JavaScript Script for MQTT Integration
This document introduces how to use a JavaScript script in Aqara Studio to add MQTT device points and their parsing methods.
Script Overview
This script must include the following 4 JavaScript methods:
Do not modify the parameters of these methods or their input/output structures.
Script Global Variables
A protocol script can use globalThis.studioScriptState to share a small amount of temporary state across multiple function calls in the same Context. This variable is initialized as an empty object by default:
globalThis.studioScriptState = {
reportCount: 0,
lastValue: null
Keep this variable as a plain object. Its properties may contain strings, finite numbers, booleans, null, plain objects, and arrays, including nested combinations of those types. Convert dates to strings first. Do not store undefined, functions, Symbol, BigInt, NaN, Infinity, circular references, Map, Set, Java/host objects, or custom class instances; such values may be ignored, lose information, or cause serialization failures.
State size is measured by the serialized UTF-8 JSON byte length. The warning threshold is 2 MiB. Studio performs a rate-limited check after script calls. When the state first exceeds the threshold, Studio writes one [warn] entry to both the service log and Console Content on the protocol configuration page. Repeated overflow does not produce periodic warnings, does not delete the state automatically, and does not terminate the current call. Keep this variable below 2 MiB during normal development and operation.
globalThis.studioScriptState is reinitialized after idle Context reclamation, memory-pressure reclamation, script updates, or execution timeouts. Do not use it for durable device state, credentials, or an unbounded history of messages.
parseDiscoveryResponse
The parseDiscoveryResponse method is mainly used to declare the basic configuration of the MQTT devices that should be integrated into Aqara Studio.
You need to return the basic information of devices to be integrated as an array of objects. For details, see Device Object Structure.
Aqara Studio calls this method to discover all available devices and enable automatic onboarding and management.
Field NameRequiredDescription
deviceNameOptionalDevice name.
deviceIdRequiredDevice ID.
brokerEndpointRequiredMQTT broker address.
brokerPortRequiredMQTT broker port.
connectionTypeRequiredConnection type. Supported values:
  • 0: Anonymous
  • 1: Anonymous over SSL
  • 2: Username/password over SSL
  • 3: Username/password without SSL
usernameConditionally requiredUsername, depending on connectionType.
passwordConditionally requiredPassword, depending on connectionType.
Required field notes:
  • deviceId, brokerEndpoint, brokerPort, and connectionType are required.
  • The default brokerPort is 1883, and the default connectionType is 3.
  • Whether username and password are required depends on connectionType.
  • deviceName is optional and defaults to an empty string when omitted.
Example
function parseDiscoveryResponse() {
return [
deviceName: "TestDevice",
deviceId: "device-001",
brokerEndpoint: "127.0.0.1",
brokerPort: 1883,
connectionType: 3,
username: "admin",
password: "public"
parseDiscoverPointsResponse
This method declares to Aqara Studio which points the device supports. Aqara Studio passes deviceId as the first argument when calling this function.
You need to return one or more point definitions in the returned array, such as pointId. For details, see Point Object Structure. Aqara Studio calls this function during point discovery and parses the returned value to identify all supported points, enabling seamless onboarding and control.
pointIdRequiredPoint ID. Consult the device manufacturer for the actual point ID so Aqara Studio can discover the point.
pointNameRequiredCustom point name defined by you.
devTypeConditionally requiredCorresponds to deviceType in the Aqara data model specification. Fill this when defining a point based on Aqara Spec. For available values, see Device Types.
functionCodeConditionally requiredCorresponds to functionCode in the Aqara data model specification. Fill this when defining a point based on Aqara Spec. For available values, see Function Codes.
traitCodeConditionally requiredCorresponds to traitCode in the Aqara data model specification. Fill this when defining a point based on Aqara Spec. For available values, see Trait Codes.
dataTypeConditionally requiredRequired for general points. Supported values:
  • bool: Boolean
  • numerical: Numeric
  • enum: Enumeration
  • text: Text
enumRangeConditionally requiredEnumeration option array. Required only when dataType is enum for a general point. The array must not be empty. Each item must contain an integer value and a string label. Both value and label must be unique, and label must not be empty.
trueText / falseTextOptionalDisplay labels for a general Boolean point. Effective only when dataType is bool. If not configured, trueText defaults to On and falseText defaults to Off. Configure them only when custom labels such as Enabled / Disabled are needed. activeText / onText and inactiveText / offText are also accepted as aliases.
minOptionalMinimum value for a general numeric point. Effective only when dataType is numerical. minimum is also accepted as an alias.
maxOptionalMaximum value for a general numeric point. Effective only when dataType is numerical. maximum is also accepted as an alias.
stepOptionalStep value for a general numeric point. It must be greater than 0. Effective only when dataType is numerical. resolution is also accepted as an alias.
precisionOptionalPrecision value for a general numeric point. It must be greater than or equal to 0. Effective only when dataType is numerical.
decimalsOptionalNumber of decimal places for a general numeric point. It must be an integer greater than or equal to 0. Effective only when dataType is numerical.
unit / unitsOptionalUnit for a general numeric point. Effective only when dataType is numerical. It is recommended to use a registered unit name such as kilowatt hour, watt, volt, ampere, celsius, or percent. Studio displays the corresponding symbols such as kWh, W, V, A, °C, and %. For the full mapping, see Unit Names and Symbols Supported by Scripts. The system can also match registered unit symbols.
accessConditionally requiredRequired for general points. Access capability flag:
  • 1: Readable
  • 2: Writable
  • 3: Readable and writable
subTopicConditionally required(MQTT devices only) Required for readable or reportable points. Aqara Studio subscribes to this topic to receive the latest point data. Fill it according to the device protocol or vendor documentation. If one point needs to receive multiple upstream topics, you can use MQTT wildcards such as + or #.
pubTopicConditionally required(MQTT devices only) Required for writable points. Aqara Studio sends control messages to this topic to control the point. Fill it according to the device protocol or vendor documentation. Leave this field empty for read-only points.
note
For numerical points, when Aqara Studio calls buildWriteRequest, it formats the write value by decimals first. If decimals is not configured, it infers the number of decimal places from step / resolution. To avoid binary floating-point artifacts such as 0.30000030249357224, explicitly configure decimals or step for points that write fractional values. precision only describes precision and is not used as the decimal-place truncation rule for outgoing write payloads.
If a numeric point is used by energy statistics or other unit-dependent features, configure unit or units. For example, use kilowatt hour (displayed as kWh) for accumulated energy, watt (W) for current power, volt (V) for voltage, ampere (A) for current, and celsius (°C) for temperature. Enter unit names exactly as shown in Unit Names and Symbols Supported by Scripts, including case and spaces.
You can define point data structures in either of the following ways:
  • Based on Aqara Spec: Fill in fields such as devType, functionCode, and traitCode to map the device point to the corresponding point in the Aqara data model specification.
  • General approach: Fill in basic fields such as dataType and access.
Example
function parseDiscoverPointsResponse(deviceId) {
return [
// Add points based on Aqara Spec
pointId: "1#Chiller Operation Status",
pointName: "1#Chiller Operation Status",
devType: "AirConditioner",
functionCode: "Output",
traitCode: "OnOff",
subTopic: "/WEI-iEdge/realdata/7a1dd258f32940d95a542c68",
pubTopic: "/WEI-iEdge/write/req/7a1dd258f32940d95a542c68"
// Add points by the general approach
pointId: "1#Chiller Off/On Read",
pointName: "1#Chiller Off/On Read",
dataType: "bool",
access: 1,
pointId: "1#Chiller Operating Mode",
pointName: "1#Chiller Operating Mode",
dataType: "enum",
enumRange: [
{ value: 0, label: "Off" },
{ value: 1, label: "Cooling" }
access: 3,
pointId: "1#Chiller Leaving Water Temperature Setpoint Read",
pointName: "1#Chiller Leaving Water Temperature Setpoint Read",
dataType: "numerical",
min: -20,
max: 50,
step: 0.1,
precision: 0.1,
decimals: 1,
unit: "celsius",
access: 2,
pointId: "1#Chiller Cooling Capacity Percentage",
pointName: "1#Chiller Cooling Capacity Percentage",
min: 0,
max: 100,
step: 1,
precision: 1,
decimals: 0,
unit: "percent",
access: 2,
parseReportRequest
This method parses one MQTT device report message and returns all point values contained in that message at once. The script is called only once for the same message and is not executed repeatedly per subscribed point.
ParameterTypeDescription
topicStringThe MQTT topic on which the message was received
jsonStrStringThe raw MQTT payload string
The return value must be an object containing a points array. Each item in the array contains pointId and value. Only the returned points are updated.
Example
function parseReportRequest(topic, jsonStr) {
try {
const obj = JSON.parse(jsonStr);
const values = obj.values || {};
return {
points: Object.keys(values).map(function (pointId) {
return {
pointId: pointId,
value: String(values[pointId])
} catch (e) {
return { points: [] };
buildWriteRequest
This method constructs the control command string to send to the device based on the target point ID and the value to set.
When Aqara Studio needs to send a control command to the device, such as switching a device on or off or setting a temperature, it calls this function and passes in the device ID, target point ID, and target value. The function must return a string that matches the command format required by the device protocol, usually including fields such as the device identifier, timestamp, and specific value payload.
Construct the object structure inside the function according to the actual message format accepted by the device. For example, for an MQTT device, the payload may include fields such as node, group, and timestamp, and the value corresponding to pointId should be written into the values field.
Example
// Example: control an MQTT device via a JSON string
// The value parameter is automatically passed in by Aqara Studio and does not need to be declared or assigned manually
function buildWriteRequest(deviceId, pointId, value) {
try {
const obj = {
"node": "Chiller",
"group": "1#Chiller",
"timestamp": 1768204054654,
"values": {
"errors": {
"metas": {
obj.values[pointId] = parseFloat(value);
return JSON.stringify(obj);
} catch (e) {
return null;
Complete Example
Below is a complete example of adding points for an MQTT device:
The globalThis registrations in the example are dynamic: register only the functions you actually implement. Functions that are not implemented do not need to be registered.
note
The example below only demonstrates a common MQTT integration flow: subscribe to one topic filter that receives multiple upstream message types, parse status, event, and command-response messages by type, and correlate write requests with responses by request ID. Replace the topics, field names, and enum values according to the actual device protocol.
(function() {
// Store only JSON-serializable temporary state. It is cleared when the Context is rebuilt.
var scriptState = globalThis.studioScriptState;
scriptState.reportCount = 0;
scriptState.lastReportAt = null;
var DEVICE_ID = "device-001";
var SUB_TOPIC = "/example/" + DEVICE_ID + "/+/json";
var PUB_TOPIC = "/example/" + DEVICE_ID + "/cmd/json";
var nextRequestIdValue = 1;
var pendingWrites = {};
return [
deviceName: "Example MQTT Device",
deviceId: DEVICE_ID,
brokerPort: 1883,
connectionType: 3,
username: "username",
password: "password"
return [
pointId: "switch.on",
pointName: "Switch",
dataType: "bool",
access: 3,
subTopic: SUB_TOPIC,
pubTopic: PUB_TOPIC
scriptState.reportCount += 1;
scriptState.lastReportAt = new Date().toISOString();
try {
var obj = JSON.parse(jsonStr);
var value = parseStatusReport(obj)
|| parseEventReport(obj)
|| parseCommandResponse(obj);
return {
points: value === null
: [{ pointId: "switch.on", value: value }]
} catch (e) {
function parseStatusReport(obj) {
if (obj.type !== "status") {
return null;
return toBoolString(obj.values && obj.values["switch.on"]);
function parseEventReport(obj) {
if (obj.type !== "event" || obj.pointId !== "switch.on") {
return null;
return toBoolString(obj.value);
function parseCommandResponse(obj) {
if (obj.type !== "response" || obj.requestId === undefined) {
return null;
var key = String(obj.requestId);
var pending = pendingWrites[key];
delete pendingWrites[key];
if (!pending || obj.success !== true) {
return null;
return pending.value;
try {
if (pointId !== "switch.on") {
return null;
var writeValue = toBoolString(value);
if (writeValue === null) {
return null;
var requestId = nextRequestId();
pendingWrites[String(requestId)] = {
pointId: pointId,
value: writeValue
var values = {};
values[pointId] = writeValue === "1";
return JSON.stringify({
type: "command",
requestId: requestId,
values: values
} catch (e) {
return null;
function toBoolString(value) {
if (value === true || value === 1) {
return "1";
if (value === false || value === 0) {
return "0";
var text = String(value).toLowerCase();
if (text === "true" || text === "on" || text === "1") {
return "1";
if (text === "false" || text === "off" || text === "0") {
return "0";
return null;
function nextRequestId() {
nextRequestIdValue += 1;
return nextRequestIdValue;
globalThis.parseDiscoveryResponse = parseDiscoveryResponse;
globalThis.parseDiscoverPointsResponse = parseDiscoverPointsResponse;
globalThis.buildWriteRequest = buildWriteRequest;
globalThis.parseReportRequest = parseReportRequest;
return null;
Troubleshooting Script Issues
After you finish developing the script, if Aqara Studio still cannot discover devices or points, check the following:
  1. Use Console Logging to verify whether each method in the script is being called as expected.
  2. Review Script Checklist and check each item against Aqara Studio's validation requirements.
  3. If the issue still cannot be resolved, it may be caused by Aqara Studio's Runtime Resource Limits.
Console Logging
  1. To debug and troubleshoot methods such as parseDiscoveryResponse and parseDiscoverPointsResponse, you can add any of the following console logging methods anywhere inside a function:
    • console.log
    • console.info
    • console.debug
    • console.warn
    • console.error
    Do not print logs unconditionally inside loops or high-frequency message handlers. Use conditional switches or sampled logging during debugging.
    Example:
    console.info("Start parsing discovery response", arguments);
    return [
    deviceName: "xxx",
    • When multiple arguments are passed, the log output joins them with spaces.
    • Output from console.warn and console.error includes the [warn] and [error] prefixes respectively.
  2. Trigger the related action again in Aqara Studio, such as device discovery, point discovery, point read, point write, or reporting, to execute the method that contains logs.
  3. Open the MQTT Protocol Configuration page and check whether the Console Content field contains log output:
    • If logs appear correctly, the method has been integrated successfully.
    • If no logs appear, check whether the method implementation is incorrect.
    • Console Content keeps at most 2048 characters. When the limit is exceeded, older content is replaced.
    • Each script parser accepts at most 20 log entries per second. Excess logs are ignored and summarized in the next time window.
    • Each log entry keeps at most 512 characters and converts only the first 16 arguments.
Script Checklist
It is recommended that you review the script item by item according to the validation flow of each Aqara Studio business node so that all key checks pass and the script remains reliable and compatible.
Business nodeCalled functionMain validation
Script loadingComplete scriptThe script must not exceed 1,048,576 characters and must be executable by the JavaScript engine. Whether each business function exists and is callable is checked again when it is actually invoked.
Device discoveryparseDiscoveryResponse()The return value must be an array. At most 128 devices are processed in a single call. Invalid device entries are ignored, and deviceId must be valid.
Point discoveryparseDiscoverPointsResponse(deviceId)The return value must be an array. At most 512 points are processed in a single call. Each item is validated for pointId, data type, access capability, and enum or numeric configuration.
Device reportparseReportRequest(topic, msg)The UTF-8 message must not exceed 256 KiB. The function is called once per message. The return value must contain a points array. At most 512 items are processed in a single call, and each item's pointId and value are validated.
Point writebuildWriteRequest(deviceId, pointId, value)The function must return a non-empty string. The generated content is sent through the publish topic configured for the point.
  • A single MQTT message passed to parseReportRequest must not exceed 256 KiB when encoded as UTF-8. Oversized messages are not passed to JavaScript.
  • A single device discovery call processes at most 128 devices, and a single point discovery call processes at most 512 points. Additional entries are ignored.
  • parseReportRequest returns at most 512 point values in a single call. Additional entries are ignored.
  • A script Context may be reclaimed after a long idle period or when the system is under memory pressure, and it is rebuilt on the next call. Do not rely on global variables to permanently store device state. Durable state should be stored on the device or in Studio points.
  • A script call may be rejected when the execution queue is full or system memory pressure is high. Active device reports should support reasonable retries or later full-state resubmission.
