轨道灯 V1系列
产品信息​
基本信息​
参数说明
中文名称轨道灯 V1 系列
产品类型调光照明
通讯协议Zigbee、Thread、低功耗蓝牙
产品SKU信息​
灯具 SKU(Studio 版)​
产品图片官方市场名称产品型号产品ID商品条码SPU编码SKU编码
Track Spotlight V1 (Mountain Gray) Studio Edition轨道射灯 V1(远山灰)Studio版GDSD12LMA023546978350356655AL206AL206CNG01
Track Spotlight V1 (Moon White) Studio Edition轨道射灯 V1(皎月白)Studio版GDSD12LMA023556978350356792AL206AL206CNW06
Track Floodlight V1 (30cm Mountain Gray) Studio Edition轨道泛光灯 V1(30cm 远山灰)Studio版GDFGD13LMA023566978350356808AL206AL206CNG02
Track Floodlight V1 (30cm Moon White) Studio Edition轨道泛光灯 V1(30cm 皎月白)Studio版GDFGD13LMA023576978350356815AL206AL206CNW07
Track Floodlight V1 (60cm Mountain Gray) Studio Edition轨道泛光灯 V1(60cm 远山灰)Studio版GDFGD14LMA023586978350356822AL206AL206CNG03
Track Floodlight V1 (60cm Moon White) Studio Edition轨道泛光灯 V1(60cm 皎月白)Studio版GDFGD14LMA023596978350356839AL206AL206CNW08
Track Grille Light V1 (12-head Mountain Gray) Studio Edition轨道格栅灯 V1(12头 远山灰)Studio版GDGSD13LMA023606978350356846AL206AL206CNG04
Track Grille Light V1 (12-head Moon White) Studio Edition轨道格栅灯 V1(12头 皎月白)Studio版GDGSD13LMA023616978350356853AL206AL206CNW09
Track Grille Light V1 (24-head Mountain Gray) Studio Edition轨道格栅灯 V1(24头 远山灰)Studio版GDGSD14LMA023626978350356860AL206AL206CNG05
Track Grille Light V1 (24-head Moon White) Studio Edition轨道格栅灯 V1(24头 皎月白)Studio版GDGSD14LMA023636978350356877AL206AL206CNW10
电源 SKU​
产品图片产品名称产品型号SKU编码商品条码
轨道电源 V1(100W 远山灰)轨道电源 V1(100W 远山灰)GDDY11LMAL207CNG016975833355860
轨道电源 V1(100W 皎月白)轨道电源 V1(100W 皎月白)GDDY11LMAL207CNW016975833355877
轨道电源 V1(200W 远山灰)轨道电源 V1(200W 远山灰)GDDY12LMAL207CNG026975833355884
轨道电源 V1(200W 皎月白)轨道电源 V1(200W 皎月白)GDDY12LMAL207CNW026975833355891
轨道 SKU​
产品名称产品型号SKU编码商品条码
嵌入式轨道批灰款 V1(1m 远山灰)QRSGDPH11LMAL208CNG016975833355907
嵌入式轨道批灰款 V1(2m 远山灰)QRSGDPH12LMAL208CNG026975833355914
嵌入式轨道夹装款 V1(1m 远山灰)QRSGDJZ11LMAL208CNG036975833355921
嵌入式轨道夹装款 V1(2m 远山灰)QRSGDJZ12LMAL208CNG046975833355938
超薄明装轨道 V1(1m 远山灰)CBMZGD11LMAL208CNG056975833355945
超薄明装轨道 V1(1m 皎月白)CBMZGD11LMAL208CNW056975833355952
超薄明装轨道 V1(2m 远山灰)CBMZGD12LMAL208CNG066975833355969
超薄明装轨道 V1(2m 皎月白)CBMZGD12LMAL208CNW066975833355976
配件 SKU​
产品名称产品型号SKU编码商品条码
嵌入式输入导电模块 V1 (远山灰)QRSSRDDMK11LMAL209CNG016975833355983
嵌入式直线导电模块 V1 (远山灰)QRSZXDDMK11LMAL209CNG026975833355990
嵌入式转角导电模块 V1 (远山灰)QRSZJDDMK11LMAL209CNG036975833356003
嵌入式批灰款转角 V1 (远山灰)QRSPHZJ11LMAL209CNG046975833356010
嵌入式批灰款内转角 V1 (远山灰)QRSPHNZJ11LMAL209CNG056975833356027
嵌入式批灰款外转角 V1 (远山灰)QRSPHWZJ11LMAL209CNG066975833356034
嵌入式夹装款转角 V1 (远山灰)QRSJZZJ11LMAL209CNG076975833356041
嵌入式夹装款内转角 V1 (远山灰)QRSJZNZJ11LMAL209CNG086975833356058
嵌入式夹装款外转角 V1 (远山灰)QRSJZWZJ11LMAL209CNG096975833356065
明装直线连接模块 V1 (远山灰)MZZXLJMK11LMAL209CNG106975833356072
明装直线连接模块 V1 (皎月白)MZZXLJMK11LMAL209CNW106975833356089
明装转角 V1 (远山灰)MZZJ11LMAL209CNG116975833356096
明装转角 V1 (皎月白)MZZJ11LMAL209CNW116975833356102
明装外转角 V1 (远山灰)MZWZJ11LMAL209CNG126975833356119
明装外转角 V1 (皎月白)MZWZJ11LMAL209CNW126975833356126
明装内转角 V1 (远山灰)MZNZJ11LMAL209CNG136975833356133
明装内转角 V1 (皎月白)MZNZJ11LMAL209CNW136975833356140
IOT转接器 V1 (远山灰)IOTZJQ11LMAL209CNG146975833356157
IOT转接器 V1 (皎月白)IOTZJQ11LMAL209CNW146975833356164
产品卖点​
产品图​
轨道灯 V1 系列产品图 1 轨道灯 V1 系列产品图 2
产品卖点说明​
  • Aqara 银河系列轨道灯 V1,基于 Zigbee 通讯协议的全光谱双色温智能灯具
  • 系列包含轨道射灯、轨道格栅灯、轨道泛光灯多种类型,适配嵌入式轨道、超薄明装轨道等多种安装方式
  • 采用全光谱光源,射灯款显色指数 Ra 98,色温 2700K-6000K,还原真实色彩
  • 支持单灯调光调色温,也可多灯编组统一控制
  • 搭配 Aqara 网关后,可实现场景化控制,并与其他智能设备联动
  • 灯具采用 48V 安全低压供电,轨道电源将 220-240V 交流转换为 48V 直流恒压输出
  • 轨道射灯、格栅灯、泛光灯规格齐全,满足重点照明、洗墙、基础照明等多种商业及家居场景
产品参数​
基本参数​
参数说明
工作温度-20 ~ 45°C
工作湿度0% ~ 85% RH,无冷凝
色温2700K ~ 6000K
防护等级IP20
显色指数Ra 98
色容差SDCM < 5
调光深度百万分级
通讯协议Zigbee(出厂默认)、Thread、低功耗蓝牙
额定电压48V DC(灯具);220-240V~(轨道电源输入)
安装方式嵌入式轨道 / 超薄明装轨道安装,需配合 Aqara 专用配套导轨
执行标准GB 7000.201-2008、GB 7000.1-2015、GB/T 17743-2021
电气参数​
灯具参数​
产品名称额定功率额定电流额定电压光通量光束角
轨道射灯 V112W(1×12W/LED 模块)0.31A48V DC720lm24°
轨道泛光灯 V1(30cm)12W(120×0.5W/LED 模块)0.262A48V DC600lm100°
轨道泛光灯 V1(60cm)24W(216×0.5W/LED 模块)0.515A48V DC1200lm100°
轨道格栅灯 V1(12头)12W(12×1W/LED 模块)0.261A48V DC720lm24°
轨道格栅灯 V1(24头)24W(24×1W/LED 模块)0.516A48V DC1440lm24°
轨道电源电气参数​
产品型号产品名称额定输入额定输出功率因数
GDDY11LM轨道电源 V1(100W)220-240V~ 50/60Hz 0.5A48V DC Max 2.1A 100W 恒压模式0.9
GDDY12LM轨道电源 V1(200W)220-240V~ 50/60Hz 1A48V DC Max 4.2A 200W 恒压模式0.9
IOT 转接器电气参数​
产品型号额定功率额定输入额定输出
IOTZJQ11LM10W48V DC 0.29A5V DC 2.1A
光源参数​
产品尺寸​
产品名称尺寸
轨道射灯 V1146.8 × 110 × 50mm
轨道泛光灯 V1(30cm)300 × 22.6 × 35.4mm
轨道泛光灯 V1(60cm)600 × 22.6 × 35.4mm
轨道格栅灯 V1(12头)241 × 22.6 × 35.4mm
轨道格栅灯 V1(24头)474 × 22.6 × 35.4mm
轨道电源 V1(100W)240 × 22.6 × 36.4mm
轨道电源 V1(200W)300 × 22.6 × 36.4mm
产品概述​
Aqara 银河系列轨道灯 V1 是基于 Zigbee 通讯协议的全光谱双色温智能灯具,包含轨道射灯、轨道格栅灯、轨道泛光灯多种类型,并适用于嵌入式轨道、超薄明装轨道等多种安装方式。搭配 Aqara 网关之后,可对单灯或编组进行调光调色温控制,实现场景化控制,也可与其他智能设备联动。
灯具采用 48V 安全低压供电,由轨道电源将 220-240V 家用交流电转换为 48V 直流恒压输出。轨道射灯 V1 款显色指数 Ra 98,支持 2700K-6000K 双色温调节;格栅灯、泛光灯提供 30cm/60cm 或 12头/24头 多种规格,功率覆盖 12W 与 24W,可满足重点照明、洗墙、基础照明等不同场景需求。
  • 本设备需配合 Aqara 网关使用以获得最全功能支持,某些特定功能仅在 Aqara 生态 中支持。
  • 轨道电源、灯具、IOT 转接器等需按说明书规范安装,轨道及灯具电源触点需使用 Aqara 专用配套导轨系统。
销售信息​
参数说明
销售区域中国大陆
安装说明​
安装条件确认​
参数说明
安装工具螺丝刀、电钻(轨道固定用)、绝缘工具
安装环境室内使用,适用于嵌入式轨道或超薄明装轨道
安装位置干燥的天花板或墙面,注意避开热源
电源要求220-240V~ 50/60Hz 家用交流电(轨道电源输入)
安装注意事项​
警告
安装过程中涉及强电,需由专业人员依照电工规范和产品说明书进行安装。
  • 本产品仅限室内使用,请勿在潮湿环境或室外使用;
  • 注意防潮,请勿将水或其他液体泼洒到本产品上;
  • 请勿将本产品置放于靠近热源的地方;
  • 请勿尝试自行维修本产品,应由授权的专业人士进行此项工作;
  • 此灯具的光源是不可替换的;当光源到其寿终时,应替换整个灯具;
  • 此灯具的电源连接方式使用非标准导轨接合器,需配合专用的配套导轨使用,不能搭配使用其他制造商的导轨系统,否则会引起风险;
  • 此灯具是 III 类灯具,其控制装置只能是 SELV 的;
  • 安装时请先断开电源;
  • 将灯具电源触点部分插入已安装好的轨道槽内,确保接触可靠。
警告
不管在什么情况下灯具都不能被隔热材料或类似材料盖住。
常规安装说明​
  • 轨道安装:根据所选安装方式(嵌入式轨道 / 超薄明装轨道),将 Aqara 专用配套轨道固定于天花板或墙面;
  • 电源接入:将轨道电源接入 220-240V~ 家用交流电,输出端接入轨道;
  • 灯具安装:确认断电后,将灯具电源触点部分插入已安装好的轨道槽内;
  • 通电测试:合闸通电,确认灯具正常工作。
使用说明​
设备配网​
设备默认为 zigbee 协议入网,设备进入组网模式后,可将设备添加至Aqara Studio 或 Aqara Life App 中使用。
设备在未入网的状态下,上电时灯光呼吸两次,自动进入组网模式,组网时间为60s。如超过组网时间,则可以对设备进行重新上电,重新进入组网模式。
添加至 Aqara Studio​
根据设备当前所使用的协议,请参考以下对应文档完成添加:
协议文档
ZigbeeZigbee 设备集成指南
MatterMatter 设备集成指南
添加至 Aqara Life App​
  1. 下载 Aqara Life App(扫描说明书二维码,或在 Apple App Store / Google Play 搜索下载)。
  2. 打开 App,进入“主页”后点击右上角“+”进入“添加设备”页面,按照 App 提示完成添加。
固件升级​
您可以在 Aqara Studio 和 Aqara Life App 中更新设备固件到最新版本后开始使用。
设备重置 / 恢复出厂​
操作操作方式说明
设备重置连续通断电5次设备完成重置并进入组网状态
产品功能​
基础调光​
功能说明
开关支持基础的打开与关闭功能
亮度支持亮度调节
色温支持 2700K - 6000K 色温调节
情景功能​
功能说明
静态情景可将特定的白光色温及亮度值组合固化储存为专属情景,便于一键调用,支持复制、编辑、删除
动态序列支持多关键帧设置,生成流转的白光光效序列
配置项​
配置项说明
通讯协议Zigbee(出厂默认)、低功耗蓝牙
通电后状态支持设置断电记忆 / 来电开灯 / 来电关灯 / 反向 模式
开/关灯过渡时间支持配置开/关灯过渡时长
过渡曲线配置灯光以设置曲线效果过渡至目标状态
调光范围配置可设置灯的最大、最小亮度
查找设备点击后,设备出现闪烁或长鸣
指示灯说明​
指示灯状态功能说明
灯光呼吸两次并闪烁一次设备重置成功并进入组网状态
灯光慢呼吸一次后持续常亮组网成功
维护保养​
  • 定期用干燥软布擦拭产品表面,避免积尘影响使用效果;
  • 请勿使用化学溶剂清洁产品;
  • 长期不使用时,请断电存放于干燥环境。
支持网关信息​
本产品需配合 Aqara 网关使用以获得最全功能支持。本产品为 Zigbee 协议子设备,请使用已升级到最新版本的 Aqara 网关。
参数说明
Aqara 网关支持
  • GX300M
  • AX100M
  • GX100M
  • M300
  • M200
  • AXI00S
  • GR100S
自动化相关信息​
支持的自动化触发/结果​
条件类型支持的自动化条件
自动化条件打开
关闭
开着
关着
自动化结果打开
关闭
打开/关闭
设置亮度
设置亮度(不带开关)
设置色温
设置色温及亮度
亮度+
亮度-
设置为指定情景
产品保修​
保修说明​
本产品售后服务严格依据《中华人民共和国消费者权益保护法》、《中华人民共和国产品质量法》实行售后三包服务。
保修政策​
服务类型服务政策
退货自签收次日起 7 天内产品因质量原因退货
换货自签收次日起 15 天内产品因质量原因换货
维修自签收次日起 1 年内产品因质量原因维修
因运输过程中需使用包装箱保证产品运输安全,建议您自签收之日起至少保留外包装 30 天。
非保修条例​
  • 未经授权的维修、误用、碰撞、疏忽、滥用、进液、事故、改动、不正确的使用非本产品配件,或撕毁、涂改标签、防伪标记;
  • 已超过三包有效期;
  • 因不可抗力造成的损坏;
  • 不符合《产品性能故障表》所列性能故障的情况;
产品性能故障表​
  • 因结构或材料因素造成表面裂损
  • 产品功能异常
排障指引​
故障一:设备无法入网​
可能原因解决方案
  • 设备未处于组网状态
  • 设备不在网关有效通讯距离内
  • 手机蓝牙未开启
  • 网关版本过低,未支持新物模型
  1. 设备处于未入网状态时,上电即自动进入组网模式,无需连续开关电源进行重置;
  2. 确保设备在网关有效通讯距离内;
  3. 确保手机蓝牙已开启;
  4. 确认网关已升级到最新版本;
  5. 如添加失败,请将网关移近本产品,通电后再试。
故障二:设备无法配对/连接​
可能原因解决方案
  • 网关未升级到支持版本
  • 设备已绑定到其它网关
  1. 确认网关已升级到最新版本;
  2. 连续开关电源 5 次(停留在开灯状态)重置设备,重新配网;
  3. 如需重新绑定,先在 Aqara Life App 中移除设备,再重新添加。
故障三:灯具不亮/光色异常​
可能原因解决方案
  • 电源连接异常
  • 轨道电源未正常输出 48V
  • 灯具与轨道触点接触不良
  1. 检查 220-240V 交流电源是否正常接入轨道电源;
  2. 检查轨道电源输出及轨道接线是否正确;
  3. 确认灯具电源触点与轨道可靠接触;
  4. 如长时间使用后失效,等待灯具冷却后重新上电。
特定说明​
微功率设备使用说明​
  • 本产品使用的 Zigbee 技术符合“微功率短距离无线电发射设备目录和技术要求”中通用微功率设备 F 类设备的技术要求,用于数据传输应用。采用一体化天线,控制、调整及开关等使用方法请参考产品说明书中相关内容;
  • 不得擅自改变使用场景或使用条件、扩大发射频率范围、加大发射功率(包括额外加装射频功率放大器),不得擅自更改发射天线;
  • 不得对其他合法的无线电台(站)产生有害干扰,也不得提出免受有害干扰保护;
  • 应当承受辐射射频能量的工业、科学及医疗(ISM)应用设备的干扰或其他合法的无线电台(站)干扰;
  • 如对其他合法的无线电台(站)产生有害干扰时,应立即停止使用,并采取措施消除干扰后方可继续使用;
  • 在航空器内和依据法律法规、国家有关规定、标准划设的射电天文台、气象雷达站、卫星地球站(含测控、测距、接收、导航站)等军民用无线电台(站)、机场等的电磁环境保护区域内使用微功率设备,应当遵守电磁环境保护及相关行业主管部门的规定;
  • 禁止在以机场跑道中心点为圆心、半径 5000 米的区域内使用各类模型遥控器;
  • 微功率设备使用温度为 -20°C ~ +45°C,供电为 48V DC。
常见问题​
轨道灯 V1 系列包含哪些灯具类型?​
轨道灯 V1 系列包含轨道射灯、轨道格栅灯、轨道泛光灯三种类型,另配套 100W / 200W 轨道电源及 IOT 转接器。
轨道灯 V1 支持哪些安装方式?​
支持嵌入式轨道和超薄明装轨道两种安装方式。轨道电源接入 220-240V 交流电后转换为 48V 直流恒压输出,灯具通过电源触点插入轨道槽内即可取电。
轨道灯 V1 必须使用 Aqara 专用轨道吗?​
是的。此灯具的电源连接方式使用非标准导轨接合器,需配合专用的配套导轨使用,不能搭配使用其他制造商的导轨系统,否则会引起风险。
如何进入组网模式?​
设备处于未入网状态时,上电即自动进入组网状态。
设备如何重置?​
连续开关电源 5 次,停留在开灯状态,待灯光呼吸两次并闪烁一次后,设备即完成重置并进入组网状态。
如何验证设备与网关之间的有效通讯距离?​
使用电源开关连续开关电源 3 次,网关发出提示音,表明设备和网关之间可以有效通讯。
