Unit Names and Symbols Supported by Scripts
The following list comes from the defaults/units.xml file loaded by the Studio runtime. For general numeric points in JavaScript scripts, configure unit / units with one of the unit names below. Studio resolves the unit name and displays the registered symbol in the UI. The system can also match registered unit symbols, but the examples use unit names to avoid formatting differences in characters such as °C and %.
Common unit names: use celsius (displayed as °C) for temperature, percent (%) for humidity, volt (V) for voltage, ampere (A) for current, watt (W) for current power, and kilowatt hour (kWh) for accumulated energy.
QuantityUnit NameSupported Unit Symbols
other--, null
otherpercent%
otherdecibeldb
otherpower factorpf
otherpHpH
otherpercent relative humidity%RH, percent-relative-humidity
otherabsolute humiditygm-3
othergrams of water per kilogram dry airgH2O/kgAir
othervolts per degree kelvinV/K
otherdegree days celsius°daysC
otherdegree days fahrenheit°daysF
otherpercent obscuration per foot%obsc/ft, OBS%/FT
otherpercent obscuration per meter%obsc/m
othersmoke density per meterdB/m
otherpsi per degree fahrenheitpsi/°F, psi/℉
othersquare meters per newtonm²/N
otherwatts per square meter degree kelvinW/m²K
otherampere square meterAm²
otherdb milliVoltdBmV
otherdb milliWattdBm
otherdb microVoltdBuV
otherdb voltdBV
otherdb amperedBA
otherminutes per degree kelvinmin/K
othergrams per milliliterg/mL
othergrams per literg/L
othermilligrams per litermg/L
othermicrograms per literug/L
otherper mile/mile
othermilliliters of watermL H2O
othermoles percentmoles%
othervolt squared hoursV²hr
otherampere squared hoursA²hr
othergas concentration%LEL
othersigned countpulses
otheractivitys⁻¹
othermolmol
othercounter pulsescounter pulses
otherfan stagefan stage
otherbrightness and color temperature transition% K s
otherdateyyyy-mm-dd
otherdate with timeyr/mth/day hr:min:sec
accelerationmeters per second squaredm/s², ms⁻²
angular accelerationradians per second squaredrad/s²
angular accelerationAcceleration angularrad s⁻²
angular momentumjoule secondJ-s, Js
angular momentummomentumN/s
angular velocityradians per secondrad/s
angular velocityrevolutions per minuterpm
angular velocityrevolutions per secondrps
areasquare meterm²
areasquare millimetermm²
areasquare centimetercm²
areasquare kilometerkm²
areasquare inchin²
areasquare footft²
areasquare yardyd²
areasquare milemile²
areaacreacre
capacitancefaradF
concentrationparts per unitppu
concentrationparts per millionppm
concentrationparts per billionppb
concentrationmilligrams per kilogrammg/kg
concentrationgrams per kilogramg/kg
concentrationgrams per gramg/g
concentrationkilograms per kilogramkg/kg
concentrationmilligrams per grammg/g
currencydollar$
currencyeuro€
currencyfranc₣
currencylira₤
currencypeseta₧
currencypounds£
currencyrupee₨
currencywon₩
currencyyen¥
currencycurrency1c1
currencycurrency2c2
currencycurrency3c3
currencycurrency4c4
currencycurrency5c5
currencycurrency6c6
currencycurrency7c7
currencycurrency8c8
currencycurrency9c9
currencycurrency10c10
densitykilograms per cubic meterkg/m³, kg m⁻³
densitygrams per cubic meterg/m³
densitymilligrams per cubic metermg/m³
densitymicrograms per cubic meterug/m³, µg/m³
densitynanograms per cubic meterng/m³
densitygrams per cubic centimeterg/cm³
dynamic viscositypascal secondPas
electric chargecoulombC
electric chargeampere secondsAs
electric chargeampere hourAh
electric chargemilliampere hourmAh
electric conductancesiemensS
electric conductancemillisiemensmS
electric conductancemicrosiemensuS
electric currentampereA
electric currentmilliamperemA
electric current densityamperes per square meterA/m², A m⁻², A m²
electric field strengthvolts per meterV/m, V·m⁻¹
electric potentialvoltV
electric potentialmillivoltmV
electric potentialkilovoltkV
electric potentialmegavoltMV
electric resistanceohmΩ, Ω⁻¹
electric resistancekilohmkΩ
electric resistancemegohmMΩ
electric resistancemilliohmmΩ
electrical conductivitysiemens per meterS/m
electrical resistivityohm meterΩ-m, Ω·m, Ω⁻¹m⁻¹, Ωm
electrical resistivityohm meter squared per meterΩm²/m
energyjouleJ
energykilojoulekJ
energygigajouleGJ
energywatt hourW-hr, W·h, Wh
energykilowatt hourkW-hr, kW·h, kWh
energymegawatt hourMW-hr, MW·h
energybtuBTU
energykilobtukBTU
energymegabtuMBTU
energyhorsepower hourhp-hr
energycaloriecal
energythermtherm
energydecathermsDth
energytons refrigeration hourtR-hr
energymegajouleMJ
energynewton meterN-m, Nm
energyactivation energyJ/mol
apparent energyvolt ampere hourVA-hr, VAh
apparent energykilovolt ampere hourkVA-hr, kVAh
apparent energymegavolt ampere hourMVA-hr
reactive energyvolt ampere reactive hourvar-hr, VARh
reactive energykilovolt ampere reactive hourkvar-hr, kVARh
reactive energymegavolt ampere reactive hourMvar-hr
reactive energywatt reactive hourWr-hr
reactive energykilowatt reactive hourkWr-hr
reactive energymegawatt reactive hourMWr-hr, MWrh, MWh
energy consumptionjoules per square meterJ/m²
energy consumptionwatt hours per square meterW-hr/m²
energy consumptionwatt hours per square footW-hr/ft²
energy consumptionkilowatt hours per square meterkW-hr/m²
energy consumptionkilowatt hours per square footkW-hr/ft²
energy consumptionmegawatt hours per square meterMW-hr/m²
energy consumptionmegawatt hours per square footMW-hr/ft²
energy consumptionmegajoules per square meterMJ/m²
energy consumptionmegajoules per square footMJ/ft²
energy consumptionnewtons per meterN/m
energy consumptionbtus per square footBTU/ft²
energy consumptionkilobtus per square footkBTU/ft²
enthalpyjoules per kilogramJ/kg
enthalpyjoules per gramJ/g
enthalpybtu per poundBTU/lb
enthalpycalorie per gramcal/g
enthalpykilojoule per kilogramkJ/kg
enthalpy differentialdelta kilojoules per kilogramΔkJ/kg, deltakJ/kg
enthalpy differentialdelta btus per poundΔBTU/lb, deltaBTU/lb
entropyjoules per degree kelvinJ/°K, J/K
entropykilojoules per degree kelvinkJ/°K, kJ/K
entropymegajoules per degree kelvinMJ/°K, MJ/K
fuel efficiencyjoules per cubic meterJ/m³
fuel efficiencywatt hour per cubic meterW-hr/m³
forcenewtonN
forcepound forcelbf
frequencyhertzHz
frequencykilohertzkHz
frequencycycles per hourcph
frequencycycles per minutecpm
frequencymegahertzMHz
frequencyper minute/min
frequencyper second/s
frequencyper hour/hr
frequencypercent per second%/s
grammagekilograms per square meterkg/m²
grammagegrams per square meterg/m²
heating ratedegrees kelvin per secondK/s
heating ratedegrees celsius per hour°C/hr, ℃/hr
heating ratedegrees celsius per minute°C/min, ℃/min
heating ratedegrees fahrenheit per hour°F/hr, ℉/hr
heating ratedegrees fahrenheit per minute°F/min, ℉/min
heating ratedegrees kelvin per hourK/hr
heating ratedegrees kelvin per minuteK/min
illuminanceluxlx
illuminancekiloluxklx
illuminancelumen per square meterlum/m²
illuminancelumen per square footlum/ft²
illuminancecandelas per square metercd/m², C m⁻², cd m⁻²
illuminancefootcandlesfc
illuminanceCharge density (volume)C m⁻³
inductancehenryH
informationbitb
informationbyteB
informationkilobitKb
informationkilobyteKB
informationmegabitMb
informationmegabyteMB
informationgigabitGb
informationgigabyteGB
informationterabitTb
informationterabyteTB
information speedbits per secondb/s
information speedbytes per secondB/s
information speedkilobits per secondKb/s
information speedkilobytes per secondKB/s
information speedmegabits per secondMb/s
information speedmegabytes per secondMB/s
information speedgigabits per secondGb/s
information speedgigabytes per secondGB/s
information speedterabits per secondTb/s
information speedterabytes per secondTB/s
irradiancewatts per square meterW/m², W m⁻²
irradiancekilowatts per square meterkW/m²
irradiancemegawatts per square meterMW/m²
irradiancewatts per square footW/ft²
irradiancekilowatts per square footkW/ft²
irradiancemegawatts per square footMW/ft²
irradiancebtus per hour per square footBTU/hr/ft²
irradiancekilobtus per hour per square footkBTU/hr/ft²
lengthmeterm
lengthmicrometerum
lengthmillimetermm
lengthcentimetercm
lengthkilometerkm
lengthinchin
lengthfootft
lengthyardyd
lengthmilemile
luminescencecandelacd
luminescencefootcandleftcd
luminescencecandle powercp
luminous fluxlumenlm
magnetic field strengthamperes per meterA/m
magnetic fluxweberWb
magnetic flux densityteslaT
masskilogramkg
massmilligrammg
massgramg
massounceoz
masspoundlb
massmetric tonton
massshort tont
mass flowkilograms per secondkg/s
mass flowkilograms per minutekg/min
mass flowkilograms per hourkg/hr
mass flowpounds per minutelb/min
mass flowpounds per hourlb/hr
mass flowpounds per secondlb/s
mass flowpounds mass per daylb/day
mass flowgrams per secondg/s
mass flowgrams per minuteg/min
mass flowmetric tons per hourton/hr
momentumnewton secondN-s
plane angleradianrad
plane angledegrees angular°, deg
plane angledegrees phasedegPh
powerwattW
powermilliwattmW
powerkilowattkW
powermegawattMW
powergigawattGW
powerbtus per hourBTU/hr
powerhorsepowerhp
powerfoot pounds per secondft-lbs/sec
powertons refrigerationtR
powerkilobtus per hourkBTU/hr
powerjoules per hourJ/hr
powerkilojoules per hourkJ/hr
apparent powervolt ampereVA
apparent powerkilovolt amperekVA
apparent powermegavolt ampereMVA
reactive powervolt ampere reactivevar
reactive powerkilovolt ampere reactivekvar
reactive powermegavolt ampere reactiveMvar
pressurepascalPa
pressurekilopascalskPa
pressurebarbar
pressureatmosphereatm
pressurepounds per square inchpsi
pressurepounds per square inch gaugepsig
pressurecentimeters of watercm/wc
pressureinches of waterin/wc
pressuremillimeters of mercurymm Hg
pressurecentimeters of mercurycm Hg
pressureinches of mercuryin Hg
pressurehectopascalhPa
pressuremillibarmbar
pressuretorrtorr
pressure differentialpascal differentialΔPa, deltaPa
pressure differentialkilopascal differentialΔkPa, deltakPa
pressure differentialbar differentialΔbar, deltabar
pressure differentialatmosphere differentialΔatm, deltaatm
pressure differentialpounds per square inch differentialΔpsi, deltapsi
pressure differentialcentimeters of water differentialΔcm/wc, deltacm/wc
pressure differentialinches of water differentialΔin/wc, deltain/wc
pressure differentialmillimeters of mercury differentialΔmm Hg, deltamm Hg
pressure differentialcentimeters of mercury differentialΔcm Hg, deltacm Hg
pressure differentialinches of mercury differentialΔin Hg, deltain Hg
pressure differentialhectopascal differentialΔhPa, deltahPa
pressure differentialmillibar differentialΔmbar, deltambar
pressure differentialtorr differentialΔtorr, deltatorr
radioactivitybecquerelBq
radioactivitykilobecquerelkBq
radioactivitymegabecquerelMBq
radiation dosegrayGy
radiation dosemilligraymGy
radiation dosemicrograyuGy
radiation dosesievertSv
radiation dosemillisievertmSv
radiation dosemicrosievertuSv
radiation dosemilliremsmrem
radiation dose ratemicrosievert per houruSv/hr
radiation dose ratemillirems per hourmrem/hr
solid anglesteradiansr
specific energyjoules per kilogram seJ/kg
specific energyjoules per kilogram dry airJ/kg
specific energybtus per poundbtu/lb
specific energybtus per pound dry airbtu/lb
specific energykilojoules per kilogramkJ/kg
specific energykilojoules per kilogram dry airkJ/kg
specific energymegajoules per kilogram dry airMJ/kg
specific entropyjoules per kilogram degree kelvinJ/kg°K, J/kg·K
surface tensionnewtons per meter stN/m
temperaturefahrenheit°F, ℉
temperaturecelsius°C, ℃, degrees-celsius
temperaturekelvinK
temperaturemillikelvinmK
temperaturetemperature-gradientK/h
temperaturekelvin-percentK/%
colorTemperaturemirekmirek, mired
colorTemperaturecolor temperature kelvinK
temperature differentialfahrenheit degreesΔ°F, Δ℉, delta℉
temperature differentialcelsius degreesΔ°C, Δ℃, delta℃
temperature differentialkelvin degreesΔ°K, ΔK, deltaK
thermal conductivitywatts per meter degree kelvinW/m°K, W/m·K, W/m K⁻¹
timenanosecondns
timemicrosecondus
timemillisecondms
timehundredths secondcs
timetenths secondds
timeseconds
timeminutemin
timehourhr, h
timedayday
timeweekwk
timejulian monthmo
timeyearyr
turbiditynephelometric turbidity unitsntu
turbidityformazin nephelometric unitfnu
velocitymeters per secondm/s
velocitykilometers per secondkm/s
velocitykilometers per hourkm/hr, km/h
velocitymiles per hourmph
velocityfeet per secondft/s
velocityfeet per minuteft/min
velocitymillimeters per secondmm/s
velocitymillimeters per minutemm/min
velocitymeters per minutem/min
velocitymeters per hourm/hr
volumecubic meterm³
volumecubic millimetermm³
volumecubic centimetercm³
volumemillilitermL
volumeliterL
volumekiloliterkL
volumecubic inchin³
volumecubic footft³
volumecubic yardyd³
volumegallongal
volumequartqt
volumepintpt
volumefluid ouncefl oz
volumeimperial gallongalUK, gal(UK)
volumetric flowcubic meters per secondm³/s
volumetric flowcubic meters per minutem³/min
volumetric flowcubic meters per hourm³/hr, m³/h, m3/h
volumetric flowcubic meters per daym³/day
volumetric flowmilliliters per secondmL/s
volumetric flowmilliliters per minutemL/min
volumetric flowmilliliters per hourmL/hr
volumetric flowliters per secondL/s
volumetric flowliters per minuteL/min
volumetric flowliters per hourL/hr, l/h
volumetric flowcubic feet per secondcfs, ft³/s
volumetric flowcubic feet per minutecfm, ft³/min
volumetric flowcubic feet per hourcfh, ft³/hr
volumetric flowcubic feet per daycfd, ft³/day
volumetric flowstandard cubic feet per daystd cfd, std ft³/day
volumetric flowmillion standard cubic feet per minutestd m cfm, std M ft³/min
volumetric flowmillion standard cubic feet per daystd m cfd, std M ft³/day
volumetric flowthousand cubic feet per dayth cfd, th ft³/day
volumetric flowthousand standard cubic feet per dayth std cfd, th std ft³/day
volumetric flowimperial gallons per secondgalUK/s, gal(UK)/s
volumetric flowimperial gallons per minutegalUK/min, gal(UK)/min
volumetric flowimperial gallons per hourgalUK/hr, gal(UK)/hr
volumetric flowgallons per secondgal/s
volumetric flowgallons per minutegal/min
volumetric flowgallons per hourgal/hr
volumetric flowrain amountl/m²
