Getting Started with the AIOT API
This article introduces the request and response elements of the Aqara AIOT HTTP API.
Request Elements​
This section describes the elements that make up an AIOT API request:
Every request to the Aqara AIOT API includes an HTTP method and a path. Depending on the specific endpoint, you may also need to specify request headers, authentication details, query parameters, or request body parameters.
The AIOT API reference documentation provides detailed information for each endpoint, including its HTTP method, path, required parameters, and request/response examples. It is recommended to first refer to the HTTP API List to quickly understand all available endpoints.
HTTP Methods​
The HTTP method of an endpoint defines the type of operation it performs on a given resource. Some common HTTP methods include GET, POST, DELETE, and PATCH. The API reference provides the HTTP methods for each endpoint.
For example, the List Spaces endpoint uses the GET method.
Currently, the Aqara AIOT API supports the following HTTP methods:
  • GET
  • POST
Endpoints​
Every endpoint has both a Base URL and a Path.
Base URL​
The Base URL of the AIOT API consists of the Open Platform server domain and a fixed prefix:
{host}/v4.0/open/api
The documented host values currently include:
RegionDomain
Chinese Mainlandhttps://open-cn.aqara.com
USAhttps://open-usa.aqara.com
Koreahttps://open-kr.aqara.com
Russiahttps://open-ru.aqara.com
Europehttps://open-ger.aqara.com
Singaporehttps://open-sg.aqara.com
Choose the appropriate server address based on your business region, application configuration, and deployment environment.
Path​
The AIOT API reference documentation provides the path for each endpoint. For example, the Query Device Details endpoint has the path /devices/definitions.
Request Headers​
Below are the common request headers used by the AIOT API.
ParameterTypeRequiredDescription
AccesstokenStringNoAccess token obtained via authorization. For details, read Cloud Development - Project Management - Authorization Management.
AppidStringYesApp ID assigned when creating an application on the Aqara Developer Platform. For details, read Cloud Development - Project Management - Create a Project.
KeyidStringYesKey ID assigned when creating an application on the Aqara Developer Platform. For details, read Cloud Development - Project Management - Create a Project.
NonceStringYesRandom string, which should be different for each request.
TimeStringYesRequest timestamp in milliseconds.
SignStringYesRequest signature. For details, read Signature Generation Rules.
LangEnumNoResponse language, supports zh and en, default is English.
Parameters​
Many API methods require or allow you to pass additional parameters with your request. Common AIOT API parameter types include header parameters, query parameters and request body parameters.
Header Parameters​
Header parameters are commonly used to pass authentication information, request context, or control request behavior. For details, read Request Headers.
Query Parameters​
Query parameters are commonly used for filtering, pagination, or specifying query targets. For example:
  • In List Spaces, you can use parentSpaceId, needChildren, and needParentSpaceSelf to control the returned portion of the space tree.
  • In List Devices, you can use spaceIds, state, deviceTypesList, pageNum, and pageSize for filtering and pagination.
  • In Query Device Details, you use deviceIds to specify target devices, and includeValues to determine whether current trait values should also be returned.
Request Body Parameters​
Request body parameters are commonly used to create resources, execute control operations, or read status in batches. For example:
Response Elements​
After you make a request, the API returns a response status code and a response body.
Response Status Code​
Every request returns an HTTP status code indicating whether it was successful. See the MDN HTTP Response Status Codes Documentation for more details.
Common AIOT API response codes include:
  • 200: Request was accepted successfully.
  • 400: Request parameter error.
  • 401: Unauthorized or authentication expired.
  • 403: No permission to access.
  • 404: Resource not found.
  • 429: Too many requests.
  • 500: Internal server error.
Response Body​
Most endpoints return a response body in JSON format.
All AIOT API responses usually contain the following base fields:
NameTypeDescription
typeStringMessage type.
versionStringAPI version. The current API version is v4.
msgIdStringMessage ID.
codeIntegerBusiness status code. 0 means success.
messageStringDescription of the request result.
On top of these fields, different endpoints return different data payloads. For example:
  • Space APIs return space nodes or space IDs.
  • Device query APIs return paginated device lists or detailed device definitions.
  • Trait query APIs return current trait values and their reported timestamps.
  • MQTT subscription APIs return client ID, MQTT host, port, credentials, and expiration information.
Note that for some control APIs, an HTTP status code of 200 does not necessarily mean every requested operation succeeded. For example:
These APIs may return a list of failed items in the response body. It is recommended to check the HTTP status code, the top-level code field, and whether data contains failure details.
