 是设备中的一个逻辑功能节点。每个 Endpoint 拥有一个 Endpoint ID(Uint16,取值 0 ~ 65535),并关联一个或多个 Device Type。
Aqara Spec 定义了三类 Endpoint:
  • Root Endpoint(Endpoint 0):设备根节点,关联 Root Device Type,必须实现 Basic Information 和 Descriptor 功能。
  • Public Endpoint(通常为 Endpoint 1):设备公共端点,关联 Public Device Type,承载 Identify、诊断、OTA 及各类生态协同等设备级通用 Function,供整个设备共享。
  • 业务 Endpoint(Endpoint 2 及以上):承载具体业务功能,关联对应的业务 Device Type(如 Occupancy Sensor、Illuminance Sensor)。同一 Device Type 可出现在多个 Endpoint 上(如上例 Endpoint 4、5 为 Endpoint 2 的子区域)。前端可见的业务 Endpoint 必须实现 Label、Endpoint Icon 功能,否则无法前端展示。
Device Type(设备类型)​
Device Type 用于描述 Endpoint 的设备类型。每个 Device Type 由唯一的 Device Type ID(Uint16)标识。每个 Device Type 定义了该类型设备必须(M)或可选(O)实现的 Function 集合。一个 Endpoint 下不允许添加重复的 Function。
除业务 Device Type 外,Aqara Spec 定义了两个与特殊 Endpoint 对应的 Device Type:
  • Root:仅用于 Root Endpoint,必须实现 Basic Information 和 Descriptor。
  • Public:仅用于 Public Endpoint,必须实现 Identify,可选实现诊断、网络配网、OTA 及各类生态协同等通用 Function。
例如上例中业务 Endpoint 2 关联 Occupancy Sensor Device Type,实现 Occupancy Sensing、Radar Sensing Union 等 Function;设备级通用能力(如 Identify、Matter Commissioning)由 Public Endpoint(Endpoint 1)统一提供,不在各业务 Endpoint 重复实现。
完整的 Device Type 列表见 设备类型。
Function(功能)​
Function 描述设备的一个完整功能单元,由若干 Traits 和 Commands 组成。
完整的 Function 列表见 功能代码。
Trait(功能点)​
Trait 描述 Function 中的一个属性或状态,支持 Read、Write、Report 等操作。
完整的 Trait 列表见 功能点代码。
Command(命令)​
Command 描述 Function 中可执行的操作,由客户端向设备发送。
完整的 Command 列表见 命令代码。
Parameter(参数)​
Parameter 是 Trait 内部的数据字段。
