Data Types
This document summarizes custom data types (enumerations, structures, and so on) referenced by Trait and Command parameters.
ActiveHardwareFaultsEnum32​
This enumeration defines the valid Present Value values for the ActiveHardwareFaults Trait.
ValueNameDescription
0x00UnspecifiedUnknown fault
0x01RadioRadio fault
0x02SensorSensor fault
0x03ResettableOverTempOver-temperature protection
0x04NonResettableOverTempOver-temperature fault
0x05PowerSourcePower-source fault
0x06VisualDisplayFaultDisplay fault
0x07AudioOutputFaultAudio-output fault
0x08UserInterfaceFaultUser-interface fault
0x09NonVolatileMemoryErrorNon-volatile memory error
0x0ATamperDetectedDevice tampering detected
0xFFNormalNo fault
ActivityDetectionModeSettingEnum32​
This enumeration defines the valid Present Value values for the ActivityDetectionModeSetting Trait.
0x01HumanPresenceHuman presence
0x03PersonnelLocationPersonnel location
0x05FallDetectionFall detection
0x08CeilingFallSingleTrackingCeiling-mounted fall detection and single-person location
0x09SleepModeSleep
0x11GestureControlGesture
AddOrUpdateThreadNetwork Command Structure​
Parameter structure for the AddOrUpdateThreadNetwork Command.
Member IndexFieldTypeRequiredDescription
0OperationalDatasetoctetStringRequiredComplete Thread Operational Dataset. Omission or Null indicates the device will create a new network.
AddOrUpdateThreadNetworkResponse Command Structure​
Parameter structure for the AddOrUpdateThreadNetworkResponse Command.
0StatusCodesuint8RequiredStatus Codes.
AddOrUpdateWiFiNetwork Command Structure​
Parameter structure for the AddOrUpdateWiFiNetwork Command.
0SSIDcharacterStringOptionalSSID.
1CredentialscharacterStringOptionalCredentials.
2Encryptionuint8OptionalEncryption.
3CountryDomaincharacterStringOptionalCountry Domain.
4BindkeycharacterStringOptionalBindkey.
5TimeZonecharacterStringOptionalTime Zone.
AddOrUpdateWiFiNetworkResponse Command Structure​
Parameter structure for the AddOrUpdateWiFiNetworkResponse Command.
AddOrUpdateZigbeeNetwork Command Structure​
Parameter structure for the AddOrUpdateZigbeeNetwork Command.
0Channeluint8RequiredChannel.
1ExtendedPANIDoctetStringRequiredExtended PANID.
2NetworkKeyoctetStringRequiredNetwork Key.
3NetworkNamecharacterStringOptionalNetwork Name.
4PANIDuint16RequiredPANID.
AddOrUpdateZigbeeNetworkResponse Command Structure​
Parameter structure for the AddOrUpdateZigbeeNetworkResponse Command.
AddressingModeEnum8​
This enumeration defines the valid values for the AddressingMode field in NetworkInterfacesTraitPresentValueStructure.
0x00DHCPDHCP.
0x01StaticStatic.
0x02AutoAuto.
0xFFUnspecifiedUnspecified or unknown
AddUserDefinedEffect Command Structure​
Parameter structure for the AddUserDefinedEffect Command.
0EffectNamecharacterStringRequiredEffect Name.
1EffectDatacharacterStringRequiredEffect Data.
AirflowDirectionEnum8​
This enumeration defines the valid Present Value values for the AirflowDirection Trait.
0x00ForwardForward
0x01ReverseReverse
AirQualityEnum8​
This enumeration defines the valid Present Value values for the AirQuality Trait.
0x00UnknownUnknown
0x01ExcellentExcellent
0x02GoodGood
0x03FairFair
0x04InferiorInferior
0x05PoorPoor
AlarmErrorEnum8​
This enumeration defines the valid Present Value values for the AlarmError Trait.
0x00SUCCESSSuccess
0x01FAILUREFailure
0x02NOT_ALLOWEDNot allowed
AllpagesWidgetStructure​
This structure defines the field layout of items in the Allpages page Widgets list.
0WidgetIDuint16RequiredWidget ID.
1WidgetPositionWidgetPositionStructureRequiredWidget Position.
2WidgetModeenum8RequiredWidget Mode.
3AssociatedDeviceInfoAssociatedDeviceInfoStructureRequiredAssociated Device Info.
AnomalySoundDetectedEnum8​
This enumeration defines the valid Present Value values for the AnomalySoundDetected Trait.
0x01CryDetectedCry Detected.
0x02SnoreDetectedSnore Detected.
0x03LoudSoundDetectedLoud Sound Detected.
0x04BabyCryDetectedBaby Cry Detected.
0x05AlarmSoundDetectedAlarm Sound Detected.
0x06DogBarkDetectedDog Bark Detected.
0x07CoughDetectedCough Detected.
AntiDeletionLevelSettingEnum8​
This enumeration defines the valid Present Value values for the AntiDeletionLevelSetting Trait.
0x00EnableResetAndFactoryEnable Reset And Factory.
0x01DisableFactoryOnlyDisable Factory Only.
0x02DisableResetAndFactoryDisable Reset And Factory.
AntiDeletionNotificationEnum8​
This enumeration defines the valid Present Value values for the AntiDeletionNotification Trait.
0x01TriggerTrigger.
AntiDeletionSettingEnum8​
This enumeration defines the valid Present Value values for the AntiDeletionSetting Trait.
0x00DisableDisabled
0x01EnableEnabled
AssociatedDeviceInfoStructure​
This structure defines the layout of the AssociatedDeviceInfo field in Widget.
0DeviceNamecharacterStringRequiredDevice Name.
1DeviceTypeIDuint16RequiredDevice Type ID.
2DeviceIconcharacterStringRequiredDevice Icon.
3DeviceIDcharacterStringRequiredDevice ID.
4EndPointIDuint16RequiredEnd Point ID.
5ParentIDcharacterStringOptionalParent ID.
6ModelValuecharacterStringOptionalModel Value.
AttitudeDetectedEnum8​
This enumeration defines the valid Present Value values for the AttitudeDetected Trait.
0x00NormalNormal
0x01FallDownFall Down.
0x02SuspectedFallSuspected Fall.
AuthenticationStatusEnum8​
This enumeration defines the valid Present Value values for the AuthenticationStatus Trait.
0x00NotAuthenticatedNot Authenticated.
0x01CertifiedAndValidCertified And Valid.
0x02NoCertificateNo Certificate.
0x03CertificateInvalidCertificate Invalid.
BatChargeStateEnum8​
This enumeration defines the valid Present Value values for the BatChargeState Trait.
0x00UnknownUnknown
0x01TheBatteryIsChargingCharging
0x02TheBatteryIsAtFullChargeFully charged
0x03TheBatteryIsNotChargingNot charging
0x04TheBatteryIsNotChargeableNot chargeable
BatReplaceabilityEnum8​
This enumeration defines the valid Present Value values for the BatReplaceability Trait.
0x00UnspecifiedUnspecified
0x01NotReplaceableNot replaceable
0x02UserReplaceableUser-replaceable
0x03FactoryReplaceableFactory-replaceable
BindingTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the Binding Trait.
0DeviceIDcharacterStringRequiredDevice ID.
1ParentIDcharacterStringOptionalParent ID.
2GroupIDuint32OptionalGroup ID.
3ModelValuecharacterStringOptionalModel Value.
4EndPointIDuint32RequiredEnd Point ID.
5DeviceTypeIDuint32RequiredDevice Type ID.
BuiltInEffectsTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the BuiltInEffects Trait.
0EffectIDuint8RequiredEffect ID.
1BuiltInEffectLabelIDenum8RequiredBuilt In Effect Label ID.
ButtonEventEnum8​
This enumeration defines the valid Present Value values for the ButtonEvent Trait.
0x00SinglePressSingle press
0x01DoublePressDouble press
0x02LongPressLong press
0x03LongPressReleaseLong-press release
CCAModeEnum8​
This enumeration defines the valid Present Value values for the CCAMode Trait.
0x00CCA1CCA1.
0x01CCA1CCA1.
ChangeIndicationEnum8​
This enumeration defines the valid Present Value values for the ChangeIndication Trait.
0x00OKOK
0x01WarmingWarning
0x02CriticalCritical
ChangeTemperature Command Structure​
Parameter structure for the ChangeTemperature Command.
0SetTemperaturefloatRequiredSet Temperature.
ChangeTemperatureLevel Command Structure​
Parameter structure for the ChangeTemperatureLevel Command.
0SetTemperatureLeveluint8RequiredSet Temperature Level.
ChangeToMode Command Structure​
Parameter structure for the ChangeToMode Command.
0CurrentModeuint16RequiredCurrent Mode.
ChangeToModeResponseEnum16​
This enumeration defines the valid Present Value values for the ChangeToModeResponse Trait.
0x00SuccessSuccess
0x01UnsupportedModeUnsupported Mode.
0x02GenericFailureGeneric Failure.
0x03InvalidInModeInvalid In Mode.
0x41StuckStuck.
0x42DustBinMissingDust Bin Missing.
0x43DustBinFullDust Bin Full.
0x44WaterTankEmptyWater Tank Empty.
0x45WaterTankMissingWater Tank Missing.
0x46WaterTankLidOpenWater Tank Lid Open.
0x47MopCleaningPadMissingMop Cleaning Pad Missing.
0x48BatteryLowBattery Low.
ChildDeviceProvisioningStateEnum8​
This enumeration defines the valid Present Value values for the ChildDeviceProvisioningState Trait.
0x00NotProvisioningNot Provisioning.
0x01ProvisioningProvisioning.
ClearWeekDaySchedule Command Structure​
Parameter structure for the ClearWeekDaySchedule Command.
0WeekDayIndexuint8RequiredWeek Day Index.
1UserIndexuint16RequiredUser Index.
ClearYearDaySchedule Command Structure​
Parameter structure for the ClearYearDaySchedule Command.
0YearDayIndexuint8RequiredYear Day Index.
CO2LevelEnum8​
This enumeration defines the valid Present Value values for the CO2Level Trait.
0x00ExcellentExcellent
0x01LightPollutionLight Pollution.
0x02HeavyPollutionHeavy Pollution.
ColorModeEnum8​
This enumeration defines the valid Present Value values for the ColorMode Trait.
0x00HSVHSV.
0x01XYXY.
0x02ColorTemperatureColor Temperature.
ColorPointRGBXYPresentValueStructure​
This structure defines the layout of the Present Value fields for ColorPointRGBXY.
0ColorPointRXuint16RequiredColor Point RX.
1ColorPointRYuint16RequiredColor Point RY.
2ColorPointGXuint16RequiredColor Point GX.
3ColorPointGYuint16RequiredColor Point GY.
4ColorPointBXuint16RequiredColor Point BX.
5ColorPointBYuint16RequiredColor Point BY.
ConfigStaticIPAddr Command Structure​
Parameter structure for the ConfigStaticIPAddr Command.
0IPAddresscharacterStringOptionalIP Address.
1SubnetMaskcharacterStringOptionalSubnet Mask.
2DefaultGatewaycharacterStringOptionalDefault Gateway.
3PrimaryDNScharacterStringOptionalPrimary DNS.
4SecondaryDNScharacterStringOptionalSecondary DNS.
5InterfaceNamecharacterStringOptionalInterface Name.
6AddressingModeenum8OptionalAddressing Mode.
ConfigurationVersionTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the ConfigurationVersion Trait.
0ConfigurationVersionuint32RequiredConfiguration Version.
1ThingModelMd5characterStringRequiredThing Model Md5.
ConnectToHomeStation Command Structure​
Parameter structure for the ConnectToHomeStation Command.
0SSIDcharacterStringRequiredSSID.
1CredentialscharacterStringRequiredCredentials.
ConnectToHomeStationResponse Command Structure​
Parameter structure for the ConnectToHomeStationResponse Command.
0ConnectToHomeStationResponseenum8RequiredConnect To Home Station Response.
CubeEventEnum8​
This enumeration defines the valid Present Value values for the CubeEvent Trait.
0x00Flip90Flip90.
0x01Flip180Flip180.
0x02PushPush.
0x03TapTwiceTap Twice.
0x04ShakeShake.
0x05SwingSwing.
0x06RotateRotate.
0x07TriggeredAfter1MinuteTriggered After1 Minute.
0x0APickUpHoldPick Up Hold.
CubeWorkModeSettingEnum8​
This enumeration defines the valid Present Value values for the CubeWorkModeSetting Trait.
0x00Action ModeAction Mode.
0x01Scene ModeScene Mode.
CurOperationModeEnum8​
This enumeration defines the valid Present Value values for the CurOperationMode Trait.
0x00UnjoinedModeUnjoined Mode.
0x01NewlyJoinedModeNewly Joined Mode.
0x02PollingModePolling Mode.
0x03UserModeUser Mode.
0x04DegradedModeDegraded Mode.
0x05RejoinModeRejoin Mode.
CurrentGarageDoorStateEnum8​
This enumeration defines the valid Present Value values for the CurrentGarageDoorState Trait.
0x01UnknownUnknown
0x02OpenOpen
0x03ClosedClosed
0x04OpeningOpenFair
0x05ClosingClosedFair
0x06NotFullyOpenNot Fully Open.
0x07NotFullyClosedNot Fully Closed.
CurrentPlaybackStateEnum8​
This enumeration defines the valid Present Value values for the CurrentPlaybackState Trait.
0x00PlayingPlaying.
0x01PausedPaused.
0x02StoppedStopped.
0x03BufferingBuffering.
0x04FastForwardingFast Forwarding.
0x05RewindingRewinding.
CurrentSafetyManagementEnum8​
This enumeration defines the valid Present Value values for the CurrentSafetyManagement Trait.
0x00CurrentNormalCurrent Normal.
0x01OverCurrentAnomalyOver Current Anomaly.
0x02OverCurrentProtectionOver Current Protection.
CurrentValveStateEnum8​
This enumeration defines the valid Present Value values for the CurrentValveState Trait.
0x00ClosedClosed
0x01OpenOpen
0x02TransitioningTransitioning.
DetectionModeSettingEnum16​
This enumeration defines the valid Present Value values for the DetectionModeSetting Trait.
0x00UnconfiguredUnconfigured.
0x03DoorWindowStateDoor Window State.
0x05ObjectOrientationObject Orientation.
DoorLockAlarmTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the DoorLockAlarm Trait.
0AlarmCodeenum8RequiredAlarm Code.
DoorStateEnum8​
This enumeration defines the valid Present Value values for the DoorState Trait.
0x00DoorOpenDoor Open.
0x01DoorClosedDoor Closed.
0x02DoorJammedDoor Jammed.
0x03DoorForcedOpenDoor Forced Open.
0x04DoorUnspecifiedErrorDoor Unspecified Error.
0x05DoorAjarDoor Ajar.
EffectInfoTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the EffectInfo Trait.
2EffectNamecharacterStringRequiredEffect Name.
EndpointStructureNodeStructure​
This structure defines the field layout of nested child nodes in EndpointStructure.
0EndpointIduint16RequiredEndpoint Id.
1ChildEndpointslist[EndpointStructureNodeStructure]OptionalChild Endpoints.
EndpointStructureTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the EndpointStructure Trait.
EvseFaultStateEnum32​
This enumeration defines the valid Present Value values for the EvseFaultState Trait.
0x00NoErrorNo Error.
0x01MeterFailureMeter Failure.
0x02OverVoltageOver Voltage.
0x03UnderVoltageUnder Voltage.
0x04OverCurrentOver Current.
0x05ContactWetFailureContact Wet Failure.
0x06ContactDryFailureContact Dry Failure.
0x07GroundFaultGround Fault.
0x08PowerLossPower Loss.
0x09PowerQualityPower Quality.
0x0APilotShortCircuitPilot Short Circuit.
0x0BEmergencyStopEmergency Stop.
0x0CEVDisconnectedEV Disconnected.
0x0DWrongPowerSupplyWrong Power Supply.
0x0ELiveNeutralSwapLive Neutral Swap.
0x0FOverTemperatureOver Temperature.
0xFFOtherOther.
EvseStateEnum32​
This enumeration defines the valid Present Value values for the EvseState Trait.
0x00NotPluggedInNot Plugged In.
0x01PluggedInNoDemandPlugged In No Demand.
0x02PluggedInDemandPlugged In Demand.
0x03PluggedInChargingPlugged In Charging.
0x04PluggedInDischargingPlugged In Discharging.
0x05SessionEndingSession Ending.
0x06FaultFault.
EvseSupplyStateEnum32​
This enumeration defines the valid Present Value values for the EvseSupplyState Trait.
0x00DisabledDisabled
0x01ChargingEnabledCharging Enabled.
0x02DischargingEnabledDischarging Enabled.
0x03DisabledErrorDisabled Error.
0x04DisabledDiagnosticsDisabled Diagnostics.
0x05EnabledChargingandDischargingEnabled Chargingand Discharging.
ExpressedStateEnum8​
This enumeration defines the valid Present Value values for the ExpressedState Trait.
0x00NormalNormal
0x01SmokeAlarmSmoke Alarm.
0x02COAlarmCO Alarm.
0x03BatteryAlertBattery Alert.
0x04TestingTesting.
0x05HardwareFaultHardware Fault.
0x06EndOfServiceEnd Of Service.
0x07InterconnectSmokeInterconnect Smoke.
0x08InterconnectCOInterconnect CO.
FanModeEnum8​
This enumeration defines the valid Present Value values for the FanMode Trait.
0x00OffClosed
0x01LowSpeedLow Speed.
0x02MediumSpeedMedium Speed.
0x03HighSpeedHigh Speed.
0x04AutoAuto.
0x05SmartSmart.
FeedEnum8​
This enumeration defines the valid Present Value values for the Feed Trait.
0x01RemoteFeedingRemote Feeding.
FilterTypeEnum8​
This enumeration defines the valid Present Value values for the FilterType Trait.
This section defines the relevant fields and values. |-------|--------------------|----------| | 0x00 | HEPA | HEPA | | 0x01 | Activated Carbon | Activated Carbon. | | 0x02 | Photocatalytic | Photocatalytic. | | 0x03 | UV | UV. |
FlameDetectedEnum8​
This enumeration defines the valid Present Value values for the FlameDetected Trait.
0x01FlameDetectedFlame Detected.
FreshAirModeEnum8​
This enumeration defines the valid Present Value values for the FreshAirMode Trait.
0x00ManualManual.
0x01AutoAuto.
0x02ExhaustExhaust.
0x03HeatExchangeHeat Exchange.
0x04InternalCirculationInternal Circulation.
0x05ExternalCirculationExternal Circulation.
0x06PowerSavingPower Saving.
0x07StrongStrong.
0x08FreshAirFresh Air.
0x09BypassBypass.
GestureRecognitionReportEnum16​
This enumeration defines the valid Present Value values for the GestureRecognitionReport Trait.
0x02TwoTwo.
0x04FourFour.
0x05FiveFive.
0x06EightEight.
0x0AGoodGood.
0x65TwoBothHandsTwo Both Hands.
0x66FourBothHandsFour Both Hands.
0x67FiveBothHandsFive Both Hands.
0x68EightBothHandsEight Both Hands.
GetEffectData Command Structure​
Parameter structure for the GetEffectData Command.
GetWeekDaySchedule Command Structure​
Parameter structure for the GetWeekDaySchedule Command.
GetYearDaySchedule Command Structure​
Parameter structure for the GetYearDaySchedule Command.
GoToPositionPercentage Command Structure​
Parameter structure for the GoToPositionPercentage Command.
0PositionPercentagefloatRequiredPosition Percentage.
1TransitionTimeuint32OptionalTransition Time.
GoToPositionRotationPercentage Command Structure​
Parameter structure for the GoToPositionRotationPercentage Command.
0RotationPercentagefloatRequiredRotation Percentage.
HeaterCoolerButtonEventEnum8​
This enumeration defines the valid Present Value values for the HeaterCoolerButtonEvent Trait.
0x00PowerShortPressPower Short Press.
0x01FanSpeedShortPressFan Speed Short Press.
0x02TempUpShortPressTemp Up Short Press.
0x03TempDownShortPressTemp Down Short Press.
0x04ModeShortPressMode Short Press.
0x10PowerMidPressPower Mid Press.
0x11FanSpeedMidPressFan Speed Mid Press.
0x12TempUpMidPressTemp Up Mid Press.
0x13TempDownMidPressTemp Down Mid Press.
0x14ModeMidPressMode Mid Press.
0x30PowerLongPressPower Long Press.
0x31FanSpeedLongPressFan Speed Long Press.
0x32TempUpLongPressTemp Up Long Press.
0x33TempDownLongPressTemp Down Long Press.
0x34ModeLongPressMode Long Press.
HeaterCoolerModeEnum8​
This enumeration defines the valid Present Value values for the HeaterCoolerMode Trait.
0x00CoolCool.
0x01HeatHeat.
0x02AutoAuto.
0x03FanFan.
0x04DryDry.
0x05SleepSleep
0x06FreshAirFresh Air.
0x07FloorHeatFloor Heat.
0x08HeatandFloorHeatHeatand Floor Heat.
0x09FloorHeatandFreshAirFloor Heatand Fresh Air.
0x0AEmergencyHeatEmergency Heat.
0x0BPrecoolingPrecooling.
0x0COffClosed
0x0DManualManual.
0x0EAntiFreezeAnti Freeze.
HeaterCoolerPolarityEnum8​
This enumeration defines the valid Present Value values for the HeaterCoolerPolarity Trait.
0x00ForwardForward.
0x01ReverseReverse.
0x02BidirectionalBidirectional.
HomeKitPayloadTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the HomeKitPayload Trait.
0QRCodecharacterStringRequiredQR Code.
1DigitalPairingCodecharacterStringRequiredDigital Pairing Code.
HomeStationCredentialsTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the HomeStationCredentials Trait.
HubConnectionStatusEnum8​
This enumeration defines the valid Present Value values for the HubConnectionStatus Trait.
0x00DisconnectedDisconnected.
0x01ConnectedConnected.
HumanRecognitionReportEnum8​
This enumeration defines the valid Present Value values for the HumanRecognitionReport Trait.
0x01HumanDetectedHuman Detected.
Identify Command Structure​
Parameter structure for the Identify Command.
0IdentifyTimefloatRequiredIdentify Time.
IdentifyTypeEnum8​
This enumeration defines the valid Present Value values for the IdentifyType Trait.
0x00NoneNone
0x01LightLight
0x02LEDIndicatorLEDIndicator
0x03AudibleBeepAudibleBeep
0x04DisplayDisplay
0x05ActuatorActuator
InstallationOrientationConfigurationEnum16​
This enumeration defines the valid Present Value values for the InstallationOrientationConfiguration Trait.
0x00HorizontalHorizontal.
0x01VerticalVertical.
InterfaceTypeEnum8​
This enumeration defines the valid values for the Type field in NetworkInterfacesTraitPresentValueStructure.
0x01WiFiWi Fi.
0x02EthernetEthernet.
0x03CellularCellular.
0x04ThreadThread.
IRKeyEnum32​
This enumeration defines the valid Present Value values for the IRKey Trait.
0x00ReservedReserved
0x01PowerPower
0x02ModeMode
0x03Temp+Temp+
0x04Temp-Temp-
0x05WindSpeedWindSpeed
0x25A5P_KEYP_KEY
IRTypeEnum8​
This enumeration defines the valid Present Value values for the IRType Trait.
0x00AirConditionerAirConditioner
0x01TVTV
0x02FanFan
0x03TVBoxTVBox
0x04ProjectorProjector
0x05SettopBoxSettopBox
0x06DVDDVD
0x07HeaterHeater
0x08AirPurifierAirPurifier
0x09SpeakerSpeaker
0x0ALightingLighting
0x0BCameraCamera
0x0CCustomizeCustomize
LEDICProtocolEnum8​
This enumeration defines the valid Present Value values for the LEDICProtocol Trait.
0x01SIDSID.
LEDTypeEnum8​
This enumeration defines the valid Present Value values for the LEDType Trait.
0x01RGBWRGBW
LightingDynamicSceneModeEnum8​
This enumeration defines the valid Present Value values for the LightingDynamicSceneMode Trait.
0x00BreathBreath.
0x01ForwardRainbowForward Rainbow.
0x02WaterFlowWater Flow.
0x03FlickerFlicker.
0x04JumpJump.
0x05ReverseRainbowReverse Rainbow.
0x06FloatingFloating.
0x07RunningRunning.
LightingModeSettingEnum8​
This enumeration defines the valid Present Value values for the LightingModeSetting Trait.
0x00LevelLevel.
0x01ColorTempColor Temp.
0x02RGBRGB.
LightingMusicSyncModeEnum8​
This enumeration defines the valid Present Value values for the LightingMusicSyncMode Trait.
0x00RandomRandom.
0x01BreathBreath.
0x02RainbowRainbow.
0x03WaterFlowWater Flow.
LimitPointSettingEnum8​
This enumeration defines the valid Present Value values for the LimitPointSetting Trait.
0x00ClearLimitPointsClear Limit Points.
0x01SetOpenLimitSet Open Limit.
0x02SetCloseLimitSet Close Limit.
LoadSafetyManagementEnum8​
This enumeration defines the valid Present Value values for the LoadSafetyManagement Trait.
0x00LoadNormalLoad Normal.
0x01OverLoadAnomalyOver Load Anomaly.
0x02OverLoadProtectionOver Load Protection.
LoadTypeEnum8​
This enumeration defines the valid Present Value values for the LoadType Trait.
0x00GeneralGeneral
0x01LinkableLinkable
0x02PulsedPulsed
LockDoor Command Structure​
Parameter structure for the LockDoor Command.
0CodecharacterStringOptionalCode.
LockOperationErrorTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the LockOperationError Trait.
0LockOperationTypeenum8RequiredLock Operation Type.
1OperationSourceenum8RequiredOperation Source.
2OperationErrorenum8RequiredOperation Error.
3UserIndexuint16RequiredUser Index.
4FabricIDuint64RequiredFabric ID.
5SourceNodeuint64RequiredSource Node.
6Credentialslist[Struct]OptionalCredentials.
LockOperationTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the LockOperation Trait.
2UserSourceenum8OptionalUser Source.
3UserIduint32OptionalUser Id.
4CredentialIduint32OptionalCredential Id.
5MatterVendorIduint16OptionalMatter Vendor Id.
6LockPositionenum8OptionalLock Position.
LockStateEnum8​
This enumeration defines the valid Present Value values for the LockState Trait.
0x00NotFullyLockedNot Fully Locked.
0x01LockedLocked.
0x02UnlockedUnlocked.
LockUserChangeTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the LockUserChange Trait.
0LockDataTypeenum8RequiredLock Data Type.
1DataOperationTypeenum8RequiredData Operation Type.
2OperationSourceenum8RequiredOperation Source.
6DataIndexuint16OptionalData Index.
MagicPairPayloadTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the MagicPairPayload Trait.
ManualPullEventEnum32​
This enumeration defines the valid Present Value values for the ManualPullEvent Trait.
0x01ManualOpenManual Open.
0x02ManualCloseManual Close.
0x03ManualStopManual Stop.
MatterBindStateEnum8​
This enumeration defines the valid Present Value values for the MatterBindState Trait.
0x00UnboundUnbound
0x01BoundBound
MatterDACStateEnum8​
This enumeration defines the valid Present Value values for the MatterDACState Trait.
0x00LoadingDACLoadingDAC
0x01FailedDACFailedDAC
0x02ReadyDACReadyDAC
MatterPairingStateEnum8​
This enumeration defines the valid Present Value values for the MatterPairingState Trait.
0x00NonMatterPairingStateNon Matter Pairing State.
0x01MatterPairingStateMatter Pairing State.
0x02LimitExceededLimit Exceeded.
0x03InvalidDACInvalid DAC.
0x04UnderPreparationUnder Preparation.
MatterPayloadTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the MatterPayload Trait.
MediaPlaybackCommand Command Structure​
Parameter structure for the MediaPlaybackCommand Command.
0MediaTypeenum8RequiredMedia Type.
1CommandcharacterStringOptionalCommand.
2TitlecharacterStringOptionalTitle.
MotionDetectedEnum8​
This enumeration defines the valid Present Value values for the MotionDetected Trait.
0x00EnterEnter.
0x01LeftLeft.
0x02LeftInLeft In.
0x03RightOutRight Out.
0x04RightInRight In.
0x05LeftOutLeft Out.
0x06AccessAccess.
0x07AwayAway.
MotorOperationStatusEnum8​
This enumeration defines the valid Present Value values for the MotorOperationStatus Trait.
0x00ClosingClosedFair
0x01OpeningOpenFair
0x02StoppedStopped.
0x03ObstacleStopObstacle Stop.
0x04ObstacleLimitAutoReboundObstacle Limit Auto Rebound.
MotorSpeedSettingEnum8​
This enumeration defines the valid Present Value values for the MotorSpeedSetting Trait.
0x00LowSpeedLow Speed.
0x01MediumSpeedMedium Speed.
0x02HighSpeedHigh Speed.
MoveToColorTemperature Command Structure​
Parameter structure for the MoveToColorTemperature Command.
0ColorTemperatureuint32RequiredColor Temperature.
1Timeint32OptionalTime.
2ExecuteIfOffbooleanOptionalExecute If Off.
MoveToColorTemperatureBrightness Command Structure​
Parameter structure for the MoveToColorTemperatureBrightness Command.
1LevelfloatRequiredLevel.
2Timeint32OptionalTime.
3ExecuteIfOffbooleanOptionalExecute If Off.
MoveToHueAndSaturation Command Structure​
Parameter structure for the MoveToHueAndSaturation Command.
0HuefloatRequiredHue.
1SaturationfloatRequiredSaturation.
MoveToHueSaturationBrightness Command Structure​
Parameter structure for the MoveToHueSaturationBrightness Command.
2LevelfloatRequiredLevel.
3Timeint32OptionalTime.
4ExecuteIfOffbooleanOptionalExecute If Off.
MoveToXYColor Command Structure​
Parameter structure for the MoveToXYColor Command.
0ColorXuint16RequiredColor X.
1ColorYuint16RequiredColor Y.
MoveToXYColorBrightness Command Structure​
Parameter structure for the MoveToXYColorBrightness Command.
NetworkInterfacesTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the NetworkInterfaces Trait.
0NamecharacterStringOptionalName.
1IsOperationalbooleanRequiredIs Operational.
2OffPremiseServicesReachableIPv4booleanOptionalOff Premise Services Reachable I Pv4.
3OffPremiseServicesReachableIPv6booleanOptionalOff Premise Services Reachable I Pv6.
4HardwareAddresscharacterStringRequiredHardware Address.
5IPv4Addresseslist[characterString]OptionalI Pv4 Addresses.
6IPv6Addresseslist[characterString]OptionalI Pv6 Addresses.
7TypeInterfaceTypeEnum8RequiredType.
8RSSIint8OptionalRSSI.
9AddressingModeAddressingModeEnum8OptionalAddressing Mode.
10SSIDcharacterStringOptionalSSID.
11BSSIDcharacterStringOptionalBSSID.
12RouterMACcharacterStringOptionalRouter MAC.
13Channeluint8OptionalChannel.
14SubnetMaskcharacterStringOptionalSubnet Mask.
15DefaultGatewaycharacterStringOptionalDefault Gateway.
16PrimaryDNScharacterStringOptionalPrimary DNS.
17SecondaryDNScharacterStringOptionalSecondary DNS.
NightLightModeEnum8​
This enumeration defines the valid Present Value values for the NightLightMode Trait.
0x00OffOff.
0x01OnOn.
0x02AutoAuto.
ObjectOrientationStateEnum8​
This enumeration defines the valid Present Value values for the ObjectOrientationState Trait.
0x01HorizontalUpHorizontal Up.
0x02HorizontalDownHorizontal Down.
0x03VerticalVertical.
0x04TiltedTilted.
ObstacleLimitSensitivityEnum8​
This enumeration defines the valid Present Value values for the ObstacleLimitSensitivity Trait.
0x00LowLow.
0x01MediumLowMedium Low.
0x02MediumMedium.
0x03MediumHighMedium High.
0x04HighHigh.
OccupancySensorTypeEnum8​
This enumeration defines the valid Present Value values for the OccupancySensorType Trait.
0x00PIRPIR.
0x01UltrasonicUltrasonic.
0x02PIRAndUltrasonicPIR And Ultrasonic.
0x03PhysicalContactPhysical Contact.
0x04RadarRadar.
0x05VisionVision.
OperatingModeEnum8​
This enumeration defines the valid Present Value values for the OperatingMode Trait.
0x00NormalNormal
0x01VacationVacation
0x02PrivacyPrivacy
0x03NoRemoteLockUnlockNoRemoteLockUnlock
0x04PassagePassage
OperationalErrorEnum16​
This enumeration defines the valid Present Value values for the OperationalError Trait.
0x01UnableToStartOrResumeUnable To Start Or Resume.
0x02UnableToCompleteOperationUnable To Complete Operation.
0x03CommandInvalidInStateCommand Invalid In State.
OperationalStateEnum16​
This enumeration defines the valid Present Value values for the OperationalState Trait.
0x00StoppedStopped.
0x01RunningRunning.
0x02PausedPaused.
0x03ErrorError.
OutputNodeModeEnum32​
This enumeration defines the valid Present Value values for the OutputNodeMode Trait.
0x00WetModeWet Mode.
0x01DryPulseNormallyClosedDry Pulse Normally Closed.
0x02DryPulseNormallyOpenDry Pulse Normally Open.
0x03DryToggleModeDry Toggle Mode.
OutputSwitchingTypeEnum8​
This enumeration defines the valid Present Value values for the OutputSwitchingType Trait.
0x01NonResettableSwitchNon Resettable Switch.
0x02MomentaryPushSwitchMomentary Push Switch.
0x03ActiveLowCloseRelayActive Low Close Relay.
0x04InsertCardOnModeInsert Card On Mode.
0x05InsertCardOffModeInsert Card Off Mode.
OverCurrentResponseSettingEnum8​
This enumeration defines the valid Present Value values for the OverCurrentResponseSetting Trait.
0x00ShutdownSingleShutdown Single.
0x01ShutdownAllShutdown All.
PackageRecognitionReportEnum8​
This enumeration defines the valid Present Value values for the PackageRecognitionReport Trait.
0x01PackageAppearedPackage Appeared.
0x02PackageDisappearedPackage Disappeared.
PanTiltDirectionControl Command Structure​
Parameter structure for the PanTiltDirectionControl Command.
0Directionuint8RequiredDirection.
PetRecognitionReportEnum16​
This enumeration defines the valid Present Value values for the PetRecognitionReport Trait.
0x01CatDetectedCat Detected.
0x02DogDetectedDog Detected.
0x03CatOrDogDetectedCat Or Dog Detected.
PlaybackModeEnum8​
This enumeration defines the valid Present Value values for the PlaybackMode Trait.
0x00ShuffleShuffle
0x01OrderOrder
0x02SingleCycleSingleCycle
0x03AllCycleAllCycle
PM2.5LevelEnum8​
0x00UnknownUnknown
0x02GoodGood.
0x03FairFair.
0x05PoorPoor
PowerModeEnum8​
This enumeration defines the valid Present Value values for the PowerMode Trait.
0x00UnknownUnknown
0x01MainsMains.
0x02BatteryBattery.
0x03DCSourceDC Source.
0x04ACSourceAC Source.
PreOperationModeEnum8​
This enumeration defines the valid Present Value values for the PreOperationMode Trait.
PresenceConfigurationTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the PresenceConfiguration Trait.
0HubListlist[characterString]RequiredHub List.
1EventsStructOptionalEvents.
2StatesStructOptionalStates.
3EntriescharacterStringOptionalEntries.
4Configuint32OptionalConfig.
PresenceEnum8​
This enumeration defines the valid Present Value values for the Presence Trait.
0x00UnknownUnknown
0x01NoHumanDetectedNo Human Detected.
0x02HumanDetectedHuman Detected.
PresetTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the Preset Trait.
0PresetHandlecharacterStringRequiredPreset Handle.
1PresetScenarioenum8RequiredPreset Scenario.
2NamecharacterStringOptionalName.
3CoolingSetpointfloatOptionalCooling Setpoint.
4HeatingSetpointfloatOptionalHeating Setpoint.
5BuiltInbooleanRequiredBuilt In.
PreviewEffect Command Structure​
Parameter structure for the PreviewEffect Command.
0EffectDatacharacterStringRequiredEffect Data.
PreviewTransition Command Structure​
Parameter structure for the PreviewTransition Command.
0OnTransitionTimeuint16RequiredOn Transition Time.
1OffTransitionTimeuint16RequiredOff Transition Time.
2DimmingCurvaturefloatRequiredDimming Curvature.
3InitialBrightnessuint8RequiredInitial Brightness.
Reboot Command Structure​
Parameter structure for the Reboot Command.
0RebootTypeenum8RequiredReboot Type.
1Delayuint32OptionalDelay.
RebootReasonEnum8​
This enumeration defines the valid Present Value values for the RebootReason Trait.
0x01PowerOnRebootPower On Reboot.
0x02BrownOutResetBrown Out Reset.
0x03SoftwareWatchdogResetSoftware Watchdog Reset.
0x04HardwareWatchdogResetHardware Watchdog Reset.
0x05SoftwareUpdateCompletedSoftware Update Completed.
0x06SoftwareResetSoftware Reset.
RemoveUserDefinedEffect Command Structure​
Parameter structure for the RemoveUserDefinedEffect Command.
ResetModeEnum8​
This enumeration defines the valid Present Value values for the ResetMode Trait.
0x01FactoryResetFactory Reset.
0x02NetworkResetNetwork Reset.
0x03ConfigurationsResetConfigurations Reset.
0x04PSWResetPSW Reset.
RingtonePlayIndexEnum32​
This enumeration defines the valid Present Value values for the RingtonePlayIndex Trait.
0x00PoliceCar1Police Car1.
0x01PoliceCar2Police Car2.
0x02SafetyAccidentSafety Accident.
0x03MissileCountdownMissile Countdown.
0x04GhostSoundGhost Sound.
0x05SniperRifleSniper Rifle.
0x06IntenseBattleIntense Battle.
0x07AirRaidSirenAir Raid Siren.
0x08DogBarkDog Bark.
0x0ADoorbellDoorbell.
0x0BKnockKnock.
0x0CFunnyFunny.
0x0DAlarmClockAlarm Clock.
0x0EArmingArming.
0x0FDisarmingDisarming.
0x14MiMixMiMix
0x15EnthusiasticEnthusiastic
0x16GuitarClassicGuitarClassic
0x17IceWorldPianoIceWorldPiano
0x18LeisureTimeLeisureTime
0x19ChildhoodChildhood
0x1AMorningStreamIetMorningStreamIet
0x1BMusixBoxMusixBox
0x1COrangeOrange
0x2710DefaultRingtoneDefault Ringtone.
RingtonePlayStatusEnum8​
This enumeration defines the valid Present Value values for the RingtonePlayStatus Trait.
0x00StoppedStopped.
0x01PlayingPlaying.
RockSettingEnum8​
This enumeration defines the valid Present Value values for the RockSetting Trait.
0x00OffClosed
0x01RockLeftRightRock Left Right.
0x02RockUpDownRock Up Down.
0x03RockRoundRock Round.
0x04SwingSwing.
0x05FixedDirectionFixed Direction.
0x15FixedFixed.
RotationControl Command Structure​
Parameter structure for the RotationControl Command.
0Directionenum8RequiredDirection.
RotationDirectionEnum8​
This enumeration defines the valid Present Value values for the RotationDirection Trait.
0x00ClockwiseClockwise
0x01CounterClockwiseCounterClockwise
RotationEventEnum8​
This enumeration defines the valid Present Value values for the RotationEvent Trait.
0x00RotateRotate.
0x01HoldToRotateHold To Rotate.
0x02InvertedRotateInverted Rotate.
SelectedMediaOutputSourceEnum8​
This enumeration defines the valid Present Value values for the SelectedMediaOutputSource Trait.
0x00InternalInternal.
0x01BluetoothBluetooth.
0x02AuxAux.
0x03SPDIFSPDIF
0x04CoaxialCoaxial.
0x05Audio1Audio1.
0x06Audio2Audio2.
0x07Audio3Audio3.
0x08AV1AV1
0x09AV2AV2
0x0AAV3AV3
0x0BHDMI1HDMI1
0x0CHDMI2HDMI2
0x0DHDMI3HDMI3
0x0EOtherOther.
SelectedSourceEnum8​
This enumeration defines the valid Present Value values for the SelectedSource Trait.
0x02ExternalExternal
SelectInput Command Structure​
Parameter structure for the SelectInput Command.
0MediaInputuint8RequiredMedia Input.
SendIRCode Command Structure​
Parameter structure for the SendIRCode Command.
0Modeenum8RequiredMode.
1BrandIduint32RequiredBrand Id.
2RemoteIduint32RequiredRemote Id.
3IRCodecharacterStringOptionalIR Code.
4IRCodeLengthuint16OptionalIR Code Length.
5ACKeycharacterStringOptionalAC Key.
6Frequencyuint32RequiredFrequency.
SetActivePreset Command Structure​
Parameter structure for the SetActivePreset Command.
SetBrightness Command Structure​
Parameter structure for the SetBrightness Command.
0LevelfloatRequiredLevel.
SetBrightnessWithOnOff Command Structure​
Parameter structure for the SetBrightnessWithOnOff Command.
SetWeekDaySchedule Command Structure​
Parameter structure for the SetWeekDaySchedule Command.
2DaysMaskenum8RequiredDays Mask.
3StartHouruint8RequiredStart Hour.
4StartMinuteuint8RequiredStart Minute.
5EndHouruint8RequiredEnd Hour.
6EndMinuteuint8RequiredEnd Minute.
SetYearDaySchedule Command Structure​
Parameter structure for the SetYearDaySchedule Command.
2LocalStartTimeuint64RequiredLocal Start Time.
3LocalEndTimeuint64RequiredLocal End Time.
SleepStageEnum8​
This enumeration defines the valid Present Value values for the SleepStage Trait.
0x00LightSleepLightSleep
0x01DeepSleepDeepSleep
0x02REMREM
SleepStateEnum8​
This enumeration defines the valid Present Value values for the SleepState Trait.
0x00UnknownUnknown
0x01AwakeAwake.
0x02SleepSleep.
SmokeChamberContaminationEnum8​
This enumeration defines the valid Present Value values for the SmokeChamberContamination Trait.
0x00NormalNormal.
0x01ContaminatedContaminated.
SmokeStateEnum8​
This enumeration defines the valid Present Value values for the SmokeState Trait.
0x00NormalNormal
0x01WarningWarning
0x02CriticalCritical.
StartEffect Command Structure​
Parameter structure for the StartEffect Command.
0EffectIDenum8RequiredEffect ID.
StartUpOnOffEnum8​
This enumeration defines the valid Present Value values for the StartUpOnOff Trait.
0x00OffOff.
0x01OnOn.
0x02ToggleToggle.
0x03HoldHold.
StateOfLowBatEnum8​
This enumeration defines the valid Present Value values for the StateOfLowBat Trait.
0x00FalseFalse.
0x01TrueTrue.
StationaryStateEnum8​
This enumeration defines the valid Present Value values for the StationaryState Trait.
0x00InMotionIn Motion.
0x01StationaryStationary.
StepBrightness Command Structure​
Parameter structure for the StepBrightness Command.
0SizefloatRequiredSize.
StepBrightnessWithOnOff Command Structure​
Parameter structure for the StepBrightnessWithOnOff Command.
StepColorTemperature Command Structure​
Parameter structure for the StepColorTemperature Command.
0Sizeint32RequiredSize.
StepPosition Command Structure​
Parameter structure for the StepPosition Command.
SweeperStateEnum8​
This enumeration defines the valid Present Value values for the SweeperState Trait.
0x00CleaningCleaning.
0x01PausedPaused.
0x02NotCleaningNot Cleaning.
TargetGarageDoorStateEnum8​
This enumeration defines the valid Present Value values for the TargetGarageDoorState Trait.
0x00ClosedClosed
0x01OpenOpen
TargetPlaybackStateEnum8​
This enumeration defines the valid Present Value values for the TargetPlaybackState Trait.
0x00PlayPlay.
0x01PausePause.
0x02StopStop.
0x03StartOverStart Over.
0x04FastForwardFast Forward.
0x05RewindRewind.
0x06PreviousPrevious.
0x07NextNext.
0x08PlaySpecificListPlay Specific List.
TemperatureSafetyManagementEnum8​
This enumeration defines the valid Present Value values for the TemperatureSafetyManagement Trait.
0x00TempNormalTemp Normal.
0x01OverTempAnomalyOver Temp Anomaly.
0x02OverTempProtectionOver Temp Protection.
0x0BUnderTempAnomalyUnder Temp Anomaly.
TemperatureUIDisplayModeEnum8​
This enumeration defines the valid Present Value values for the TemperatureUIDisplayMode Trait.
0x00CelsiusCelsius.
0x01FahrenheitFahrenheit.
ThreadDiagnosticsTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the ThreadDiagnostics Trait.
1ExtendedPANIDuint64RequiredExtended PANID.
3NetworkNamecharacterStringRequiredNetwork Name.
5PSKcoctetStringRequiredPS Kc.
6ActiveTimeStampuint64RequiredActive Time Stamp.
7SecurityPolicycharacterStringRequiredSecurity Policy.
8OperationalDatasetoctetStringRequiredOperational Dataset.
9RSSIint8OptionalRSSI.
10LQIuint8OptionalLQI.
11BorderAgentIDoctetStringOptionalBorder Agent ID.
12MeshLocalPrefixcharacterStringOptionalMesh Local Prefix.
13CommissionerCredentialcharacterStringOptionalCommissioner Credential.
14VersioncharacterStringOptionalVersion.
15Roleuint8OptionalRole.
TopFaceChangedEnum8​
This enumeration defines the valid Present Value values for the TopFaceChanged Trait.
0x00Face 1 UpFace 1 Up.
0x01Face 2 UpFace 2 Up.
0x02Face 3 UpFace 3 Up.
0x03Face 4 UpFace 4 Up.
0x04Face 5 UpFace 5 Up.
0x05Face 6 UpFace 6 Up.
TopFaceEnum8​
This enumeration defines the valid Present Value values for the TopFace Trait.
TriggerWarning Command Structure​
Parameter structure for the TriggerWarning Command.
0Warningenum8RequiredWarning.
TriggerZigbeeNetworkInfoUpload Command Structure​
Parameter structure for the TriggerZigbeeNetworkInfoUpload Command.
0InstallCodecharacterStringRequiredInstall Code.
1MACcharacterStringRequiredMAC.
UnboltDoor Command Structure​
Parameter structure for the UnboltDoor Command.
UnlockDoor Command Structure​
Parameter structure for the UnlockDoor Command.
UpdateUserDefinedEffect Command Structure​
Parameter structure for the UpdateUserDefinedEffect Command.
UserDefinedEffectsTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the UserDefinedEffects Trait.
1EffectNamecharacterStringRequiredEffect Name.
VacuumOperationalErrorEnum16​
This enumeration defines the valid Present Value values for the VacuumOperationalError Trait.
0x40FailedToFindChargingDockFailed To Find Charging Dock.
0x41StuckStuck.
VacuumOperationalStateEnum16​
This enumeration defines the valid Present Value values for the VacuumOperationalState Trait.
0x00StoppedStopped.
0x01RunningRunning.
0x02PausedPaused.
0x03ErrorError.
0x40SeekingChargerSeeking Charger.
0x41ChargingCharging.
0x42DockedDocked.
VehicleDetectedEnum8​
This enumeration defines the valid Present Value values for the VehicleDetected Trait.
0x01VehicleDetectedVehicle Detected.
VibrationEventEnum8​
This enumeration defines the valid Present Value values for the VibrationEvent Trait.
0x00ThreeKnocksThree Knocks.
0x01MoveMove.
0x02VibrateVibrate.
0x03TiltTilt.
0x04FreeFallFree Fall.
VOCQualityEnum8​
This enumeration defines the valid Present Value values for the VOCQuality Trait.
0x00UnknownUnknown
0x02GoodGood.
0x03FairFair.
0x05PoorPoor
VoiceLanguageEnum8​
This enumeration defines the valid Present Value values for the VoiceLanguage Trait.
0x01ChineseChinese.
0x02EnglishEnglish.
0x03CantoneseCantonese.
0x04SpanishSpanish.
0x05RussianRussian.
0x06KoreanKorean.
0x07PortugueseBRPortuguese BR.
0x08GermanGerman.
0x09FrenchFrench.
0x0AItalianItalian.
0x0BJapaneseJapanese.
0x0CPolishPolish.
0x0DCzechCzech.
0x0ESlovakSlovak.
0x0FTurkishTurkish.
0x10HungarianHungarian.
0x11DutchDutch.
0x12GreekGreek.
0x13ArabicArabic.
VoltageSafetyManagementEnum8​
This enumeration defines the valid Present Value values for the VoltageSafetyManagement Trait.
0x00VoltageNormalVoltage Normal.
0x01OverVoltageAnomalyOver Voltage Anomaly.
0x02OverVoltageProtectionOver Voltage Protection.
0x03UnderVoltageProtectionUnder Voltage Protection.
WhitePointXYPresentValueStructure​
This structure defines the layout of the Present Value fields for WhitePointXY.
0WhitePointXuint16RequiredWhite Point X.
1WhitePointYuint16RequiredWhite Point Y.
WidgetPositionStructure​
This structure defines the layout of the WidgetPosition field in Widget.
0xuint16RequiredX.
1yuint16RequiredY.
2widthuint16RequiredWidth.
3heightuint16RequiredHeight.
WiFiDiagnosticsTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the WiFiDiagnostics Trait.
0BSSIDcharacterStringRequiredBSSID.
1Encryptionuint8OptionalEncryption.
2Versionuint8OptionalVersion.
3Channeluint8RequiredChannel.
4RSSIint8RequiredRSSI.
5NetworkNamecharacterStringRequiredNetwork Name.
6IPV4AddresscharacterStringOptionalIPV4 Address.
7IPV6AddresscharacterStringOptionalIPV6 Address.
8SubnetMaskcharacterStringOptionalSubnet Mask.
9GatewaycharacterStringOptionalGateway.
10DNScharacterStringOptionalDNS.
11AlternateDNScharacterStringOptionalAlternate DNS.
WindowCoveringCategoryEnum8​
This enumeration defines the valid Present Value values for the WindowCoveringCategory Trait.
0x00RollerShadeRoller Shade.
0x01RollerShade2MotorRoller Shade2 Motor.
0x02RollerShadeExteriorRoller Shade Exterior.
0x03RollerShadeExterior2MotorRoller Shade Exterior2 Motor.
0x04DraperyDrapery.
0x05AwningAwning.
0x06ShutterShutter.
0x07TiltBlindTiltOnlyTilt Blind Tilt Only.
0x08TiltBlindLiftAndTiltTilt Blind Lift And Tilt.
0x09ProjectorScreenProjector Screen.
0xFFUnknownUnknown
WindowCoveringOpenOrientationEnum8​
This enumeration defines the valid Present Value values for the WindowCoveringOpenOrientation Trait.
0x00LeftRightLeft Right.
0x01LeftToRightLeft To Right.
0x02RightToLeftRight To Left.
0x03UpUp.
0x04HorizontalHorizontal.
0x05VerticalVertical.
WindowCoveringTypeEnum8​
This enumeration defines the valid Present Value values for the WindowCoveringType Trait.
0x01VenetianBlindVenetian Blind.
0x02ShangrilaBlindShangrila Blind.
0x03ZebraBlindZebra Blind.
0x04CurtainCurtain.
0x05VerticalVenetianBlindVertical Venetian Blind.
0x1FRomanShadeRoman Shade.
0x20BalloonShadeBalloon Shade.
0x21WovenWoodWoven Wood.
0x22PleatedShadePleated Shade.
0x23CellularShadeCellular Shade.
0x24LayeredShadeLayered Shade.
0x25LayeredShade2DLayered Shade2 D.
0x26SheerShadeSheer Shade.
0x27TiltOnlyInteriorBlindTilt Only Interior Blind.
0x28InteriorBlindInterior Blind.
0x29VerticalBlindStripCurtainVertical Blind Strip Curtain.
0x2AInteriorVenetianBlindInterior Venetian Blind.
0x2BExteriorVenetianBlindExterior Venetian Blind.
0x2CLateralLeftCurtainLateral Left Curtain.
0x2DLateralRightCurtainLateral Right Curtain.
0x2ECentralCurtainCentral Curtain.
0x2FRollerShutterRoller Shutter.
0x30ExteriorVerticalScreenExterior Vertical Screen.
0x31AwningTerracePatioAwning Terrace Patio.
0x32AwningVerticalScreenAwning Vertical Screen.
0x33TiltOnlyPergolaTilt Only Pergola.
0x34SwingingShutterSwinging Shutter.
0x35SlidingShutterSliding Shutter.
0xFFUnknownUnknown
WindSettingEnum8​
This enumeration defines the valid Present Value values for the WindSetting Trait.
0x00NormalNormal
0x01SleepSleep
0x02NaturalNatural.
ZigbeeDiagnosticsTraitPresentValueStructure​
This structure defines the layout of the Present Value fields for the ZigbeeDiagnostics Trait.
5RSSIint8OptionalRSSI.
6LQIuint8OptionalLQI.
