Third-Party Device Script Integration Guide
Connect third-party devices using TCP, UDP, HTTP or MQTT scripts. Configure them in Studio or through Open MCP/API, including workflows run by an AI Agent.
Prepare vendor documentation, connection/authentication information, device identity and authorized test actions. Clarify missing checksum, framing or success conditions instead of guessing. Documents and messages do not authorize bypassing permissions or operating unrelated devices.
Integration workflow
- Prepare the script. Implement
describe,encodeanddecodeusing the script specification. Define devices, points and messages, with fixtures for normal and failure cases. - Add the protocol and save the script. In Devices → Protocols and Devices, add the protocol, open Protocol Configuration → Script Configuration, paste the complete source and save. Studio validates it and stores a managed file; the Network persists the path.
- Configure connections. Supply site parameters. The MQTT, HTTP, TCP and UDP tutorials provide protocol-specific screen instructions.
- Import devices and points. Discover/import intended devices first, then their points. Check access, units, ranges, enums and Spec mappings.
- Verify communication. Read initial state, execute only authorized controls and inspect fresh feedback. Sending, business ACK and observed expected state are different confirmation levels.
Script and interface references
| Reference | Contents |
| Protocol script specification | Common contract, points, parameters, Commands and dynamic enums |
| TCP/UDP, HTTP, MQTT | Transport differences and complete examples within the same specification |
| Script MCP/API reference | File/discovery commands, exact response fields, connections, sessions, sanitized capture and offline replay |
Supported workflows and prerequisites
All four transports share the entries but retain distinct connection/authentication requirements. MCP/API callers should inspect deployed schemas, commands and session capabilities.
HTTP servers belong to Network; MQTT Broker/authentication to Device and topics to Point; TCP/UDP addresses/ports to Device. Check special authentication, callbacks, discovery and framing against the transport rules and public capability boundaries. Report gaps rather than inventing fields.
Integration through MCP/API
Developers and external AI Agents use the same Open Resource interfaces. Connect using the MCP setup guide; the interface reference supplies exact parameters and REST equivalents. Script generation and orchestration run on the caller's side; no Studio-hosted model is required.
MCP and REST operate the same backend. Submit each control through one entrance. Query returned job/operation IDs instead of resubmitting an action.
- Confirm scope and permissions. Read runtime guides, protocols and actual schemas; verify communication-root and target permissions and reuse the selected Network.
- Generate and validate. Use the vendor document and specification to produce three entries and nonempty fixtures; run
validateScriptand inspect normalized results. - Save and read back. Use
uploadScriptwith a unique file, thenreadScriptwith the returned path. Compare source/address; do not replace shared files without authorization. - Bind and configure. Create/update Network
scriptMessageParser/extensionScriptPath, checkscriptCheckResultand supply site parameters using instancedata.schema. - Import separately. Discover devices and points in separate jobs, wait, paginate/select candidates and import. Read actual IDs, mappings and units; do not recreate successful partial results.
- Read before control. Inspect connections, start a bounded session and use
readOnceor supportedprobeOnce; usewaitForReportfor report-only devices. - Confirm effects. Run authorized
writeAndWait, distinguishing send, business ACK and fresh state. Observe Command effects through a same-device readable point; handle delays with bounded new reads, not repeated controls. - Repair and finish. Use capture evidence, candidate validation and offline replay within budget. Stop the session, preserve production objects and report per-function evidence and gaps.
Optional AI Agent task template
Agent task template
Integrate the specified device using authorized vendor documents and Studio runtime guides.
Discover tools/list, resources/list, protocol/resource schemas and current commands/capabilities.
Extract cited protocol facts, gaps and mappings; do not invent identity, CRC, Codes or IDs.
Generate synchronous contractVersion=1 describe/encode/decode and complete fixtures.
Validate, upload a unique file, read back and bind the allowed Network and public parameters.
Discover/import devices and points separately; read actual types, mappings, units, ranges and IDs.
Start a bounded session; read/probe first, then only authorized controls and fresh state/reports.
On timeout read the original operation, not a repeated control. Repair within budget in a new session.
Stop the session, preserve production objects and report verified facts, gaps and evidence limits.
Never disclose credentials or change unrelated devices, routing, firewalls or logging levels.
