脚本支持的单位名称与符号
以下列表来自 Studio 运行时加载的 defaults/units.xml。在 JavaScript 脚本的数值型通用功能点中,unit / units 建议填写下表中的单位名称。Studio 会将单位名称解析为对应单位,并在前端展示注册的符号。系统也可以匹配已注册的单位符号,但为避免 °C、% 等字符书写差异影响识别,脚本示例统一使用单位名称。
常用单位名称:温度使用 celsius(显示 °C),湿度使用 percent(显示 %),电压使用 volt(显示 V),电流使用 ampere(显示 A),当前功率使用 watt(显示 W),累计电量使用 kilowatt hour(显示 kWh)。
| 量纲 | 单位名称 | 支持的单位符号 |
| other | - | -, null |
| other | percent | % |
| other | decibel | db |
| other | power factor | pf |
| other | pH | pH |
| other | percent relative humidity | %RH, percent-relative-humidity |
| other | absolute humidity | gm-3 |
| other | grams of water per kilogram dry air | gH2O/kgAir |
| other | volts per degree kelvin | V/K |
| other | degree days celsius | °daysC |
| other | degree days fahrenheit | °daysF |
| other | percent obscuration per foot | %obsc/ft, OBS%/FT |
| other | percent obscuration per meter | %obsc/m |
| other | smoke density per meter | dB/m |
| other | psi per degree fahrenheit | psi/°F, psi/℉ |
| other | square meters per newton | m²/N |
| other | watts per square meter degree kelvin | W/m²K |
| other | ampere square meter | Am² |
| other | db milliVolt | dBmV |
| other | db milliWatt | dBm |
| other | db microVolt | dBuV |
| other | db volt | dBV |
| other | db ampere | dBA |
| other | minutes per degree kelvin | min/K |
| other | grams per milliliter | g/mL |
| other | grams per liter | g/L |
| other | milligrams per liter | mg/L |
| other | micrograms per liter | ug/L |
| other | per mile | /mile |
| other | milliliters of water | mL H2O |
| other | moles percent | moles% |
| other | volt squared hours | V²hr |
| other | ampere squared hours | A²hr |
| other | gas concentration | %LEL |
| other | signed count | pulses |
| other | activity | s⁻¹ |
| other | mol | mol |
| other | counter pulses | counter pulses |
| other | fan stage | fan stage |
| other | brightness and color temperature transition | % K s |
| other | date | yyyy-mm-dd |
| other | date with time | yr/mth/day hr:min:sec |
| acceleration | meters per second squared | m/s², ms⁻² |
| angular acceleration | radians per second squared | rad/s² |
| angular acceleration | Acceleration angular | rad s⁻² |
| angular momentum | joule second | J-s, Js |
| angular momentum | momentum | N/s |
| angular velocity | radians per second | rad/s |
| angular velocity | revolutions per minute | rpm |
| angular velocity | revolutions per second | rps |
| area | square meter | m² |
| area | square millimeter | mm² |
| area | square centimeter | cm² |
| area | square kilometer | km² |
| area | square inch | in² |
| area | square foot | ft² |
| area | square yard | yd² |
| area | square mile | mile² |
| area | acre | acre |
| capacitance | farad | F |
| concentration | parts per unit | ppu |
| concentration | parts per million | ppm |
| concentration | parts per billion | ppb |
| concentration | milligrams per kilogram | mg/kg |
| concentration | grams per kilogram | g/kg |
| concentration | grams per gram | g/g |
| concentration | kilograms per kilogram | kg/kg |
| concentration | milligrams per gram | mg/g |
| currency | dollar | $ |
| currency | euro | € |
| currency | franc | ₣ |
| currency | lira | ₤ |
| currency | peseta | ₧ |
| currency | pounds | £ |
| currency | rupee | ₨ |
| currency | won | ₩ |
| currency | yen | ¥ |
| currency | currency1 | c1 |
| currency | currency2 | c2 |
| currency | currency3 | c3 |
| currency | currency4 | c4 |
| currency | currency5 | c5 |
| currency | currency6 | c6 |
| currency | currency7 | c7 |
| currency | currency8 | c8 |
| currency | currency9 | c9 |
| currency | currency10 | c10 |
| density | kilograms per cubic meter | kg/m³, kg m⁻³ |
| density | grams per cubic meter | g/m³ |
| density | milligrams per cubic meter | mg/m³ |
| density | micrograms per cubic meter | ug/m³, µg/m³ |
| density | nanograms per cubic meter | ng/m³ |
| density | grams per cubic centimeter | g/cm³ |
| dynamic viscosity | pascal second | Pas |
| electric charge | coulomb | C |
| electric charge | ampere seconds | As |
| electric charge | ampere hour | Ah |
| electric charge | milliampere hour | mAh |
| electric conductance | siemens | S |
| electric conductance | millisiemens | mS |
| electric conductance | microsiemens | uS |
| electric current | ampere | A |
| electric current | milliampere | mA |
| electric current density | amperes per square meter | A/m², A m⁻², A m² |
| electric field strength | volts per meter | V/m, V·m⁻¹ |
| electric potential | volt | V |
| electric potential | millivolt | mV |
| electric potential | kilovolt | kV |
| electric potential | megavolt | MV |
| electric resistance | ohm | Ω, Ω⁻¹ |
| electric resistance | kilohm | kΩ |
| electric resistance | megohm | MΩ |
| electric resistance | milliohm | mΩ |
| electrical conductivity | siemens per meter | S/m |
| electrical resistivity | ohm meter | Ω-m, Ω·m, Ω⁻¹m⁻¹, Ωm |
| electrical resistivity | ohm meter squared per meter | Ωm²/m |
| energy | joule | J |
| energy | kilojoule | kJ |
| energy | gigajoule | GJ |
| energy | watt hour | W-hr, W·h, Wh |
| energy | kilowatt hour | kW-hr, kW·h, kWh |
| energy | megawatt hour | MW-hr, MW·h |
| energy | btu | BTU |
| energy | kilobtu | kBTU |
| energy | megabtu | MBTU |
| energy | horsepower hour | hp-hr |
| energy | calorie | cal |
| energy | therm | therm |
| energy | decatherms | Dth |
| energy | tons refrigeration hour | tR-hr |
| energy | megajoule | MJ |
| energy | newton meter | N-m, Nm |
| energy | activation energy | J/mol |
| apparent energy | volt ampere hour | VA-hr, VAh |
| apparent energy | kilovolt ampere hour | kVA-hr, kVAh |
| apparent energy | megavolt ampere hour | MVA-hr |
| reactive energy | volt ampere reactive hour | var-hr, VARh |
| reactive energy | kilovolt ampere reactive hour | kvar-hr, kVARh |
| reactive energy | megavolt ampere reactive hour | Mvar-hr |
| reactive energy | watt reactive hour | Wr-hr |
| reactive energy | kilowatt reactive hour | kWr-hr |
| reactive energy | megawatt reactive hour | MWr-hr, MWrh, MWh |
| energy consumption | joules per square meter | J/m² |
| energy consumption | watt hours per square meter | W-hr/m² |
| energy consumption | watt hours per square foot | W-hr/ft² |
| energy consumption | kilowatt hours per square meter | kW-hr/m² |
| energy consumption | kilowatt hours per square foot | kW-hr/ft² |
| energy consumption | megawatt hours per square meter | MW-hr/m² |
| energy consumption | megawatt hours per square foot | MW-hr/ft² |
| energy consumption | megajoules per square meter | MJ/m² |
| energy consumption | megajoules per square foot | MJ/ft² |
| energy consumption | newtons per meter | N/m |
| energy consumption | btus per square foot | BTU/ft² |
| energy consumption | kilobtus per square foot | kBTU/ft² |
| enthalpy | joules per kilogram | J/kg |
| enthalpy | joules per gram | J/g |
| enthalpy | btu per pound | BTU/lb |
| enthalpy | calorie per gram | cal/g |
| enthalpy | kilojoule per kilogram | kJ/kg |
| enthalpy differential | delta kilojoules per kilogram | ΔkJ/kg, deltakJ/kg |
| enthalpy differential | delta btus per pound | ΔBTU/lb, deltaBTU/lb |
| entropy | joules per degree kelvin | J/°K, J/K |
| entropy | kilojoules per degree kelvin | kJ/°K, kJ/K |
| entropy | megajoules per degree kelvin | MJ/°K, MJ/K |
| fuel efficiency | joules per cubic meter | J/m³ |
| fuel efficiency | watt hour per cubic meter | W-hr/m³ |
| force | newton | N |
| force | pound force | lbf |
| frequency | hertz | Hz |
| frequency | kilohertz | kHz |
| frequency | cycles per hour | cph |
| frequency | cycles per minute | cpm |
| frequency | megahertz | MHz |
| frequency | per minute | /min |
| frequency | per second | /s |
| frequency | per hour | /hr |
| frequency | percent per second | %/s |
| grammage | kilograms per square meter | kg/m² |
| grammage | grams per square meter | g/m² |
| heating rate | degrees kelvin per second | K/s |
| heating rate | degrees celsius per hour | °C/hr, ℃/hr |
| heating rate | degrees celsius per minute | °C/min, ℃/min |
| heating rate | degrees fahrenheit per hour | °F/hr, ℉/hr |
| heating rate | degrees fahrenheit per minute | °F/min, ℉/min |
| heating rate | degrees kelvin per hour | K/hr |
| heating rate | degrees kelvin per minute | K/min |
| illuminance | lux | lx |
| illuminance | kilolux | klx |
| illuminance | lumen per square meter | lum/m² |
| illuminance | lumen per square foot | lum/ft² |
| illuminance | candelas per square meter | cd/m², C m⁻², cd m⁻² |
| illuminance | footcandles | fc |
| illuminance | Charge density (volume) | C m⁻³ |
| inductance | henry | H |
| information | bit | b |
| information | byte | B |
| information | kilobit | Kb |
| information | kilobyte | KB |
| information | megabit | Mb |
| information | megabyte | MB |
| information | gigabit | Gb |
| information | gigabyte | GB |
| information | terabit | Tb |
| information | terabyte | TB |
| information speed | bits per second | b/s |
| information speed | bytes per second | B/s |
| information speed | kilobits per second | Kb/s |
| information speed | kilobytes per second | KB/s |
| information speed | megabits per second | Mb/s |
| information speed | megabytes per second | MB/s |
| information speed | gigabits per second | Gb/s |
| information speed | gigabytes per second | GB/s |
| information speed | terabits per second | Tb/s |
| information speed | terabytes per second | TB/s |
| irradiance | watts per square meter | W/m², W m⁻² |
| irradiance | kilowatts per square meter | kW/m² |
| irradiance | megawatts per square meter | MW/m² |
| irradiance | watts per square foot | W/ft² |
| irradiance | kilowatts per square foot | kW/ft² |
| irradiance | megawatts per square foot | MW/ft² |
| irradiance | btus per hour per square foot | BTU/hr/ft² |
| irradiance | kilobtus per hour per square foot | kBTU/hr/ft² |
| length | meter | m |
| length | micrometer | um |
| length | millimeter | mm |
| length | centimeter | cm |
| length | kilometer | km |
| length | inch | in |
| length | foot | ft |
| length | yard | yd |
| length | mile | mile |
| luminescence | candela | cd |
| luminescence | footcandle | ftcd |
| luminescence | candle power | cp |
| luminous flux | lumen | lm |
| magnetic field strength | amperes per meter | A/m |
| magnetic flux | weber | Wb |
| magnetic flux density | tesla | T |
| mass | kilogram | kg |
| mass | milligram | mg |
| mass | gram | g |
| mass | ounce | oz |
| mass | pound | lb |
| mass | metric ton | ton |
| mass | short ton | t |
| mass flow | kilograms per second | kg/s |
| mass flow | kilograms per minute | kg/min |
| mass flow | kilograms per hour | kg/hr |
| mass flow | pounds per minute | lb/min |
| mass flow | pounds per hour | lb/hr |
| mass flow | pounds per second | lb/s |
| mass flow | pounds mass per day | lb/day |
| mass flow | grams per second | g/s |
| mass flow | grams per minute | g/min |
| mass flow | metric tons per hour | ton/hr |
| momentum | newton second | N-s |
| plane angle | radian | rad |
| plane angle | degrees angular | °, deg |
| plane angle | degrees phase | degPh |
| power | watt | W |
| power | milliwatt | mW |
| power | kilowatt | kW |
| power | megawatt | MW |
| power | gigawatt | GW |
| power | btus per hour | BTU/hr |
| power | horsepower | hp |
| power | foot pounds per second | ft-lbs/sec |
| power | tons refrigeration | tR |
| power | kilobtus per hour | kBTU/hr |
| power | joules per hour | J/hr |
| power | kilojoules per hour | kJ/hr |
| apparent power | volt ampere | VA |
| apparent power | kilovolt ampere | kVA |
| apparent power | megavolt ampere | MVA |
| reactive power | volt ampere reactive | var |
| reactive power | kilovolt ampere reactive | kvar |
| reactive power | megavolt ampere reactive | Mvar |
| pressure | pascal | Pa |
| pressure | kilopascals | kPa |
| pressure | bar | bar |
| pressure | atmosphere | atm |
| pressure | pounds per square inch | psi |
| pressure | pounds per square inch gauge | psig |
| pressure | centimeters of water | cm/wc |
| pressure | inches of water | in/wc |
| pressure | millimeters of mercury | mm Hg |
| pressure | centimeters of mercury | cm Hg |
| pressure | inches of mercury | in Hg |
| pressure | hectopascal | hPa |
| pressure | millibar | mbar |
| pressure | torr | torr |
| pressure differential | pascal differential | ΔPa, deltaPa |
| pressure differential | kilopascal differential | ΔkPa, deltakPa |
| pressure differential | bar differential | Δbar, deltabar |
| pressure differential | atmosphere differential | Δatm, deltaatm |
| pressure differential | pounds per square inch differential | Δpsi, deltapsi |
| pressure differential | centimeters of water differential | Δcm/wc, deltacm/wc |
| pressure differential | inches of water differential | Δin/wc, deltain/wc |
| pressure differential | millimeters of mercury differential | Δmm Hg, deltamm Hg |
| pressure differential | centimeters of mercury differential | Δcm Hg, deltacm Hg |
| pressure differential | inches of mercury differential | Δin Hg, deltain Hg |
| pressure differential | hectopascal differential | ΔhPa, deltahPa |
| pressure differential | millibar differential | Δmbar, deltambar |
| pressure differential | torr differential | Δtorr, deltatorr |
| radioactivity | becquerel | Bq |
| radioactivity | kilobecquerel | kBq |
| radioactivity | megabecquerel | MBq |
| radiation dose | gray | Gy |
| radiation dose | milligray | mGy |
| radiation dose | microgray | uGy |
| radiation dose | sievert | Sv |
| radiation dose | millisievert | mSv |
| radiation dose | microsievert | uSv |
| radiation dose | millirems | mrem |
| radiation dose rate | microsievert per hour | uSv/hr |
| radiation dose rate | millirems per hour | mrem/hr |
| solid angle | steradian | sr |
| specific energy | joules per kilogram se | J/kg |
| specific energy | joules per kilogram dry air | J/kg |
| specific energy | btus per pound | btu/lb |
| specific energy | btus per pound dry air | btu/lb |
| specific energy | kilojoules per kilogram | kJ/kg |
| specific energy | kilojoules per kilogram dry air | kJ/kg |
| specific energy | megajoules per kilogram dry air | MJ/kg |
| specific entropy | joules per kilogram degree kelvin | J/kg°K, J/kg·K |
| surface tension | newtons per meter st | N/m |
| temperature | fahrenheit | °F, ℉ |
| temperature | celsius | °C, ℃, degrees-celsius |
| temperature | kelvin | K |
| temperature | millikelvin | mK |
| temperature | temperature-gradient | K/h |
| temperature | kelvin-percent | K/% |
| colorTemperature | mirek | mirek, mired |
| colorTemperature | color temperature kelvin | K |
| temperature differential | fahrenheit degrees | Δ°F, Δ℉, delta℉ |
| temperature differential | celsius degrees | Δ°C, Δ℃, delta℃ |
| temperature differential | kelvin degrees | Δ°K, ΔK, deltaK |
| thermal conductivity | watts per meter degree kelvin | W/m°K, W/m·K, W/m K⁻¹ |
| time | nanosecond | ns |
| time | microsecond | us |
| time | millisecond | ms |
| time | hundredths second | cs |
| time | tenths second | ds |
| time | second | s |
| time | minute | min |
| time | hour | hr, h |
| time | day | day |
| time | week | wk |
| time | julian month | mo |
| time | year | yr |
| turbidity | nephelometric turbidity units | ntu |
| turbidity | formazin nephelometric unit | fnu |
| velocity | meters per second | m/s |
| velocity | kilometers per second | km/s |
| velocity | kilometers per hour | km/hr, km/h |
| velocity | miles per hour | mph |
| velocity | feet per second | ft/s |
| velocity | feet per minute | ft/min |
| velocity | millimeters per second | mm/s |
| velocity | millimeters per minute | mm/min |
| velocity | meters per minute | m/min |
| velocity | meters per hour | m/hr |
| volume | cubic meter | m³ |
| volume | cubic millimeter | mm³ |
| volume | cubic centimeter | cm³ |
| volume | milliliter | mL |
| volume | liter | L |
| volume | kiloliter | kL |
| volume | cubic inch | in³ |
| volume | cubic foot | ft³ |
| volume | cubic yard | yd³ |
| volume | gallon | gal |
| volume | quart | qt |
| volume | pint | pt |
| volume | fluid ounce | fl oz |
| volume | imperial gallon | galUK, gal(UK) |
| volumetric flow | cubic meters per second | m³/s |
| volumetric flow | cubic meters per minute | m³/min |
| volumetric flow | cubic meters per hour | m³/hr, m³/h, m3/h |
| volumetric flow | cubic meters per day | m³/day |
| volumetric flow | milliliters per second | mL/s |
| volumetric flow | milliliters per minute | mL/min |
| volumetric flow | milliliters per hour | mL/hr |
| volumetric flow | liters per second | L/s |
| volumetric flow | liters per minute | L/min |
| volumetric flow | liters per hour | L/hr, l/h |
| volumetric flow | cubic feet per second | cfs, ft³/s |
| volumetric flow | cubic feet per minute | cfm, ft³/min |
| volumetric flow | cubic feet per hour | cfh, ft³/hr |
| volumetric flow | cubic feet per day | cfd, ft³/day |
| volumetric flow | standard cubic feet per day | std cfd, std ft³/day |
| volumetric flow | million standard cubic feet per minute | std m cfm, std M ft³/min |
| volumetric flow | million standard cubic feet per day | std m cfd, std M ft³/day |
| volumetric flow | thousand cubic feet per day | th cfd, th ft³/day |
| volumetric flow | thousand standard cubic feet per day | th std cfd, th std ft³/day |
| volumetric flow | imperial gallons per second | galUK/s, gal(UK)/s |
| volumetric flow | imperial gallons per minute | galUK/min, gal(UK)/min |
| volumetric flow | imperial gallons per hour | galUK/hr, gal(UK)/hr |
| volumetric flow | gallons per second | gal/s |
| volumetric flow | gallons per minute | gal/min |
| volumetric flow | gallons per hour | gal/hr |
| volumetric flow | rain amount | l/m² |
