Automation API
Query Device Traits Available for Automation
By calling this API, you can query trait information that can be used for automation from all devices. The returned content includes the value type, unit, and the applicable phase for each trait in the automation process (such as starter, condition, or action).
Request Parameters
| Parameter | Type | Required | Description |
| type | String | ✓ | Message type for the request, must be QueryAutomationCapabilitiesRequest. |
| version | String | ✓ | API version, must be v1. |
| msgId | String | ✓ | Request ID defined by you. |
| data | Object | ✓ | Pass an empty object here. |
Example Request
Below is a sample request body for QueryAutomationCapabilitiesRequest:
"type": "QueryAutomationCapabilitiesRequest",
"version": "v1",
"msgId": "1751609244328",
"data": {}
Response Parameters
| Parameter | Type | Description |
| type | String | The message type of the response, always QueryAutomationCapabilitiesResponse. |
| version | String | Response version. It matches the version used in the request. |
| msgId | String | The msgId provided in your request. |
| code | Number | Return code. 0 means success, any non-zero value indicates failure. |
| data.devices | Array of Object | List of device information. |
| data.devices[].deviceId | String | Device ID. |
| data.devices[].deviceName | String | Device name. |
| data.devices[].endpoints | Array of Object | List of endpoint information for the device. |
| data.devices[].endpoints[].endpointName | String | Endpoint name. |
| data.devices[].endpoints[].endpointId | Number | Endpoint ID. |
| data.devices[].endpoints[].properties | Array of Object | List of traits. |
| data.devices[].endpoints[].properties[].functionCode | String | Function code. |
| data.devices[].endpoints[].properties[].functionName | String | Function name. |
| data.devices[].endpoints[].properties[].traitCode | String | Trait code. |
| data.devices[].endpoints[].properties[].traitName | String | Trait name. |
| data.devices[].endpoints[].properties[].valueType | String | The value type of the trait (such as boolean, number, etc.). |
| data.devices[].endpoints[].properties[].semanticRole | Array of String | The automation phases this trait can participate in, including starter, condition, and action. The specific roles depend on the returned array. |
| data.devices[].endpoints[].properties[].unit | String/null | Unit. If no unit, this is null. |
Example Response
Below is an example response for QueryAutomationCapabilitiesResponse:
"type": "QueryAutomationCapabilitiesResponse",
"version": "v1",
"devices": [
"deviceId": "9f3e3632068ff047",
"deviceName": "Door and Window Magnet Sensor",
"endpoints": [
"endpointName": "Endpoint_2",
"endpointId": 2,
"properties": [
"functionCode": "OnOffSensor",
"functionName": "OnOff Sensor",
"traitCode": "BooleanState",
"traitName": "Boolean State",
"valueType": "boolean",
"semanticRole": [
"starter",
"condition"
"unit": null
"deviceId": "af9e93b709de1fd9",
"deviceName": "Motion Sensor",
"endpoints": [
"endpointId": 2,
"properties": [
"semanticRole": [
"starter",
"condition"
"unit": null
"deviceId": "947793560f5b2fbd",
"deviceName": "Flood Detector",
"endpoints": [
"endpointId": 2,
"properties": [
"semanticRole": [
"starter",
"condition"
"unit": null
"code": 0
Create Automation
By calling this API, you can create and enable a flow automation.
Once created successfully, you can view and manage this flow in the automation list on Aqara Studio.
Request Parameters
| type | String | ✓ | Message type, must be CreateAutomationRequest. |
| msgId | String | ✓ | Custom request ID defined by you. |
| data | Object | ✓ | Request data. |
| data.definitionType | String | ✓ | Automation type. Currently, only "SCRIPT_JSON" is supported. |
| data.config | Object | ✓ | JSON automation script. For details, see JSON Automation Script. |
Example Request
Below is a sample request body for CreateAutomationRequest:
"type": "CreateAutomationRequest",
"version": "v1",
"definitionType": "SCRIPT_JSON",
"config": {
"metadata": {
"name": "Smart Lighting Control",
"description": "Automatically turn on two lights when the switch is on",
"scope": [
"name": "switchState",
"type": "device.property",
"deviceId": "switch001",
"endpointId": 1,
"functionCode": "OnOff",
"traitCode": "OnOff"
"name": "tempSensor",
"deviceId": "sensor001",
"endpointId": 1,
"functionCode": "TemperatureMeasurement",
"traitCode": "MeasuredValue"
"automations": [
"name": "Switch triggers light linkage",
"starters": [
"type": "property.event",
"source": {
"type": "data.ref",
"from": "/metadata/scope",
"select": {
"by": "name",
"value": "switchState"
"is": true,
"for": "5sec",
"suppressFor": "10sec"
"condition": {
"type": "and",
"conditions": [
"type": "property.state",
"source": {
"type": "data.ref",
"select": {
"by": "name",
"value": "tempSensor"
"greaterThan": 20
"type": "time.between",
"after": "08:00",
"before": "22:00"
"actions": [
"type": "device.trait.write",
"functionCode": "Switch",
"traitCode": "OnOff",
"targets": [
"deviceId": "light001",
"endpointIds": [1]
"value": true
"type": "delay",
"for": "2sec"
"functionCode": "LevelControl",
"traitCode": "CurrentLevel",
"targets": [
"endpointIds": [1]
"value": 100
Response Parameters
| type | String | The type of message in the response. Always set to CreateAutomationResponse. |
| message | String | Description of the request result. |
| data | String | The automatin ID of the created automation. |
Example Response
Below is an example response for CreateAutomationResponse:
"type": "CreateAutomationResponse",
"version": "v1",
"message": "",
"data": "auto_15b0cde_127312348967862272"
Edit Automation
By calling this API, you can modify the name and enabled status of an existing automation. If the automation's definitionType is "SCRIPT_JSON", you can also update its automation script content at the same time.
Request Parameters
| type | String | ✓ | Message type, must be UpdateAutomationRequest. |
| data.automationId | String | ✓ | The target automation ID. |
| data.definitionType | String | ✓ | The definition type of the target automation to be edited. |
| data.name | String | ✗ | The new name. |
| data.enabled | Boolean | ✗ | The new enabled status. true means enabled. false means disabled. |
| data.config | Object | ✗ | The new JSON automation script. |
| data.updateMask | Array of String | ✓ | List of parameter names to be updated. Only the following fields are supported:
updateMask has a corresponding new value provided in the data object. |
Example Request
Below is an example of the request body for UpdateAutomationRequest:
"type": "UpdateAutomationRequest",
"version": "v1",
"automationId":"auto_15b0cde_127312348967862272",
"name": "New Name",
"updateMask": [
"name"
Response Parameters
| type | String | The type of message in the response. Always set to UpdateAutomationResponse. |
| data | String | Empty string. |
Example Response
The following is an example response for UpdateAutomationResponse:
"type": "UpdateAutomationResponse",
"version": "v1",
"message": "",
"data": ""
Batch Update Automation Status
By calling this API, you can update the enable status of multiple automations at once.
Request Parameters
| type | String | ✓ | Type of request message, must be UpdateAutomationStatusRequest. |
| data | Object | ✓ | Request data object. |
| data.automationIds | Array of String | ✓ | List of automation IDs to update the status for. |
| data.enabled | Boolean | ✓ | The status to set: true to enable, false to disable. |
Example Request
Below is a example request body for UpdateAutomationStatusRequest:
"type": "UpdateAutomationStatusRequest",
"version": "v1",
"automationIds": [
"enabled": false
Response Parameters
| type | String | Response message type, always UpdateAutomationStatusResponse. |
| version | String | API version in the response, always v1. |
| msgId | String | The msgId you provided in the request. |
| code | Number | Indicates whether the request was successful: 0 for success, non-zero for failure. |
| data | Object | Response data object. |
| data.successIds | Array of String | List of successfully updated automation IDs. |
| data.failedItems | Array of Object | List of failed automation update objects. |
| data.failedItems.automationId | String | Automation ID. |
| data.failedItems.code | Number | Error code. |
| data.failedItems.message | String | Failure description. |
Example Response
The following is an example response for UpdateAutomationStatusResponse:
"type": "UpdateAutomationStatusResponse",
"version": "v1",
"successIds": [
Query Automation List
By calling this API, you can get a paginated list of automation summaries, including each automation's ID, name, enable status, and creation time.
Request Parameters
| type | String | ✓ | Message type, must be GetAutomationListRequest. |
| data.definitionTypes | Array of String | ✗ | Target types to query. Optional values: "SCRIPT_JSON", "SCRIPT_TEXT", "WHEN_IF_THEN". If not provided or empty, queries all types. |
| data.orderBy | String | ✗ | Sorting field.
| data.pageNum | Number | ✓ | Page number, starting from 1. |
| data.pageSize | Number | ✓ | Number of items per page. |
Example Request
Below is a sample request body for GetAutomationListRequest:
"type": "GetAutomationListRequest",
"version": "v1",
"definitionTypes": ["SCRIPT_JSON"],
"pageNum":1,
"pageSize":2
Response Parameters
| type | String | Response message type, always GetAutomationListResponse. |
| data | Object | Response data object, including the automation list and pagination info. |
| data.totalCount | Number | Total number of automations. |
| data.pageNum | Number | Current page number. |
| data.pageSize | Number | Number of items per page. |
| data.data | Array of Object | List of automations. |
| data.data[].automationId | String | Automation ID. |
| data.data[].definitionType | String | Automation type. |
| data.data[].name | String | Name of the automation. |
| data.data[].enabled | Boolean | Enable status:
| data.data[].createTime | Number | Creation time of the automation, as a UTC timestamp in milliseconds. |
| code | Number | Indicates request success. 0 means success, non-zero means failure. |
| message | String or null | Description of the response. An empty string or null indicates success. |
Example Response
Below is an example response for GetAutomationListResponse:
"type": "GetAutomationListResponse",
"version": "v1",
"totalCount": 6,
"pageNum": 1,
"pageSize": 2,
"data": [
"automationId": "auto_15b0cde_127312348967862272",
"name": "a3-1",
"enabled": false,
"createTime": 1766043229326
"automationId": "auto_15b0ceb_127312523723538432",
"name": "b2",
"enabled": true,
"createTime": 1766043270999
"message": null
Query Automation Details
By calling this API and providing the automation ID, you can retrieve the detailed information for the specified automation (such as the JSON automation script).
Only automations with definitionType equal to "SCRIPT_JSON" are supported for querying details.
Request Parameters
| type | String | ✓ | Request message type, must be GetAutomationDetailsRequest. |
| data | String | ✓ | The automation ID to be queried. |
Example Request
Below is an example request body for GetAutomationDetailsRequest:
"type": "GetAutomationDetailsRequest",
"version": "v1",
Response Parameters
| type | String | The type of response message. Always set to GetAutomationDetailsResponse. |
| version | String | API version. Always v1. |
| data | Object | The returned object containing the automation's detailed information. |
| data.automationId | String | The automation ID. |
| data.definitionType | String | Automation type. Currently always "SCRIPT_JSON". |
| data.name | String | The name of the automation. |
| data.enabled | Boolean | Whether the automation is enabled. |
| data.config | Object | The JSON automation script. |
| data.createTime | Number | The time when the automation was created, as a UTC timestamp in milliseconds. |
| code | Number | Response code. 0 means success, any other value is an error code. |
| message | String or null | Description message about the response. An empty string or null means the request was successful. |
Example Response
Below is an example response for GetAutomationDetailsResponse:
"type": "GetAutomationDetailsResponse",
"version": "v1",
"name": "a3-1",
"enabled": false,
"config": {
"message": null
Delete Automation
By calling this API, you can delete multiple automations.
Request Parameters
| type | String | ✓ | Request message type, fixed as DeleteAutomationRequest. |
| version | String | ✓ | API version, always v1. |
| data | Array of String | ✓ | Array of automation IDs to be deleted. |
Example Request
Below is an example request body for DeleteAutomationRequest:
"type": "DeleteAutomationRequest",
"version": "v1",
"data": ["auto_15b0b4d_1273030749213163"]
Example Response
| type | String | The type of message in the response. Always set to DeleteAutomationResponse. |
| version | String | Response version. Always set to v1. |
| data | Object | Response object. |
| data.successIds | Array of String | IDs of automations deleted successfully. |
| data.failedItems | Array of Object | Objects representing failed deletions. |
Example Response
"type": "DeleteAutomationResponse",
"version": "v1",
"message": "",
"successIds": [
