Energy Management System
Overview
Aqara Studio’s energy management system can automatically collect data from all types of energy-consuming devices, supporting daily, weekly, and monthly multi-dimensional statistics and trend analysis. Through this UI, you can intuitively view the total energy usage for your entire space, rank energy consumption by space, device, or device type, and analyze specific energy usage trends in depth.
This feature helps you monitor the energy consumption status of various areas and devices in real time, quickly identify high-consumption devices and abnormal usage behavior, and provides decision support for energy-saving optimization and efficiency management.
Additionally, the energy management dashboard presents energy data visually and centrally, providing strong data support for subsequent efficiency analysis, energy consumption warnings, and device maintenance.
Prerequisites
The energy management page displays only devices capable of reporting power consumption data (such as refrigerators, air conditioners, switches, sockets, and other devices with energy statistics capability), and only statistics based on each device's Cumulative Energy Consumption data point are collected.
Energy management can display energy data from different protocol devices, but specific visibility depends on the device protocol configuration:
  • Aqara devices and those in the Home Assistant ecosystem natively support this feature. As long as they are connected to Aqara Studio, their data is shown in the energy management page directly, with no extra adjustment required.
  • For devices using other protocols, you must manually map the energy consumption-related data point to Cumulative Energy Consumption when integrating them, otherwise Aqara Studio will not be able to retrieve their energy data.
If you want to monitor energy consumption for devices that do not support energy statistics by themselves (such as lights), you can connect them to a smart socket or smart meter, then view the energy data for that socket or meter in the energy management page to indirectly obtain the device’s consumption.
Adjust Data
Go to EMS from the left sidebar. By default, all devices in all spaces are shown. No setup is required.
If you need custom data, see the settings table below:
ComponentDescriptionGeneral SettingsSpecial Settings
Energy Data
  • Total Energy: Last 365 days
  • Today's Energy: From 00:00 to now, updates hourly
  • Yesterday's Energy: All of yesterday
  • 7-Day Energy: Last 7 days
  • 30-Day Energy: Last 30 days
Data Source
• Device scope: All or selected devices
View Options
• Itemized display: You can independently enable or disable the display of Today, Yesterday, Last 7 Days, and Last 30 Days energy consumption.
Energy TrendsLine chart shows energy use trends and peak timesCommon Settings
• Time unit: hour, day, week, month
• Period: custom time range
• Device scope: all or selected
Chart Settings
• Show max/min for range
Energy Top by SpaceRanks devices by energy useCommon Settings
Rank Settings
• Show: top 5, top 10, chosen, all devices
Energy Top by DeviceRanks devices by energy usage. Helps you quickly spot high energy devices.Common Settings
Ranking Options
• Show: top 5, top 10, selected devices, or all devices
Energy Trend by Device TypeTracks energy by device type, like lights or ACCommon Settings
Type Filter
• Show all or specific types
• Show max/min values
Energy MoMShows week-over-week changesCommon Settings
Time Select
• Choose any week as "current" week
Energy Consumption CalendarCalendar view of daily energy with colored levels for rangeCommon Settings
View Settings
• Pick target month
• Customize color and range per level
