Device Function API
Query Device Information by Pages
You can query the list of devices in the Studio system with pagination. Filtering by device type, sorting, and paging are supported.
This API allows you to retrieve a paginated list of device information. By specifying parameters such as device types, sort fields, page number, and page size, you can flexibly filter, sort, and paginate the detailed information of devices integrated into Aqara Studio. The response includes device ID, name, type, creation time, online status, and more.
Request Parameters
ParameterTypeRequiredDescription
typeStringYesMessage type, must be GetDeviceInfoRequest.
versionStringYesAPI version, must be v1.
msgIdStringYesCustom request ID defined by you.
dataObjectYesRequest data.
data.deviceTypesListArray of StringNoList of device types. For available strings, see Device Types.
data.orderByStringNoSort rule. Supported values:
  • createTime asc: Sort by creation time ascending.
  • createTime desc: Sort by creation time descending.
data.pageNumNumberNoPage number, starting from 1. Values less than 1 will be treated as 1.
data.pageSizeNumberNoNumber of device IDs per page. Range is (0, 200]. The default value is 200.
Example Request
Below is an example request body for GetDeviceInfoRequest:
"type": "GetDeviceInfoRequest",
"version": "v1",
"msgId": "get_devices_1751609244328",
"data":{
"deviceTypesList": ["Light"],
"orderBy": "createTime desc",
"pageNum": 1,
"pageSize": 100
Response Parameters
ParameterTypeDescription
typeStringThe type of message in the response. Always set to GetDeviceInfoResponse.
versionStringResponse version. It matches the version used in the request.
msgIdStringThe msgId you sent in your request.
messageStringDescription of the request result.
codeNumberIndicates if the request was successful. 0 means success, any non-zero value means failure.
dataObjectResponse data.
data.totalCountNumberTotal number of devices.
data.pageSizeNumberPage size.
data.pageNumNumberPage number.
data.dataArray of ObjectList of device data.
data.data[].deviceIdStringDevice ID.
data.data[].deviceTypesListArray of StringDevice type. For an explanation of the string values, see Device Types.
data.data[].deviceNameStringDevice name.
data.data[].createTimeNumberUnix timestamp (milliseconds) when the device was added.
data.data[].stateBooleanDevice online status:
  • false: offline.
  • true: online.
Example Response
Below is an example of a GetDeviceInfoResponse response:
"type": "GetDeviceInfoResponse",
"version": "v1",
"message": "",
"data":{
"totalCount": 1,
"pageSize": 100,
"pageNum": 1,
"data":[
"deviceId": "xxx",
"deviceName": "xxx",
"createTime":1758549173093,
"state": true
Query All Device Information
This API is used to retrieve the complete list of device information. With this interface, you can obtain detailed information of all devices within Aqara Studio at once, including device ID, name, device type, time added, online status. The request body supports filtering based on device type and sorting fields.
The response returns the device list as an array, without pagination information. It is suitable for scenarios where all device data needs to be obtained in a single request.
Request Parameters
typeStringYesMessage type, must be GetAllDeviceInfoRequest.
dataObjectNoFilter configuration.
data.deviceTypesListString[]NoArray of device types to filter the query. If left empty, all device types will be queried by default. Each element represents a specific device type string. For details, see Device Types.
data.orderByStringNoSorting rule. Supported values:
Example Request
Below is an example request body for GetAllDeviceInfoRequest:
"type": "GetAllDeviceInfoRequest",
"version": "v1",
"msgId": "req-003",
Response Parameters
typeStringThe type of message in the response. Always set to GetAllDeviceInfoResponse.
dataArray of ObjectData list.
data[].deviceTypesListArray of StringDevice types. For an explanation of the string values, see Device Types.
data[].createTimeNumberThe Unix timestamp (milliseconds) when the device was added.
  • false: offline.
  • true: online.
Example Response
Below is a sample response for GetAllDeviceInfoResponse:
"type": "GetAllDeviceInfoResponse",
"version": "v1",
"msgId": "req-003",
"data": [
"deviceId": "device-001",
"deviceName": "Living Room Lamp",
"createTime": 1609459200000,
"state": true
"deviceId": "device-002",
"deviceName": "Bedroom Lamp",
"createTime": 1609459300000,
"state": false,
Query Device Spec Configuration
Query the spec configuration of devices by device ID.
Request Parameters
typeStringYesThe type of message to send. Must be GetDevicesRequest.
versionStringYesAPI version. Must be v1.
msgIdStringYesThe request ID defined by you.
dataObjectYesRequest data object.
data.deviceIdsArray of StringNoPass the device ID list obtained from the paginated query or the complete query of device IDs into this list as the target for querying the spec configuration of the devices. If this list is empty, the spec configuration for all devices will be queried.
Request Example
Below is an example of a GetDevicesRequest request body:
"type": "GetDevicesRequest",
"version": "v1",
"data":{
"deviceIds": ["57190441014857"]
Response Parameters
typeStringThe type of message in the response. Always set to GetDevicesResponse.
dataArray of ObjectResponse data.
data[].nameStringDevice name.
data[].deviceTypesListArray of StringDevice type list. For an explanation of the string values, see Device Types.
data[].endpointsArray of ObjectEndpoint list.
data[].endpoints[].endpointIdNumberEndpoint ID.
data[].endpoints[].endpointNameStringEndpoint name.
data[].endpoints[].deviceTypeStringEndpoint type list.
data[].endpoints[].functionsArray of ObjectFunction list.
data[].endpoints[].functions[].functionCodeStringFunction code.
data[].endpoints[].functions[].traitsArray of ObjectTrait list.
data[].endpoints[].functions[].traits[].traitCodeStringTrait code, corresponding to the specific function supported by the device. For details, see Trait Codes, including the meaning, type (such as numeric, boolean, enumeration, etc.), whether it is readable/writable/reportable, etc.
data[].endpoints[].functions[].traits[].parameterObjectTrait parameter.
data[].endpoints[].functions[].traits[].parameter.typeStringType of trait value. For an explanation of the string values, see Trait Value Types.
data[].endpoints[].functions[].traits[].parameter.readableBooleanWhether the trait is readable.
data[].endpoints[].functions[].traits[].parameter.writableBooleanWhether the trait is writable.
data[].endpoints[].functions[].traits[].parameter.subscribableBooleanWhether the trait can be subscribed to.
data[].endpoints[].functions[].traits[].parameter.supportedValuesArray of ObjectList of enum values. This field is only meaningful when parameter.type is Enum.
data[].endpoints[].functions[].traits[].parameter.supportedValues[].keyStringEnum key.
data[].endpoints[].functions[].traits[].parameter.supportedValues[].valueStringEnum value.
data[].endpoints[].functions[].traits[].parameter.minNumberMinimum value. This field is only meaningful when parameter.type is Integer or Float.
data[].endpoints[].functions[].traits[].parameter.maxNumberMaximum value. This field is only meaningful when parameter.type is Integer or Float.
data[].endpoints[].functions[].traits[].parameter.unitStringUnit. This field is only meaningful when parameter.type is Integer or Float.
data[].endpoints[].functions[].traits[].valueAnyThe current value of the function point. The type is the same as parameter.type.
data[].endpoints[].functions[].traits[].timeNumberUnix timestamp (milliseconds) when the function point value was reported.
Checking Device Types and Trait Codes
  • In the response, data[].deviceTypesList shows the list of device types supported by the device. For the meaning of each string, see Device Types.
  • In the response, data[].endpoints[].functions[].traits[].traitCode shows the trait code, representing a specific function the device supports. For detailed explanation of each trait, including its meaning, type (such as numeric, boolean, enum, etc.), and whether it is readable, writable, or reportable, see Trait Codes.
Trait Value Types
NameTypeDescription
BoolBooleanTrue or false (true/false).
IntegerIntegerInteger type.
FloatFloatNumber with decimals.
StringStringString value.
StructStructAqara-defined structured data in JSON string format.
It can contain multiple types of fields.
EnumEnumEnum type, defines a fixed set of values.
List[X]ListA list of elements of type X, in JSON string format.
X can be Integer, Float, String, Struct, or Enum.
DataDataHex string (Hex String), e.g. "0x01AB3F".
Example Response
Below is an example response for GetDevicesResponse:
"type": "GetDevicesResponse",
"version": "v1",
"message": null,
"data": [
"deviceId": "57190441014857",
"name": "Touch Screen Switch Panel S1 Pro",
"Speaker"
"endpoints": [
"endpointId": 0,
"endpointName": "DeviceObject",
"deviceType": "Root"
"endpointId": 3,
"endpointName": "Multi-stateOutputObject",
"deviceType": "Speaker",
"functions": [
"functionCode": "MediaPlayback",
"traits": [
"traitCode": "TargetPlaybackState",
"parameter": {
"type": "Enum",
"readable": true,
"writable": true,
"subscribable": true,
"supportedValue": [
"key": "Play",
"value": "0"
"key": "Pause",
"value": "1"
"key": "Stop",
"value": "2"
"key": "StartOver",
"value": "3"
"key": "FastForward",
"value": "4"
"key": "Rewind",
"value": "5"
"key": "Previous",
"value": "6"
"key": "Next",
"value": "7"
"key": "PlaySpecificList",
"value": "8"
"value": "0",
"time": 1761295151845
"traitCode": "MediaInformation",
"parameter": {
"type": "String",
"readable": true,
"writable": false,
"value": "",
"time": null
"functionCode": "Speaker",
"endpointId": 3,
"traits": [
"traitCode": "Mute",
"parameter": {
"type": "Bool",
"readable": true,
"writable": true,
"value": false,
"time": 1761295151843
"traitCode": "Volume",
"parameter": {
"type": "Float",
"readable": true,
"writable": true,
"min": 0.0,
"max": 100.0,
"unit": "%"
"value": 0.0,
"time": 1761295151847
Control Device
After you get the device's spec configuration, you can control the device by passing the relevant fields for the trait you want to operate and calling this API.
Request Parameters
typeStringYesThe message type. Must be ExecuteTraitRequest.
versionStringYesThe version of the API. Must be v1.
msgIdStringYesA request ID defined by you.
dataArray of ObjectYesRequest data.
data[].deviceIdStringYesThe ID of the device to control.
data[].endpointIdNumberYesTarget endpoint ID.
data[].functionCodeStringYesFunction code.
data[].traitCodeStringYesTrait code that must have writable set to true.
data[].valueAnyYesThe value supported by this trait.
Request Example
Below is an example request body for ExecuteTraitRequest:
"type" : "ExecuteTraitRequest",
"version" : "v1",
"msgId" : "get_devices_1751609244328",
"data":[{
"deviceId": "14a0bxx",
"endpointId": 0,
"functionCode": "Output",
"traitCode": "OnOff",
"value": true
Response Data
typeStringThe response message type. Always ExecuteTraitResponse.
versionStringThe response version. Matches the request API version.
msgIdStringThe same msgId you sent in your request.
codeNumberStatus code for the control operation:
  • 0: At least one trait was controlled successfully.
  • Non-zero: All trait controls failed.
messageStringDescription of the result.
dataArray of ObjectList of failed device trait control results. Only failed records are included; successful controls are not returned.
data[].endpointIdNumberEndpoint ID.
data[].functionCodeStringFunction code.
data[].traitCodeStringTrait code.
data[].codeNumberFailure code for this trait control.
data[].messageStringFailure description.
A code value of 0 only means the API call was successful. It does not guarantee the device state has changed. Please query the latest trait value to confirm if the control was effective.
Example Response
Below is a sample response for ExecuteTraitResponse:
"type": "ExecuteTraitResponse",
"version": "v1",
"message": null,
"data": [
// When there is no failure, the data is empty
Query the Latest Values of Device Traits
Get the latest values for one or more device traits in a batch query.
Request Parameters
Below is an example of the request body for GetTraitValueRequest:
typeStringYesThe message type. Must be GetTraitValueRequest.
versionStringYesThe API version. Must be v1.
msgIdStringYesThe request ID, defined by you, to identify this request.
dataArray of ObjectYesList of query targets. Each object specifies one query item.
data[].deviceIdStringYesThe ID of the target device to query.
data[].endpointIdNumberYesEndpoint ID. Specifies which device endpoint to query.
data[].functionCodeStringYesThe function code. Specifies which function to query.
data[].traitCodesArray of StringYesList of trait codes. Specifies which trait values to query.
Request Example
Below is a request body example for GetTraitValueRequest:
"type" : "GetTraitValueRequest",
"version" : "v1",
"data":[{
"endpointId": 3,
"traitCodes": ["TargetPlaybackState"]
Response Data
typeStringThe message type of the response. Always GetTraitValueResponse.
versionStringResponse version, same as the request API version.
msgIdStringThe msgId you provided in your request.
codeNumberWhether the request was successful. 0 means success, non-zero means failure.
dataArray of ObjectThe list of response data items.
data[].valueAnyThe current value of the trait.
data[].timeNumberThe time when the value was reported, as a Unix timestamp in milliseconds.
Example Response
Below is an example response for GetTraitValueResponse:
"type": "GetTraitValueResponse",
"version": "v1",
"message": null,
"data": [
"endpointId": 3,
"value": "0",
"time": 1761308409323
Subscribe to Multiple Trait Changes
This API allows you to subscribe to real-time updates for device traits. When the value of a device trait changes, Studio will proactively send you the latest data via this API.
By subscribing, you can get device status changes in time, without polling frequently. This improves communication efficiency and real-time response.
Request Parameters
typeStringYesThe message type. Must be SubscribeTraitValueRequest.
data[].deviceIdStringYesThe ID of the device to subscribe to.
data[].traitCodesArray of StringYesList of trait codes to subscribe.
Request Example
Below is a request body example for SubscribeTraitValueRequest:
"type" : "SubscribeTraitValueRequest",
"version" : "v1",
"data":[{
"endpointId": 3,
Subscription Response
Response Data
typeStringYesThe response message type. Always SubscribeTraitValueResponse.
versionStringYesAPI version, same as in the request.
msgIdStringYesUnique identifier for the corresponding request.
codeNumberYesRequest result. 0 means subscription successful; any other value means failure.
messageStringNoDescription of the response result.
Example Response
Below is an example of a successful SubscribeTraitValueResponse:
"type": "SubscribeTraitValueResponse",
"version": "v1",
"message": ""
Device Trait Change Notification
When a device trait value changes, Aqara Studio will push the update to you in real time.
Notification Data Structure
typeStringYesThe response message type. Always TraitValueUpdate.
dataArray of ObjectYesArray of data objects.
data[].deviceIdStringYesDevice ID.
data[].traitCodeStringYesTrait code.
data[].valueAnyYesValue of the trait. The data type depends on the trait.
data[].timeNumberYesUpload time of the trait value, as a Unix timestamp in milliseconds.
Notification Example
When the trait value you subscribed to changes, a TraitValueUpdate will look like this:
"type": "TraitValueUpdate",
"version": "v1",
"data": [{
"endpointId": 3,
"value": "0",
"time": 1754469720110
Unsubscribe from Trait Changes
If you no longer need real-time updates about trait values, use this API to cancel your subscription.
Request Parameters
typeStringYesThe message type. Must be UnsubscribeTraitValueRequest.
data[].deviceIdStringYesDevice ID to unsubscribe from.
data[].traitCodesArray of StringYesList of trait codes to unsubscribe.
Request Example
Here is an example request body for UnsubscribeTraitValueRequest:
"type" : "UnsubscribeTraitValueRequest",
"version" : "v1",
"data": [{
"endpointId": 3,
Response Data
typeStringThe response message type. Always UnsubscribeTraitValueResponse.
versionStringYes
msgIdStringYes
codeNumberYes
messageStringNo
Example Response
Here is a sample UnsubscribeTraitValueResponse:
"type": "UnsubscribeTraitValueResponse",
"version": "v1",
"msgId": "0806",
"message": ""
Subscribe to All Trait Changes
Subscribe to all trait changes of multiple devices.
Request Parameters
typeStringYesThe message type. Must be SubscribeAllRequest.
dataArray of StringNoList of device IDs to subscribe. If empty, all devices will be subscribed.
note
Subscribing to all devices and subscribing to specific devices are mutually exclusive and cannot be active at the same time. If this request’s data field is not empty but the previous one was empty, the system will cancel the previous “all devices” subscription and keep only the specific device subscription. The opposite also applies.
Request Example
Here is an example body for SubscribeAllRequest:
"type": "SubscribeAllRequest",
"version": "v1",
"msgId": "1751609244328",
"data": ["deviceId"]
Response Data
typeStringYesResponse type. Always SubscribeAllResponse.
versionStringYesResponse API version. Must be v1.
msgIdStringYesUnique ID corresponding to the request.
codeNumberYesResult code. 0 means success, non-0 means fail.
messageStringNoDescription of the response.
Example Response
Here is an example response of SubscribeAllResponse:
"type": "SubscribeAllResponse",
"version": "v1",
"message": ""
Unsubscribe from All Trait Changes
Unsubscribe from all trait changes of multiple devices.
Request Parameters
typeStringYesThe message type. Must be UnsubscribeAllRequest.
dataArray of StringNoList of device IDs to unsubscribe. If empty, will unsubscribe all devices.
note
  • If you have subscribed to "all devices", unsubscribing by specifying device IDs in data (i.e., a non-empty array) will be ignored. Only an empty data (unsubscribe all) takes effect.
  • If you have subscribed to "specific devices", sending an empty data (unsubscribe all) will unsubscribe all previous subscriptions for those devices.
Request Example
Here is an example body for UnsubscribeAllRequest:
"type": "UnsubscribeAllRequest",
"version": "v1",
"data": []
Response Data
typeStringYesResponse type. Always UnsubscribeAllResponse.
versionStringYesAPI version, same as requested.
codeNumberYesResult code. 0 means success, non-0 means failure.
Example Response
Here is a sample UnsubscribeAllResponse:
"type": "UnsubscribeAllResponse",
"version": "v1",
"message": ""
Object Event Messages Push
When you subscribe to certain trait changes or subscribe to all trait changes for a device, Studio will send you these real-time events:
  • Device added.
  • Device removed.
  • Device endpoint added.
  • Device endpoint removed.
  • Device trait parameter updated (e.g., min, max, unit, etc.).
Response Data
typeStringResponse type. Always objectEvent.
versionStringAPI version, will match the request.
msgIdStringUnique ID corresponding to the request.
dataObjectEvent data object.
data.eventTypeStringEvent type:
  • DEVICE_ADDED: Device added
  • DEVICE_REMOVED: Device removed
  • DEVICE_ENDPOINT_ADDED: Device endpoint added
  • DEVICE_ENDPOINT_REMOVED: Device endpoint removed
  • DEVICE_TRAIT_PAREMETER_UPDATE: Trait parameter updated (min, max, unit, etc.)
data.objectIdStringObject ID (the device ID).
data.timeNumberEvent time, Unix timestamp in milliseconds.
data.dataObjectDetailed event data. For details of this field, see data.data Field Description
The content of data.data varies by event type.
Non-DEVICE_TRAIT_PARAMETER_UPDATE Events
This structure applies if eventType is one of:
  • DEVICE_ADDED
  • DEVICE_REMOVED
deviceTypesListArray of StringList of device types. For details, see Device Types.
endpointIdsArray of NumberList of endpoint IDs.
If you receive a DEVICE_TRAIT_PARAMETER_UPDATE event, it is recommended to call GetDevicesRequest again to get the updated device spec.
data.data.deviceIdStringDevice ID.
data.data.endpointIdIntegerEndpoint ID.
data.data.functionCodeStringFunction code.
data.data.traitCodeStringTrait code.
data.data.newValueObjectLatest configuration.
data.data.newValue.endpointIdIntegerEndpoint ID.
data.data.newValue.functionCodeStringFunction code.
data.data.newValue.traitCodeStringTrait code.
data.data.newValue.minNumberMinimum value.
data.data.newValue.maxNumberMaximum value.
data.data.newValue.unitStringUnit.
data.data.newValue.stepNumberStep.
data.data.oldValueObjectPrevious configuration, same structure as newValue.
Example Response
Here are example responses for different events.
Example response for an objectEvent:
"type": "objectEvent",
"version": "v1",
"msgId": "123456",
"eventType": "DEVICE_ADDED",
"objectId": "14d3b91",
"time": 1754469720110,
"deviceId": "14d3b91",
"name": "",
"endpointIds": [0,2,3]
Example response for a DEVICE_TRAIT_PARAMETER_UPDATE event:
"version": "v1",
"msgId": "1765163175639",
"eventType": "DEVICE_TRAIT_PARAMETER_UPDATE",
"objectId": "xxxxxxx",
"time": 1765163175603,
"deviceId": "virtual.14247766413772",
"endpointId": 2,
"functionCode": "LevelControl",
"traitCode": "CurrentLevel",
"newValue": {
"endpointId": 2,
"max": 100.0,
"min": 1.0,
"step": null,
"unit": "%"
"oldValue": {
"endpointId": 2,
"max": 100.0,
"min": 1.0,
"step": 1.0,
"unit": "%"
"message": null
Query Device History
Query the history of a device by its device ID.
Request Parameters
typeStringYesMessage type, must be QueryDeviceHistoryDataRequest.
data.deviceIdStringYesDevice ID to query historical data for.
data.traitCodesArray of StringNoList of trait codes to query. If not specified, all historical data of the specified deviceId will be queried by default.
data.scanIdNumberNoPagination marker. Keep blank for the first query. To query the next page, pass the scanId returned in the previous response. Used for continuous paging of data.
data.descBooleanNoWhether to sort query results in descending order by time:
  • true: (default) descending
  • false: ascending
data.startTimeNumberYesThe query start timestamp, in milliseconds (UTC).
data.endTimeNumberYesThe query end timestamp, in milliseconds (UTC).
Note: The interval between start time and end time cannot exceed 7 days (endTime - startTime ≤ 7 * 24 * 60 * 60 * 1000)
data.langStringYesLanguage.
  • en-US: English
  • zh-CN: Chinese
data.sizeNumberNoNumber of records to query per request. Range: [1, 200], default is 50.
Example Request
Below is an example request body for QueryDeviceHistoryDataRequest:
"type" : "QueryDeviceHistoryDataRequest",
"version": "v1",
"msgId" : "msgId123456",
"data":{
"deviceId": "b1654af4fda39824",
// "traitCodes": ["EndpointCount"],
// "desc":false,
"lang":"en-US",
"startTime": 1770114300000,
"endTime": 1770639900000,
// "scanId": 0,
"size":3
Response Parameters
typeStringResponse message type, always QueryDeviceHistoryDataResponse.
versionStringResponse version, matches API version in the request.
codeNumberIndicates whether the request succeeded. 0 means success, nonzero means failure.
dataObjectResponse data object.
data.scanIdNumberPagination marker for querying the next page.
data.dataArray of ObjectHistorical data list. Each item contains:
data.data[].endpointIdNumberEndpoint ID.
data.data[].functionCodeStringFunction code.
data.data[].traitCodeStringTrait code.
data.data[].valueAnyValue for the specified traitCode.
data.data[].pointNameStringTrait display name (in the language specified by the data.lang parameter).
data.data[].pointValueStringHuman-readable value (in the language specified by data.lang).
data.data[].unitStringUnit of value.
data.data[].timeNumberReport time in UTC, milliseconds.
Example Response
Below is an example of a QueryDeviceHistoryDataResponse response:
"type": "QueryDeviceHistoryDataResponse",
"version": "v1",
"msgId": "msgId123456",
"scanId": 3178,
"data": [
"deviceName": "Home Assistant Versions Update Available",
"endpointId": 2,
"functionCode": "OnOffSensor",
"traitCode": "BooleanState",
"value": true,
"pointName": "OnOff Sensor - Boolean State",
"pointValue": "True",
"unit": "",
"time": 1770580415746
"endpointId": 2,
"value": false,
"pointValue": "False",
"unit": "",
"time": 1770580114489
"endpointId": 2,
"value": true,
"unit": "",
"time": 1770564659744
"code": 0
