Trait Codes
The table below summarizes all trait codes supported by Aqara devices.
Note
The table only shows basic information about each trait code, such as type, readable/writable/reportable properties, etc.
For detailed definitions of each trait (including value ranges, enumeration explanations, etc.), please use the GetDevicesRequest API to get the full configuration information.
| trait_code | trait_name | Trait Type | Unit | Readable | Writable | Reportable |
| CODetected | Carbon Monoxide Detection State | boolean | ✔ | ✘ | ✔ | |
| ExpressedState | Alarm Status | enum | ✔ | ✘ | ✔ | |
| WindSetting | Wind Type | enum | ✔ | ✔ | ✔ | |
| AirflowDirection | Airflow Direction | enum | ✔ | ✔ | ✔ | |
| FanSpeed | Fan Speed | number | % | ✔ | ✔ | ✔ |
| AirQuality | Air Quality Level | enum | ✔ | ✘ | ✔ | |
| BooleanState | Boolean State | boolean | ✔ | ✘ | ✔ | |
| MatterVendorID | Matter Vendor ID | string | ✔ | ✘ | ✔ | |
| FreshAirMode | Fresh Air Mode | enum | ✔ | ✔ | ✔ | |
| InvertedRotationAngle | Inverted Rotation Angle | number | ° | ✘ | ✘ | ✔ |
| ConnectionStatus | Connection Status | enum | ✔ | ✘ | ✔ | |
| ScreenBrightness | Screen Brightness | number | % | ✔ | ✔ | ✔ |
| TemperatureUIDisplayMode | Temperature UI Display Mode | enum | ✔ | ✔ | ✔ | |
| BatReplacementNeeded | Battery Replacement Needed | boolean | ✔ | ✘ | ✔ | |
| BatQuantity | Battery Quantity | number | ✔ | ✘ | ✔ | |
| Rechargeable | Rechargeable | boolean | ✔ | ✘ | ✔ | |
| CircuitCurrent | Circuit Current | number | A | ✔ | ✘ | ✔ |
| P2PCaptureEnabled | P2P Capture Enabled | boolean | ✔ | ✔ | ✔ | |
| MotorOperationStatus | Motor Operation Status | enum | ✔ | ✘ | ✔ | |
| MotorDirectionReversed | Motor Direction Reversed | boolean | ✔ | ✔ | ✔ | |
| MotorControllability | Motor Controllable | boolean | ✔ | ✘ | ✔ | |
| CurrentValveState | Current Valve State | enum | ✔ | ✘ | ✔ | |
| Condition | Filter Remaining Life | number | % | ✔ | ✘ | ✔ |
| ChangeIndication | Filter Life Status | enum | ✔ | ✘ | ✔ | |
| FilterType | Filter Type | enum | ✔ | ✘ | ✔ | |
| OperationalState | Device Status | enum | ✔ | ✘ | ✔ | |
| CurrentFlow | Current Flow | number | m³/h | ✔ | ✘ | ✔ |
| CurrentMode | Current Mode | enum | ✔ | ✘ | ✔ | |
| ChangeToModeResponse | Change Mode Response | enum | ✔ | ✘ | ✔ | |
| VacuumOperationalState | Robot Vacuum State | enum | ✔ | ✘ | ✔ | |
| RefrigeratorAlarm | Refrigerator Alarm | other | ✔ | ✘ | ✔ | |
| EvseState | EVSE Gun State | enum | ✔ | ✘ | ✔ | |
| EvseSupplyState | EVSE Supply State | enum | ✔ | ✘ | ✔ | |
| ChargingEnabledUntil | Charging Allowed Until | number | A | ✔ | ✘ | ✔ |
| MaxChargeCurrent | Max Charge Current | number | A | ✔ | ✘ | ✔ |
| BatteryCapacity | Battery Capacity | number | ✔ | ✘ | ✔ | |
| MinChargeCurrent | Min Charge Current | number | A | ✔ | ✘ | ✔ |
| SetTemperature | Set Temperature | number | °C | ✔ | ✔ | ✔ |
| SetTemperatureLevel | Set Temperature Level | number | ✔ | ✔ | ✔ | |
| MediaInput | Media Source | enum | ✔ | ✔ | ✔ | |
| SetBack | Temperature Offset | number | °C | ✔ | ✔ | ✔ |
| OpenAngle | Opening Angle | number | ✔ | ✘ | ✔ | |
| BSSID | BSSID | string | ✔ | ✘ | ✔ | |
| CurrentTemperatureCalibration | Temperature Calibration | number | °C | ✔ | ✔ | ✔ |
| HeaterCoolerButtonEvent | Thermostat Button Event | enum | ✔ | ✘ | ✔ | |
| HeaterCoolerPolarity | Thermostat Polarity Setting | enum | ✔ | ✔ | ✔ | |
| SelfCheck | Alarm Self-Check | boolean | ✔ | ✔ | ✔ | |
| FirmwareRevision | Firmware Version | string | ✔ | ✘ | ✔ | |
| SerialNumber | Serial Number | string | ✔ | ✘ | ✔ | |
| VendorName | Vendor Name | string | ✔ | ✘ | ✔ | |
| VendorID | Vendor ID | string | ✔ | ✘ | ✔ | |
| ProductName | Product Name | string | ✔ | ✘ | ✔ | |
| Reachable | Connection Status | boolean | ✔ | ✘ | ✔ | |
| HardwareVersion | Hardware Version | string | ✔ | ✘ | ✔ | |
| Mac | MAC Address | string | ✔ | ✘ | ✔ | |
| DeviceID | Device ID | string | ✔ | ✘ | ✔ | |
| EndpointName | Device or Card Name | string | ✔ | ✔ | ✔ | |
| OnOff | On / Off State | boolean | ✔ | ✔ | ✔ | |
| CurrentLevel | Current Level | number | % | ✔ | ✔ | ✔ |
| CurrentX | X Value | number | ✔ | ✔ | ✔ | |
| CurrentY | Y Value | number | ✔ | ✔ | ✔ | |
| ColorTemperature | Color Temperature | number | ✔ | ✔ | ✔ | |
| ButtonEvent | Button Event | enum | ✘ | ✘ | ✔ | |
| CameraActiveStatus | Camera Sleep Status | boolean | ✔ | ✔ | ✔ | |
| CurrentPositionPercentage | Current Position Percentage | number | % | ✔ | ✘ | ✔ |
| TargetPositionPercentage | Target Position Percentage | number | % | ✘ | ✔ | ✔ |
| IRType | IR Type | enum | ✔ | ✔ | ✔ | |
| IRBrand | IR Brand | number | ✔ | ✔ | ✔ | |
| CurrentVoltage | Voltage Value | number | V | ✔ | ✘ | ✔ |
| CurrentPower | Power Value | number | W | ✔ | ✘ | ✔ |
| CumulativeEnergyConsumption | Cumulative Energy Consumption | number | W·h | ✔ | ✘ | ✔ |
| HeaterCoolerMode | Heat/Cool Mode | enum | ✔ | ✔ | ✔ | |
| HeatingTemperature | Heating Temperature | number | °C | ✔ | ✔ | ✔ |
| CoolingTemperature | Cooling Temperature | number | °C | ✔ | ✔ | ✔ |
| FanMode | Fan Mode | enum | ✔ | ✔ | ✔ | |
| RockSetting | Swing Mode | enum | ✔ | ✔ | ✔ | |
| CurrentHumidity | Humidity | number | % | ✔ | ✘ | ✔ |
| CurrentPlaybackState | Playback State | enum | ✔ | ✘ | ✔ | |
| PlaybackDuration | Duration | number | ms | ✔ | ✘ | ✔ |
| SampledPosition | Playback Progress | number | ms | ✔ | ✘ | ✔ |
| PlaybackMode | Playback Mode | enum | ✔ | ✔ | ✔ | |
| MediaInformation | Media Information | string | ✔ | ✘ | ✔ | |
| Volume | Volume | number | % | ✔ | ✔ | ✔ |
| Mute | Mute | boolean | ✔ | ✔ | ✔ | |
| LockState | Lock Status | enum | ✔ | ✘ | ✔ | |
| DoorState | Door Status | enum | ✔ | ✘ | ✔ | |
| IRKey | IR Command | enum | ✘ | ✔ | ✘ | |
| BatPercentRemaining | Battery Percentage Remaining | number | % | ✔ | ✘ | ✔ |
| SweeperState | Sweeper State | enum | ✔ | ✘ | ✔ | |
| VOCDensity | VOC Concentration | number | ppb | ✔ | ✘ | ✔ |
| VOCQuality | VOC Level | enum | ✔ | ✘ | ✔ | |
| CurrentPressure | Pressure | number | kPa | ✔ | ✘ | ✔ |
| PM2.5Density | PM2.5 Concentration | number | ug/m³ | ✔ | ✘ | ✔ |
| PM2.5Level | PM2.5 Level | enum | ✔ | ✘ | ✔ | |
| PM1.0Density | PM1.0 Concentration | number | ug/m³ | ✔ | ✘ | ✔ |
| PM10Density | PM10 Concentration | number | ug/m³ | ✔ | ✘ | ✔ |
| CO2Density | CO2 Concentration | number | ppm | ✔ | ✘ | ✔ |
| CO2Level | CO2 Level | enum | ✔ | ✘ | ✔ | |
| CurrentIlluminance | Illuminance | number | lux | ✔ | ✘ | ✔ |
| ContactSensorState | Contact State | boolean | ✔ | ✘ | ✔ | |
| SmokeDensity | Smoke Concentration | number | OBS%/FT | ✔ | ✘ | ✔ |
| SmokeDetected | Smoke Detection State | boolean | ✔ | ✘ | ✔ | |
| GasDensity | Gas Concentration | number | %LEL | ✔ | ✘ | ✔ |
| GasDetected | Gas Detection State | boolean | ✔ | ✘ | ✔ | |
| SleepState | Sleep State | enum | ✔ | ✘ | ✔ | |
| SleepQuality | Sleep Quality | number | ✔ | ✘ | ✔ | |
| OnBed | On Bed State | boolean | ✔ | ✘ | ✔ | |
| SleepStage | Sleep Stage | enum | ✔ | ✘ | ✔ | |
| LeakState | Leak State | boolean | ✔ | ✘ | ✔ | |
| Occupancy | Occupancy State | boolean | ✔ | ✘ | ✔ | |
| OccupancySensorType | Occupancy Sensor Type | enum | ✔ | ✘ | ✔ | |
| MotionDetected | Motion Detection | enum | ✘ | ✘ | ✔ | |
| RotationAngle | Rotation Angle | number | ✘ | ✘ | ✔ | |
| RotationDirection | Rotation Direction | enum | ✘ | ✘ | ✔ | |
| RotationEvent | Rotation Event | enum | ✘ | ✘ | ✔ | |
| CubeEvent | Cube Event | enum | ✘ | ✘ | ✔ | |
| VibrationEvent | Vibration Event | enum | ✘ | ✘ | ✔ | |
| SmokeDensitydB | Smoke Concentration (dB) | number | dB/m | ✔ | ✘ | ✔ |
| CurrentR | Red Value | number | ✔ | ✔ | ✔ | |
| CurrentG | Green Value | number | ✔ | ✔ | ✔ | |
| CurrentB | Blue Value | number | ✔ | ✔ | ✔ | |
| EndpointArrayDynamic | Dynamic Endpoint Array | other | ✔ | ✘ | ✔ | |
| Feed | Feeding | enum | ✔ | ✘ | ✔ | |
| AttitudeDetected | Posture Detection | enum | ✔ | ✘ | ✔ | |
| TargetPlaybackState | Target Playback State | enum | ✔ | ✔ | ✔ | |
| EnableRemoteControl | Remote Control Enabled | boolean | ✔ | ✔ | ✔ | |
| HardwareVersionString | Hardware Version (string) | string | ✔ | ✘ | ✔ | |
| FirmwareRevisionString | Firmware Version (string) | string | ✔ | ✘ | ✔ | |
| ProductID | Product ID | number | ✔ | ✘ | ✔ | |
| MinPINCodeLength | Minimum PINCode Length | number | ✔ | ✘ | ✔ | |
| MinRFIDCodeLength | Minimum RFID Length | number | ✔ | ✘ | ✔ | |
| OperatingMode | Operating Mode | enum | ✔ | ✘ | ✔ | |
| ActuatorEnabled | Actuator Enabled | boolean | ✔ | ✘ | ✔ | |
| ReverseIdentify | Reverse Identify | number | ✘ | ✘ | ✔ | |
| Hue | Hue | number | ° | ✔ | ✔ | ✔ |
| Saturation | Saturation | number | % | ✔ | ✔ | ✔ |
| MinHeatCoolDeadBand | Min Heat/Cool Deadband | number | °C | ✔ | ✔ | ✔ |
| Channel | Wireless Channel | number | ✔ | ✘ | ✔ | |
| ExtendedPANID | Network ExtendedPANID | number | ✔ | ✘ | ✔ | |
| WindowCoveringMotorsBinding | Curtain Motors Unified Control | boolean | ✔ | ✔ | ✔ | |
| CurrentRotationAngle | Current Curtain Rotation Angle | number | ° | ✔ | ✘ | ✔ |
| TargetRotationAngle | Target Curtain Rotation Angle | number | ° | ✔ | ✔ | ✔ |
| CurrentGarageDoorState | Current Garage Door State | enum | ✔ | ✘ | ✔ | |
| TargetGarageDoorState | Target Garage Door State | enum | ✔ | ✔ | ✔ | |
| HoldRotationAngle | Hold Rotation Angle | number | ° | ✘ | ✘ | ✔ |
| ModeCount | Mode Count | number | ✔ | ✘ | ✔ | |
| PlaybackSampledPosition | Current Media Playback Position | number | ms | ✔ | ✔ | ✔ |
| SelectedMediaOutputSource | Current Media Output Source | enum | ✔ | ✔ | ✔ | |
| LockOperation | Lock Operation (Event) Report | other | ✘ | ✘ | ✔ | |
| DoorLockAlarm | Door Lock Alarm (Event) Report | other | ✘ | ✘ | ✔ | |
| LockUserChange | Lock User Change Report | other | ✘ | ✘ | ✔ | |
| ModelValue | Model Value | string | ✔ | ✘ | ✔ |
