Builder Lab FAQ
A Local Studio does not appear in Builder Lab​
Possible cause: The device running Builder Lab and the Studio are not on the same local network.
Solution: Connect both devices to the same local network, then search for the Local Studio again.
Possible cause: The Studio has not been set up.
Solution: Set up the Studio, then return to Builder Lab and search again.
The Studio I need is not listed under Create with My Devices​
Possible cause: The wrong remote or local connection method is selected.
Solution: Select Remote Studio or Local Studio to match how the Studio is connected.
The space plan cannot be deployed​
Possible cause: One or more devices in the plan are not matched to actual Studio devices.
Solution: Find each unmatched device and select an actual Studio device for it.
The automatic matches do not reflect the actual installation​
Possible cause: Automatic matches must be reviewed manually.
Solution: Change the match between each plan device and actual Studio device as needed.
A matched device may not support the features required by the plan​
Possible cause: The system does not currently check device-feature compatibility.
Solution: Use your knowledge of the devices to confirm that the plan device and actual Studio device are compatible.
A switch button cannot be assigned to another device category​
Possible cause: After the first controlled device is selected, only devices in the same category can be added.
Solution: Use only Aqara smart devices or only third-party smart devices for the same button.
A member is not listed during Application UI deployment​
Possible cause: The member has not joined the target Studio.
Solution: Invite the member in Studio Manager and make sure the invitation has been accepted.
