Get Device Filter Options
GET/devices/filter-options
Returns the protocol instances that have been created and are visible to the caller, which can be used as filter conditions for /devices. By default, all supported option categories are returned; currently, only protocols are supported. You can specify which categories to return via the 'fields' parameter; unrequested categories will not be returned. If there are no available instances, an empty array will be returned. Local calls can return instances that are offline or have no devices; cloud calls with device authorization enabled will only return instances associated with accessible devices. Blacklisted networks and cloud-exported networks are not returned as filter options. Instances without a public type or bit mask configured will still return id and name, with their type and networkProtocolMask explicitly set to null; internal framework types will not be returned. This API supports both local and cloud HTTP calls. Only options are returned; device counts are not provided. This API does not interlock with other device filter conditions and does not offer a WebSocket/MCP option querying entrance.
Request
Responses
- 200
- 400
- 401
- 403
- 429
- 500
Success. If no available instances, data.protocols will be [].
fields is empty, contains empty segments, or contains unknown categories.
Unauthorized or authentication expired
No permission to access
Request frequency too high
The protocol type mapping configuration is invalid or an internal error occurred.
