View and Edit Basic Information
This article explains how to view and edit the basic information of a device, such as its name.
  1. Go to the Devices page. In the Protocol and Device Tree on the left, select the device you want to view, and click the More Settings button.
    Click the "More Settings" button
  2. In the More Settings popup window, you can view and edit the following basic information:
    View and edit basic information
    FieldEditableDescription
    Device Name✓You can rename the device to help with identification and management.
    Device Type✗A collection of the function point types of the device.
    Device ID✗The ID assigned to the device by Aqara Studio.
    Device Status✗The device's online status.
    Space✓It Shows and allows you to change the space where the device is located. This helps you manage the mapping between devices and physical spaces.
    Point Count✗The number of function points supported by the device.
    Import Time✗The time when the device was imported into Aqara Studio.
    Firmware Version✗The device's firmware version.
