Data Export API v1
Aqara provides the Data Export API v1, which allows you to access device data from the Studio system and perform secondary development.
The API supports querying and subscribing to device data, device control, device add/delete event notifications, and scene list queries.
Communication Protocols
The Studio API supports two main protocols: HTTP and WebSocket.
Request Endpoint
The request URL format varies depending on whether remote access is enabled.
HTTP Request
Request method: POST
Request URL format:
- Remote access disabled:
http://<local_LAN_IP>/open/api/v1 - Remote access enabled:
https://<remote_access_address>/open/api/v1
WebSocket Request
Request URL format:
ws://<local_LAN_IP>/open/ws - Remote access enabled:
ws://<remote_access_address>/open/ws
After you establish a connection, you can send and receive JSON messages in real time with the server.
Request Headers
| Parameter | Type | Required | Description |
| Authorization | String | Required for HTTP and WebSocket | Authorization Token for user authentication. Format is Bearer <token>. Replace <token> with the token you obtained from Aqara Studio. (If the token from Aqara Studio already includes the Bearer prefix, use it directly without adding another Bearer.) For more details on how to get the token, see Developer Guide - Obtain Required Information. |
| Content-Type | String | HTTP only | Default is application/json. |
API List
Aqara Studio determines and responds to different API functions based on the type field in the request body. The table below summarizes all supported APIs in Aqara Studio, along with their corresponding request and response types:
| API Function | Request Type | Response Type |
| Query Device Information by Pages | GetDeviceInfoRequest | GetDeviceInfoResponse |
| Query All Device Information | GetAllDeviceInfoRequest | GetAllDeviceInfoResponse |
| Query Device Spec Configuration | GetDevicesRequest | GetDevicesResponse |
| Control Device | ExecuteTraitRequest | ExecuteTraitResponse |
| Query the Latest Values of Device Traits | GetTraitValueRequest | GetTraitValueResponse |
| Subscribe to Multiple Trait Changes | SubscribeTraitValueRequest | SubscribeTraitValueResponse |
| Unsubscribe from Trait Changes | UnsubscribeTraitValueRequest | UnsubscribeTraitValueResponse |
| Subscribe to All Trait Changes | SubscribeAllRequest | SubscribeAllResponse |
| Unsubscribe from All Trait Changes | UnsubscribeAllRequest | UnsubscribeAllResponse |
| Object Event Messages Push | - | objectEvent |
| Query Device History | QueryDeviceHistoryDataRequest | QueryDeviceHistoryDataResponse |
| Query Device Traits Available for Automation | QueryAutomationCapabilitiesRequest | QueryAutomationCapabilitiesResponse |
| Create Automation | CreateAutomationRequest | CreateAutomationResponse |
| Edit Automation | UpdateAutomationRequest | UpdateAutomationResponse |
| Batch Update Automation Status | UpdateAutomationStatusRequest | UpdateAutomationStatusResponse |
| Query Automation List | GetAutomationListRequest | GetAutomationListResponse |
| Query Automation Details | GetAutomationDetailsRequest | GetAutomationDetailsResponse |
| Delete Automation | DeleteAutomationRequest | DeleteAutomationResponse |
Error Handling
If you receive an error response after making an API request, don’t worry. The error message will help you troubleshoot and solve the issue.
Below is an example to help you quickly understand and resolve problems:
"type": "ErrorMessage",
"version": "v1",
"msgId": "UNKNOWN",
"code": 1000,
"message": "Message parsing failed: Unexpected JSON token at offset 0: Serializer for subclass 'GetDeviceInfo' is not found in the polymorphic scope of 'WebSocketMessageRequest' at path: $\nCheck if class with serial name 'GetDeviceInfo' exists and serializer is registered in a corresponding SerializersModule.\nTo be registered automatically, class 'GetDeviceInfo' has to be '@Serializable', and the base class 'WebSocketMessageRequest' has to be sealed and '@Serializable'.\nJSON input: {\n \"type\": \"GetDeviceInfo\",....."
Check the
typefieldFirst, look at the
typefield in the response. All failed requests will haveErrorMessageas the value. -
Check the
msgIdfieldIf there was a format error in your request, the
msgIdwill usually beUNKNOWN, which means the server did not recognize a valid request ID. -
Carefully read the
messagefield for detailsThe
messagefield provides detailed error information. It usually includes the most important clues, for example, missing parameters or data type mistakes. Read this carefully to figure out the precise issue and how to fix it.
