Spatial Parsing (Foundation)
Spatial parsing is Builder Agent's foundation — before recommending devices or orchestrating scenes, the Agent must first "see" the space.
Why It's the Foundation​
Device recommendations require knowing "which device goes in which room," and scene orchestration requires knowing "how the living room lights and AC work together" — all of which depend on one prerequisite: the Agent has a clear picture of what's in the space, where things are, and how they relate to each other.
Spatial parsing converts a floor plan image or description into a spatial model + spatial graph the Agent can reason with.
How It Works​
The process has two steps:
  1. Spatial Model: Converts the floor plan image / description into a computable geometric and semantic structure — rooms, walls, and device points, plus what each space "is" (this is the living room, that's the master bedroom, this one is the balcony…)
  2. Spatial Graph: Builds a relationship network on top of the model — relative relationships (belongsTo, connects, isAdjacentTo) between rooms, devices, and zones, so the Agent understands "who is inside whom, and who is next to whom"
What the Spatial Model Looks Like​
Once parsing is complete, the space is represented as a Spatial Graph:
  • Nodes: rooms, devices, zones, etc.
  • Edges (relationships): belongsTo, connects, isAdjacentTo, and more
For example, the "living room temperature sensor" has a belongsTo relationship to the "living room" node — all subsequent recommendations and orchestration are based on this graph.
Point-to-Room Mapping & Device Assignment​
With the spatial model in place, the Agent can do two critical things:
  • Device assignment to rooms: Determines which room a device belongs to (used as context for recommendations and orchestration)
  • Position coordinates: Pinpoints the device's exact location in space (x, y, z) for precise installation placement
The quality of spatial parsing directly determines downstream performance. The clearer the floor plan and the more complete the information, the better the recommendations and orchestration. We recommend uploading a complete floor plan when creating the project.
