Plugin Center
Aqara Studio supports the acquisition and installation of plugins via Aqara Builder Lab - Marketplace to extend its functionality. Plugins in the marketplace are provided by Aqara officially, and users can also develop and upload their own plugins.
Prerequisites​
Before getting started, please make sure you have set up Cloud Connect.
Acquire a Plugin​
  1. Visit the Aqara Builder Lab - Marketplace website, and navigate to Builder Lab from the left sidebar.
    Enter Builder Lab
  2. Go to the Marketplace from the left sidebar to browse various plugins. Click on the plugin you wish to acquire to view its details page.
    Enter Marketplace
  3. Click the Get Plugin button. After confirming you have read the installation information and confirming your order, you will successfully acquire the plugin.
    Get the Plugin
  4. Go to Assets from the left sidebar to view the plugins you have acquired.
    Click the Assign button to bring up the configuration popup.
    Assign Plugin
  5. In the configuration popup, select the target region, space, and Aqara Studio where you wish to install the plugin. After confirming everything is correct, click Confirm to successfully assign the plugin to the specified Aqara Studio.
    Select Studio
Install a Plugin​
  1. Visit your Aqara Studio and go to the Plugin Center from the left sidebar.
  2. Find the plugin you just assigned, click the Install button to start installation. Once installed, you can use the capabilities provided by the plugin.
Click Install
Plugin Overview​
The following table summarizes the various plugins related to Aqara Studio. You can clearly understand the main function of each plugin and use the links to view detailed usage instructions.
Plugin NameDescriptionDocumentation
AIOT Data MigrationSupport the migration of sub device data from some gateways on AIOT (Aqarahome) to gateways within Studio, with the migration scope only supporting Zigbee sub device binding relationships.AIOT Data Migration
MQTT Protocol AccessProvides device access capabilities based on the MQTT standard protocol, supporting connection configuration, message parsing, and data processing through scripting.MQTT Protocol Access
HTTP Protocol AccessProvides device access capabilities based on the HTTP standard protocol, supporting connection configuration, message parsing, and data processing through scripting.HTTP Protocol Access
TCP Protocol AccessProvides general network access capabilities based on TCP Socket, supporting custom message parsing and connection management.TCP Protocol Access
UDP Protocol AccessProvides device access capabilities based on the UDP standard protocol, supporting connection configuration, message parsing, and data processing through scripting.UDP Protocol Access
Sonos AccessSupport Sonos speaker devices to connect to Studio for use.Sonos Access
AqaraCoap Protocol AccessSupport the integration of original Aqara ecosystem devices into Aqara Studio using AqaraCoap protocol.AqaraCoap Protocol Access
Haystack ExportSupport the distribution of model information generated based on the Haystack framework to supported category devices, with only certain gateways being compatibleExport via Haystack Framework
